SDQ Dynamic Range
Started Jul 21, 2017 | Discussions
PrebenR Veteran Member • Posts: 4,164
Re: SDQ Dynamic Range
lockhrt wrote:
Hmm. That is almost half of what I am used to.
That is not correct. According to DxOMark K5 has a max if 10.5 PDR. K-1 has 11.30.
Don't blame the camera
joe173 Contributing Member • Posts: 590
lockhrt wrote:
raylob wrote:
lockhrt
I ran a quickie comparison test between my FF K1 + 31mm ltd lens and my SDQ + 18-35mm A lens set to approx same 31mm focal range as my Pentax lens. Same aperture, same tripod no sharpening but images adjusted for brightness. There was little difference generally but I thought that the SDQ images were a little sharper. Don't forget that the Pentax is FF and the 31mm is one of Pentax's best lens! I use the Pentax as an alternative when conditions or subject matter does not favour the Sigma. Both systems are excellent at what they are designed for. I suspect that my post may not clarify your dilemma but in reality I get more satisfaction from my Sigma. I do not find that the DR is much of a problem.
Wow, you're right - this does not help me at all! I much prefer the SDQ photos above to the K1 except for maybe the twine, but that had more to do with exposure. And, the K1 is full frame, with the Holy Grail of prime lenses. This says a lot for the SDQ. Hmm.
Wouldn't a full frame Foveon be amazing!?
Not having a big DR is annoying, but it can be overcome. Use SFD mode and play with the raw image. If there is wind, use a graduated nd filter. It makes post processing much easier, and with less HD artifacts from overdoing SPP sliders. Just make sure to buy a good quality filter, not the el-cheapo ones. Is it more fiddley? Yes. But it makes you slow down and THINK about what you are DOING, and why which is better. On each shot, I set the white balance in the camera using settings, or manual white balance using a card. It made a big difference with the final good color quality. I always carry a light travel tripod to use for SFD mode if the situation calls for it. Slower work is better.
Sugasmune wrote:
It was measured in another topic, the photographic DR was little under 8 EV.
Who measured that?
Shutterbug says they measured it to 11.6 at iso 100. This sounds high to me, but I don't buy under 8 EV.
https://www.shutterbug.com/content/sigma-sd-quattro-h-mirrorless-camera-review#zpQFb6jrLjSAGuoj.97
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
PrebenR wrote:
Who measured that?
Thanks for the link. There's a DP2 Merrill review there too and (by coincidence?) it's DR is also measured at 11.6 EV.
Bill Claff is an acknowledged expert on DR here on DPR and has published his method (PTC curve) at his website. He has tested Sigmas in the past but disappeared from his site a long time ago. Not saying it was he who tested the qh ...
http://www.photonstophotos.net/
OT, but he did test my SD9 which came to 9-and-a-bit EV.
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
DMillier Forum Pro • Posts: 23,871
Where did you get that DXOMark score for the K5?
This page https://www.dxomark.com/Cameras/Pentax/K5---Measurements seems to indicate 14 stops DR (using their system). I don't know what that translates to in real world use at acceptable shadow noise levels. DR seems to be one of those specifications where you can score almost anything depending on how the measurement is done.
xpatUSA wrote:
PrebenR wrote:
Who measured that?
When I finally get my MC-11 I can test my sd q h against the A7rii. At any rate the A7rii will be my B camera
xpatUSA
There is an ISO 15739 standard for the measurement of digital camera DR. The well-respected Doug Kerr has a lot to say about it here:
http://dougkerr.net/Pumpkin/articles/ISO_Dynamic_range.pdf
It gets interesting from page 8 onwards, where he debunks the stated low level where the luminance SNR = 0dB; under that condition, two standard deviations of the normal distribution (+/- 3 sd) are actually negativebrightness ... a black hole so to speak.
So it is these days that the low level from which DR is determined is whatever Chuck Norris says it is ...
http://www.photonstophotos.net/Charts/PDR.htm#FujiFilm%20GFX%2050R,Pentax%20K-1,Pentax%20K-5%20IIs,Ricoh%20GR%20III,Sony%20ILCE-7RM2
TN Args
TN Args Forum Pro • Posts: 10,683
I agree. That is why it is not helpful to pop up here and just say a camera has a DR of ## in isolation. It is best to list cameras comparatively from the same DR test or test site.
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
