Is this lens easily fixable (18-55mm)?
Started Jul 23, 2017 | Discussions
bryguy
bryguy Regular Member • Posts: 144
The unthinkable happened, my nx300 with the 18-55 kit lens slid off the tripod and the lens broke off (pic below). Thankfully this was not my 16-50 "S" and NX1! NX300 still working. Question, is this lens fixable? Looks like the main data ribbon cable broke off alone with 3 small screws. Everything else looks fine. If not, has anyone bought refurbished nx lenses? I see a 16-50 pz for relatively cheap on eBay. Thanks!
 bryguy's gear list:bryguy's gear list
Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS Samsung NX 45mm F1.8
Samsung NX1 Samsung NX300M
markyboy81 Veteran Member • Posts: 4,778
Re: Is this lens easily fixable (18-55mm)?
Almost all of my lenses have been bought used and touch wood I haven't had any issues. You could attempt to fix it but if you can find a cheap 16-50pz I'd go for it as (in my opinion) it's a better lens and much more portable when paired with the nx 300.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Veducci Senior Member • Posts: 1,359
I purchased my NX300 with a 18-55 f/3.5 lens and found it to be decently sharp for a cheap kit lens. Of course most of us know and understand the fact that kit lenses are not built to a high quality standard when compared to a pro lens so they can and do break easily when subject to rough situations. Personally I`ve been lucky and never has a kit lens fail me.
I had originally preferred to get one with the 16-50 PZ based on past experience with that lens but none were available at that particular time so I figured on buying the 16-50 pz separately to compare them and sell off one or the other.
Truth is they were close , both good copies , but the 16-50 pz was definitely sharper (only visible at full screen size though ) ,however the compactness of the 16-50 ,24mm wide aperture made the choice a solid no brainer. I paid $126 incl shipping (refurbished and arrived looking and works as brand new) so I`d have to say this lens is possibly the best kit lens bargain on Ebay.
http://www.ebay.com/itm/Samsung-16-50mm-Power-Zoom-ED-OIS-Lens-Black-/201992694234?hash=item2f07b3e9da:g:xAAAAOSwa~BYc6vr
Check out some of Ben Hermann`s very positive review comments below . I can fully and wholeheartedly support his highly positive opinion of this lens .
"All I can add to my initial comments is that this is one of the sharpest PZ kit lenses on the market. Sure, we'd all love to have the much more expensive glass (S lens), but not many of us can continuously shell out the bucks for those optics.
But this is where the PZ lens shines. If you are looking for superior optics but are limited with funds, look no further than this Samsung PZ lens. It has permanently stayed on my NX300 and I see no need to add anything else (subjective, I know). I've had so many stellar keepers with this lens that I must say (again, subjective...) that it is one of the finest (if not the finest) kit lenses out there.
And to say this a year or so after the initial review is saying something. You would be very happy with this lens and sure, we're love to have perhaps a longer reach (I'd love for Samsung to release a 16-85 kit lens (with this sharpness level), but that doesn't look like it's going to happen.
I'm going to eventually pick up the NX500 and luckily, it comes with the PZ lens.
hide signature --
Have a great one...."
Bernd (Ben) W. Herrmann
 Veducci's gear list:Veducci's gear list
Fujifilm FinePix F40fd Panasonic Lumix DMC-G3 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +3 more
bryguy
OP bryguy Regular Member • Posts: 144
Awesome, thanks for the thorough response. Is the link you provided the seller in which you purchased the refurbished pz lens? I'm a bit skeptical due to the no return policy with this particular seller. Good 100% feedback tho. I've seen another seller in the 98% range, also in the US, but will accept returns. Not sure which route to go. I'm just weary with my luck I'll get a refurb lens with some sort of imperfection, be it that cosmetic or optically.
Anyways, did you buy a lens hood?
bryguy
Thanks.. I agree. I've always wanted the PZ lens, guess this is good time as any to finally do it.
Even if they say no returns, you can still return if it's not as described, that's to say if there are any imperfections that weren't mentioned. PayPal will help you if there is any dispute.
StenM Regular Member • Posts: 201
just remove the ribbon cable, and glue/screw it back in place - use it as a MF lens
The link IS to the seller I purchased from.
No lens hood included . I simply got mine off Ebay by getting the cheapest 43-52mm step up ring and attaching an inexpensive 52mm (flared type) shallow hood. I`ve found anything smaller will vignette @24mm.
It`s pretty compact so I leave it on to keep the lens protected (mainly from fingerprints and smudges). I do not have to use the lens cap with the hood in place.
This 2 pc setup should cost less than $6 including shipping (from China of course). I waited about 2 weeks for delivery to the US.
bryguy
That's an interesting thought, but there goes my aperture control and OIS
bryguy
Thanks again. I ordered the PZ lens from the seller you linked to. Should get it this Friday. Hopefully it's a good as new copy.. Keeping my fingers crossed. Oh and thanks for the recommendation on the hood and pic!
billwest9 New Member • Posts: 1
Replying to an old thread. If you still have the broken lens, I am trying to repair the same lens and need parts. Let me know if you have it and want to get rid of it.
Thanks.
