Smartphone camera vs Canon 650D with shocking result
Started Jul 17, 2017 | Discussions
Clara May New Member • Posts: 6
I compared photos from my smartphone Samsung Galaxy Note 5's camera against my Canon 650D with Tamron SP 17-50 mm F2.8 and was blown away by the smartphone doing significantly better.
First of all, the Note 5's camera on Auto seems to be able to get the correct exposure  the first time while I often have to fiddle with the Canon 650D's exposure compensation to prevent over-exposure.
Then, I notice that the Note 5's camera has a wider dynamic range than the Canon 650D. Its tiny lens also gives far better detail than my Sigma lens.
Compare the two photos I took of a morning scene. The sky was bright and I aimed just away from the sun. The Note 5 photo was taken on Auto. For the Canon 650D, I had to step down the exposure by -4/3 in P Mode to get some detail into the sky. If I step it down further, the rest of the scene will be too dark.
I am thinking of upgrading to the Canon 80D in the hope that it give me a big boost in picture quality but what do you guys think?
Image taken by Galaxy Note 5 smartphone on Auto
Image taken by Canon 650D with Tamron SP 17-50mm f2.8
Canon EOS 80D Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
Thevenin New Member • Posts: 22
Re: Smartphone camera vs Canon 650D with shocking result
Unless you perform a similar process as the smartphone did in this case, combining multiple exposures to create this image, you can never achieve the same dynamic range. Regardless from the type of camera.
photonius Veteran Member • Posts: 6,895
no, I don't think you will get such a huge "boost" in IQ going to the 80D, though the 80D is better.
A direct comparison between smartphone and a dSLR is also comparing apples and oranges. The smartphone will apply a lot more processing than what you get from the Canon out of the camera.
First exposure: take the image with the 650D, adjust exposure for the sky, and lift shadows in PP. In fact, I don't know if the Galaxy even applies some kind of HDR to capture the dynamic range?  P&S cameras and smartphones in general also apply more sharpening and saturation than dSLRs to generate more pop in the images. Then there is the difference in optics. The smartphone has a small lens with a very short focal length. This gives it more DOF at the same angle of view than a dSLR lens. Hence, a lot more landscape will be within DOF and therefore sharp. This is of course part of using a dSLR, that you have more control over your DOF, and you can get nice background blur with fast and/or long lenses. In order to compare this better, you would have stop down and use, for example, f11 or 16. Of course, that would require a longer shutter time.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
Ron777 Veteran Member • Posts: 6,871
That's what I was going to point out, I had a Galaxy Note 4 (so I'm sure the 5 also does this) but default is HDR using 2 images to capture a higher dynamic range. My iphone does that too, so in hard lighting the SOOC pics have better DR than my DSLR. If you have a DSLR that has HDR built in and use that, then you'd have better DR than the smart phone, and more resolution. (Or take multiple exposure and create an HDR yourself).
Try those shots again but turn HDR off in your phone, then the DSLR will have way more room for post processing than the phone pic.
Canon SL1 , Canon 450D, 18-55IS, 50mm F1.8, 70-300IS, Fuji X-S1, Fuji F200EXR, Canon S90
Olga Johnson Forum Pro • Posts: 24,360
In addition to what others have suggested,  I always lower the setting of Contrast in camera.
plantdoc Veteran Member • Posts: 4,339
I suspect that smartphones use various AI adjustments to try to create the most appealing image.
Greg
jebo1 Regular Member • Posts: 457
The results from the smartphone are indeed better! In the smartphone software, lens and camera are optimized to work together. In the Canon you have to do this all by yourself and the lens is not optimized for the camera. We life in times that you can get better or comparable results with small modern camera's compared to large old school dslr's. I have several Canon apsc dslr's and a panasonic fz 1000. The results from the panasonic are sometimes better! I use the dslr's more for the old school feeling than that I expect them to perform better.
 jebo1's gear list:jebo1's gear list
Nikon D200 Nikon D700 Nikon D7200 Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR +2 more
dpr4bb Senior Member • Posts: 1,418
Despite years and years of head start, traditional camera makers have now decisively fallen behind companies like Apple and Google in image processing expertise. That's why these smartphone cameras, with their tiny sensors, are punching way above their weight class.
