E-pm2 Firmware update without cable?
Started Jul 22, 2017 | Discussions
M_digicapt Veteran Member • Posts: 3,289
I just got the camera second hand and it came without the USB cable. Is there a way to load the update to the SD card to install it?
Thanks,
Olympus PEN E-PM2
Fibinaci
Fibinaci Regular Member • Posts: 127
Not that I'm aware of
You have to use their updater app, but it also updates all lenses as well.
cables are thankfully not expensive
https://www.amazon.com/Bargains-Depot-Select-Olympus-Cameras/dp/B00CPCX0D0/ref=sr_1_2?s=electronics&ie=UTF8&qid=1500688403&sr=1-2&keywords=e-pm2+usb+cable
 Fibinaci's gear list:Fibinaci's gear list
Fujifilm X-T200 Fujifilm XF 18mm F2 R
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
Re: E-pm2 Firmware update without cable?
Thanks,
There is a site:
That has a collection of firmware for various Olympus cameras, along with documentation of how to update (or backdate) firmware without the cable.  Unfortunately, the E-PM2 is not one of the models whose firmware was collected.
According to the Olympus documentation, the last firmware release for the E-PM2 was 1.5 in January, 2016:
However, the last 3 firmware releases were for the newer high end Olympus lenses (12-100mm pro, 300mm pro, 40-150mm pro4) or the Toshiba FlashAir cards.  If your camera is at 1.2, you might not need to update to 1.5.
So, the solution is to buy a 3rd party clone cable that allows you to update the firmware if needed.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
OP M_digicapt Veteran Member • Posts: 3,289
Thanks. The camera has the original 1.0 firmware​...
Anybody know if the 1.2 firmware make any real difference?
Michael Meissner
From the list of features, probably not, unless you were going to use non-micro 4/3rds lenses or the VF-4 viewfinder.
I was thinking of this improvement ”Stability of touch panel operation during playback was improved.” but yes I want to use manual lenses so I need the upgrade to atleast 1.2 anyway. Thanks!
Michael Meissner
Yeah, but the touch panel is just an enhancement when reviewing pictures, it doesn't add anything to taking the pictures (at least according to the description).
Note, Olympus only gives you the ability to go to the latest level (1.5), you can't pick which intermediate level to go to.  The lightsnowdev site does allow you to downgrade the firmware, but unfortunately the E-PM2 is not a camera that they collected the firmware for (you might shoot off an email to the owner of the site, maybe he can download the E-PM2 firmware).
As I said, just get a clone CB-USB6 cable to do the download.  If you don't have other Olympus cameras, you will need to download the firmware updater for your Windows or Apple system.
I do have an older Olympus somewhere... maybe I still have the cable.
Karl S. Regular Member • Posts: 221
 Karl S.'s gear list:Karl S.'s gear list
Olympus E-M1 II Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +3 more
maltmoose Veteran Member • Posts: 3,051
Thanks,
There is a site:
Hi thought id just add a comment that https://lightsnowdev.com now has e-pm2 firmware and instructions to update via sd card.
I just updated mine to 1.5.. and works fine this way.
Thanks,
There is a site:
Thanks, good to know.
OliverHasanOlympus Regular Member • Posts: 115
Karl S. wrote:
I just purchased one of these:
CB-USB5 CB-USB6 CB-USB8 CBUSB8 USB Data SYNC Cable Cord Lead for Olympus Camera
Cool. Did it work for data transfer, and for what camera?
 OliverHasanOlympus's gear list:OliverHasanOlympus's gear list
Olympus E-M5 II Canon PowerShot S1 IS Canon PowerShot SX260 HS Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH +7 more
Works on E-M1 and E-M1 II.  I think it should work with any MFT.
Karl
Michael Meissner
Except for the newest cameras (E-m1 mark II, E-PL9, and E-m10 mark III).  I believe the E-m1 mark II uses a standard USB C cable and the E-PL9 and E-m10 mark III use a standard USB micro-B cable.
I stand corrected. E-M1 uses CB-USB6.  E-M1 II uses CB-USB11.
Till Kamppeter
Till Kamppeter Regular Member • Posts: 159
The site has also E-PM2 firmware (I used it for this camera, too as I do not have Windows or Mac) and I have looked now, all firmwares up to 1.5.
Till
 Till Kamppeter's gear list:Till Kamppeter's gear list
Olympus PEN-F Olympus E-M5 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH +11 more
Rolfens Forum Member • Posts: 97
The original firmware is quite buggy (mostly weird side effects with a few settings). It is better to update it. I have not checked whether any of the bugs I came across in the original firmware have been resolved by updates, because they are edge cases and I forgot how to reproduce them. But that's the idea.
I know this is an old thread - maybe it will benefit someone else.
 Rolfens's gear list:Rolfens's gear list
Olympus PEN E-PM2 Sony a7 Panasonic 20mm F1.7 II Samyang 12mm F2.0 NCS CS +11 more
G Rash Senior Member • Posts: 2,890
If you live near any camera stores, check and see if they will be having a day with an Olympus rep there. On "Olympus Day" they will usually clean your camera and sensor for free and update your firmware. I took in a couple of Oly bodies the last time there was an "Olympus Day" near me.
Gary
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
abderrahmen New Member • Posts: 1
hello, and thanks for the tip but ihave a question.
Can i update the firmware from 1.0 directly to 1.6??
 abderrahmen's gear list:abderrahmen's gear list
Olympus PEN E-PM2
Michael Meissner
Yes. There were a few models that you have to first go to an intermediate version (IIRC, the E-m5 mark I was one), but the E-pm2 doesn't list any restrictions.
The lightsnowdev site does have the firmware 1.6 for E-pm2.
Unfortunately, it doesn't provide the new Olympus E-m5 mark III, E-m1 mark III, and E-PL10 firmware files.
