JakeJY
Re: GH5 and focus issues with non-panasonic lenses?
Michael1000 wrote:
JakeJY wrote:
Michael1000 wrote:
It is my understanding that Panasonic GH5 has lens data stored in the camera for Panasonic lenses that tell the camera how much the focus needs to change to get in focus. So it first reads how out of focus it is, and then based on that data, it goes to the lens data table to see how much focus change it needs to get in focus. It is able to go straight to in focus, with only minor corrections. Also if you get new Panasonic lenses that don't have this lens data in the camera firmware, the GH5 will read the data it needs from firmware in the lens.
Olympus has not put this data in the firmware of their lenses for the GH5 to read. Therefore, the GH5 has to rely on trial and error using the contrast based focusing system to get in focus, which ends up in a number of overshoots until it zeros in on the focus. This is a much slower process.
That's DFD, which is something different. Yes it does focus at once (similar to PDAF) for faster focusing, but I think what the others are talking about are actually more correct. I don't believe the OP loses focus with the Panasonic lens and then reacquire quickly. Rather the lens never changes focus through the zoom range.
The Panasonic PZ lenses appear to be electronically parfocal (on Panasonic bodies). This means as you zoom, the lens attempts to maintain focus at the same distance electronically. It's not truly parfocal given this doesn't appear to work on Olympus bodies.
That's interesting. I didn't know the Panasonic lenses did that. How are those lenses that have that feature identified (something in the model name)?
Also I wonder if they can also electronically compensate for focus breathing.
Unfortunately this does not appear to be identified in any systematic way. And given it is doesn't appear cross compatible between systems (Olympus vs Panasonic) that makes it even tougher.
For example, here's a thread that tries to find parfocal M43 lenses:
https://www.dpreview.com/forums/thread/4130430
You will note that the 45-175 is listed as not parfocal on a EM-5 II.
However, LensRentals says it is a parfocal lens for video:
https://www.lensrentals.com/rent/panasonic-pz-45-175mm-f4.0-5.6-ois
This test suggests it is (at least on a GH4 body):
https://www.youtube.com/watch?v=pHkbjD1VIfs
However this review says it's not on a G5 body:
https://www.amazon.com/review/R3CX35RED8A35X
I'm guessing given the inconsistencies (and perhaps effectiveness of it; I can see it varying depending on the zoom speed), it's not really advertised.
I forgot where I read it, but also, this electronic parfocal only appears to work well if you set focus zoomed in, before zooming out. Doing the other way around may be less accurate.