Stan in NH
Stan in NH Senior Member • Posts: 1,898
5
I've used my iPhone for photos on many trips where I did not want to carry my dslr and lenses around with me.  The results are always excellent, because the in camera processing is optimized for these small cameras.  But, as good as the final image may look, they come with some serious limitations.
I have yet to see any smartphone camera that does very well in low light.  They also do not stand up well to cropping, and have very limited zoom options.  If you need a nice quality snapshot, these are great.  For any specialized work though, they leave a lot to be desired.
They have their "sweet spot," and if you stay there the output can be very impressive.  Get too far away from that, and they just won't cut it.
 Stan in NH's gear list:Stan in NH's gear list
Sony a6400 Sony a7R IV
Good post, spot on.
No matter how good the processing is in a smart phone, it can't overcome the physics of super teeny sensor size and a super teeny little lens. And my biggest issue.... no nice shallow DOF for subject shots!
Stan in NH
Good post, spot on.
I know the iPhone 7 now has a "portrait " mode which introduces a narrow depth of field to produce a blurred background.  I'm not sure if this is real or simply a blur process added to the image.  My guess is that it's done with in camera processing.  Other smartphones may offer a similar feature since no feature goes uncopied too long.
Good post, spot on.
Yes, true, it's not nearly as good as a fast lens on a DSLR, I have that in one of my superzoom P&S cams too , it adds a little blur, not bokeh, but a bit of blur. It's better than nothing, but a high res, excellent set of pixels with super nice bokeh vs a phone pic with massive NR and a little blur isn't even a contest for quality IMO.
Phone pics, uncropped at websize or 'phone screen size', with the super convenience of using the phone is what makes it so popular, I use my phone for snaps all the time. But if I want a nice photo, then it's DSLR time for me for sure.
ThrillaMozilla Veteran Member • Posts: 7,681
Here's the Canon shot reprocessed a bit.
Sky is overexposed, but shadows are better exposed than in the iPhone photo.
This was very hastily done. Some parts of the image are improved, but some are made worse. Of course I could have done it more carefully to improve all or most parts.
The iPhone photo is very good, but the phone may be at its limit. The camera is not. The iPhone combined exposures to achieve the result. The camera did not.
The sky was badly overexposed by the camera, but note that the shadows were underexposed by the iPhone. Take a close look at the noise in the brick wall and the foreground bushes, etc. Note also the color. The iPhone combined exposures and somehow avoided overexposing the sky. The camera is also either misfocused or there is camera motion, or the lens is soft.
The overexposed sky is because the camera metered off the dark center of the photo (you have options). It's possible that the phone did better because it metered from the whole scene. If you combined photos, you could improve the camera photo a great deal. Still, there's no denying the convenience factor. Excellent performance by the phone overall, but maybe not a slam-dunk.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
Digirame Forum Pro • Posts: 41,857
I think you could have taken a better photo with the Canon 650D.  Would you agree with that?  The shocking difference was not caused by either camera, but the photographer behind the cameras.
I really don't agree. It is shocking to see that a phone can produce similar and often better pictures than a dslr. You would at least expect the dslr to produce sharper pictures with it's  infinte larger sensor and lens but even that is obviously not the case. Imagine this person going on a holiday carrying his/her dslr stuff around and coming home with less results than his partner using only the phone. So my summary would be that in 2017 a phone produces better pictures for the average person not needing wide angle or telelenses. Now we are taliking about dslrs but would it be far off to state that a phone produces better pictures than compact camera's like the coolpix or powershot?
Man, I really don't see a better picture from the phone, I see an sooc image that has a closer to final tone/light, but a dslr image that's shot and processed right will destroy any phone camera image, even a good P&S will nuke an iPhone image.
