3D Printing Lens Hoods
Started Jul 23, 2017 | Discussions
Djdirtboy New Member • Posts: 1
Re: 3D Printing Lens Hoods
Hello,
Very nice job.
Can you send me STL file for this hood?
Thanks a lot
linuxmaster
linuxmaster Junior Member • Posts: 48
OK. Where to get 35.5mm lens hood for $1? I would be glad to buy it.
 linuxmaster's gear list:linuxmaster's gear list
Canon PowerShot S80 Sony Cyber-shot DSC-H50 Sony Cyber-shot DSC-F828 Canon EOS 400D Sony Alpha NEX-5 +13 more
linuxmaster
Gigants live among us...
MikeyBugs95
MikeyBugs95 Regular Member • Posts: 446
35.5mm diameter?? Or to fit a 35.5mm lens?
It's a pretty simple task of 3D modeling something. It's getting it to fit that takes most of the time!
 MikeyBugs95's gear list:MikeyBugs95's gear list
Pentax K-3 II Pentax smc DA* 55mm F1.4 SDM Sigma 50mm F1.4 EX DG HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +11 more
linuxmaster
I have "antique" Soviet Industar 50-2 f/3.5 lense and it has 35.5 mm diameter in the filter part. That is why I want to put lens hood with 35.5 mm diameter. I found nothing like that at aliexpress or somewhere else. So it goes.
E Dinkla Senior Member • Posts: 2,613
Not at 1$ but I guess a filter adapter will allow another size hood to be adapted. Or fork out 9-12$ for one of the hoods at the bottom of this list: https://filterfind.net/35.5mm_filters.html
Met vriendelijke groet, Ernst
No photographer's gear list is complete without the printer mentioned !
Luisifer
Luisifer Contributing Member • Posts: 631
My first lens hood is for LWD Mitutoyo with 32.2 mm objective diameter:
https://12in.cz/pismo/id/18_Clonka-pro-objektivy-Mitutoyo
I prepared it with XT-CF20 filament.
 Luisifer's gear list:Luisifer's gear list
Canon EOS 5D Mark IV Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM Canon MP-E 65mm f/2.5 1-5x Macro +13 more
Dpap New Member • Posts: 1
MikeyBugs95 wrote:
I recently designed my own lens hood for the Sigma 50-500 OS HSM for use on APS-C cameras. I basically reverse-engineered the supplied lens hood and the APS-C extension and came up with this huge barrel-type hood. I outsourced printing and it came out very well. It's printed in a carbon fiber/nylon filament so it's very strong but slightly flexible and has very high impact resistance. After getting this hood, though, I found that it's just too big for my bag so I redesigned it to be about 5mm smaller in diameter, and about 10mm shorter. You can see in the bottom picture that it almost completely covers the lens. It ends about half an inch from the tripod foot. I decreased the thickness of the hood from 2mm to 1.5mm as well. I also tapered the left and right sides in a similar vein to the Tamron hood for the original 150-600. There were also ridges in the original design that I removed.
Hello,u make great job with the hood. maybe u can help me!!!I lost the hood from my sigma 50-500 len.can u send me the stf to make a new hood with the 3d print!
Jan Steinman
Jan Steinman Senior Member • Posts: 1,015
Captain Hook wrote:
A few years ago, I've tried 3D printing such parts. But it was always disappointing.
A lens hood generally requires more precision than you can get from a "filament extrusion" printer.
But resin printers have steadily come down in price, and their output is certainly up to the task.
Resin printers (also called "SLA" printers) require more expensive materials and more labour. You have to wash and cure the print. So they may not end up as such a bargain.
That said, I think it would be cool if there was a "library" of lens hood models, but who is going to make them? You have to do a number of precision measurements and enter them correctly into a CAD/CAM program, paying special attention to voids and supports and such.
In my experience, modelling is much more work than printing. That's a big time investment for just one or two lens hoods.
Jan Steinman
 Jan Steinman's gear list:Jan Steinman's gear list
Olympus 7-14mm F2.8 Pro Olympus E-3 Olympus E-300 Olympus Air Olympus PEN-F +50 more
Jan Steinman
slickwillie wrote:
I could probably get an inexpensive 3D printer and try 50 variations for the cost of buying a new hood for a 400 f/2.8...
It is unlikely that an "inexpensive" 3D printer will be up to the job, especially since you mention a screw and thread.
You'd need an SLA printer, and they start at about $400 or so.
SLA snobs consider filament printers, "toys."
Jan Steinman
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Actually, on Thingiverse I have scripts posted that can make all sorts of custom lenscaps and filter-thread-mounted stuff. Not yet posted, I have a version to make compact custom hoods -- basically, a flat mask design, with a second thing to print a measuring device so you can correctly size the mask-style hoods. I'm currently at the IS&T Electronic Imaging conference, so it'll be a while after I get home before I have a chance to post the hood mask stuff... which I keep forgetting to post.
Anyway, it's very similar to the Front-Mounted Waterhouse Stop Thing I have posted...
The only things that are hard to print about a hood are the filter thread and really thin walls with good durability. The thread is actually not a big deal, with a neat little trick to make it trivial. The thin-wall stuff is typically done in vase mode, and it is fragile, but there is even a trick for that, where you can force vase mode to make multi-layer walls by making the wall design a bit maze-like, so the slicer sees it as all outside walls. I don't use the second trick for my hoods, because they are the flat mask style.
BTW, most plastics for extrusion and resins are NOT opaque, especially in the NIR. Thus, you might need to coat the hood with Black 2.0 or somesuch.
As for resin printers being more precise, well, not really. They tend towards smoother surface finish and less long-range geometric distortion, but I've seen no evidence of them producing more precise parts, and they actually have worse problems with support structures and less than 100% infill structures... as well as using expensive, toxic, resin instead of nice friendly PLA.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
