G10 and G12 questions
Started Jul 25, 2017 | Discussions
Mo Kwart
Mo Kwart Senior Member • Posts: 1,261
I am taking my grandson to an astronomy-photography workshop. I have an SLR and he has a G10 with access to his mother's G12. I understand that maximum shutter for these G models is 15 seconds. Does the camera have something similar to a B mode where we can leave the shutter open as long as we want? I will appreciate your help here and any pointers on astrophotography with a Canon G will also be appreciated.
 Mo Kwart's gear list:Mo Kwart's gear list
Fujifilm X-T1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +4 more
Canon PowerShot G12
Chaplain Mark
Chaplain Mark Veteran Member • Posts: 6,539
Re: G10 and G12 questions
Mo,
I downloaded the user guides for the G10 and G12 from the Canon website; niether camera has Bulb shutter mode.....sorry..!
Thank You,
Chaplain Mark
'Tis better to have a camera and not need one than to need a camera and not have one.
 Chaplain Mark's gear list:Chaplain Mark's gear list
Canon G3 X Canon PowerShot G5 X Sony a7R III Sony a7C Sony FE 135mm F1.8 GM +3 more
rpm40
rpm40 Senior Member • Posts: 2,411
If you are up for a little project, you can download the CHDK software for your grandson's G10 and play around with that. It will give you bulb mode for your camera. It is installed right to an SD card, so it does not modify the camera, and is easy to go back to the original settings.
http://www.instructables.com/id/How-To-Install-CHDK/
Chaplain Mark
How cool.....I didn't know..!!
Thank You,
Chaplain Mark
Mo Kwart
OP Mo Kwart Senior Member • Posts: 1,261
Thanks for the research and for the interesting hacking project. No time before this trip, but we'll see how interested he is to continue in this direction.