If exposure and such were equalized and both used the same method (such as HDR), the phone image couldn't hold a candle to a large sensor's image.
As I already wrote in my post above, due to the larger sensor, you have an issue with DOF. In fact, many times it is desired that you can control DOF with a dSLR. With a small sensor, usually everything is within DOF, thus the image appears sharp throughout (see bushes in the front left where phone is clearly better). Thus, the dSLR would have to be stopped down further, which would improve DOF an probably overall sharpness. As we all know, pixel sharpness depends on the lens used, and not all lenses on dSLRs give maximal resolution. There is still room for improvement in post processing.
Where the smartphone clearly has the advantage is that it can use a lens that is optimised for the small sensor, and most likely, all kinds of corrections are done on the image (CA correction, vignetting correction, etc. etc.). These software corrections can of course be optimised for the phone, since it's a fixed lens/sensor combo, something you cannot do with a dSLR. To get optimal images you would have to take an image in RAW, expose properly, stop down more for DOF, probably use a tripod to remove any shake with slow shutter speeds, since you have a small aperture now. Then do post processing, first use a tool that removes lens aberrations, then process it is for optimal look.
And yes, compact cameras with fixed lenses should be able to achieve similar results, maybe the software is not as good.
But in the end, for a user that doesn't want to go into all the technicalities, a smartphone for a selfie/snapshot is probably the better choice.
Stan in NH
There should be no question that any modern dslr can outperform a smartphone or point and shoot under similar circumstances. The OP's original shots don't show this, in fact they weren't even taken at the same time  ... two minutes apart ... so the lighting may have  changed between shots.
A better comparison would be not only jpeg to jpeg, but one which used the dslr's built in presets, which let the camera optimize settings for a given situation. Then, shooting at the same time, we can see what the in camera processing does with each sensor. For a true comparison, we can then crop the images and do some pixel peeping to see what's really there. One should not have to shoot raw, then post process and convert to jpeg in order to replicate the apparent quality of an instant smartphone snapshot. I shoot both raw and jpeg, and the vast majority of my out of camera jpeg shots are much better than anything I can get from any of my p&s cameras or smartphones. Yes, I have done some excellent work with non-dslr cameras, but I recognize their limitations and sweet spots and adjust my work accordingly.
I also know that many people just take pictures, and have no interest in photography. They just want to document and share, and have absolutely no concept of the art of photography. That's fine, and those people are well served by their smartphones which, at this point, have become the compact camera of choice. The claim that a smartphone is somehow a "better" camera than a dslr, however, falls into that general category of alternate facts.
photonius wrote:
As I already wrote in my post above, due to the larger sensor, you have an issue with DOF. ...As we all know, pixel sharpness depends on the lens used, and not all lenses on dSLRs give maximal resolution....
An f stop of 7.5 would have given the same field of view. The f/5.6 that was set was probably adequate, but one more stop would have been more would have sufficed for sure. I think the problem is that nothing is really sharp in the photo. I think the problem is either camera motion or lens sharpness.  The phone used a very fast shutter speed, which is why it underexposed the picture.
Where the smartphone clearly has the advantage is that it can use a lens that is optimised for the small sensor....
The lens is shown as 17-50 mm, which is not a Canon lens as far as I know.  But it is probably an EF-S lens, which presumably is optimized for small sensor.
To me, an analogy would be someone making two dinners, one is a frozen TV dinner the other they cooked themselves and compared. The TV dinner was better. This doesn't mean frozen TV dinners are better than home cooked meals, just that if a person doesn't have the right ingredients and can't cook a better meal, in those cases the frozen dinner might be better. But if one learns to cook/prepare a meal, it will always be way better than a frozen TV dinner.
I'm really sure Ansel Adam's photos would not have been better if he used an iphone instead of his camera, nor would I want to see a wedding photographer show up with an iphone instead of real camera gear.
