Water Damage to Exposure Meter Locked
Started Jul 14, 2017 | Discussions
This thread is locked.
Andrew Schwartz New Member • Posts: 18
Hey All,
I bought a K-3 ii for aggressive use about 6 months ago.  Had a great time taking it hiking and sailing, but then one day cracked the viewfinder glass while clambering across a rock-face.  It took a bit of work to track down a repair company that could actually get Pentax parts, but 2 months and 300$ later it seemed all good.
A week ago, I found myself motoring happily in light rain from Avondale RI to Mystic CT, taking photos using my newly repaired K-3 ii and a 16-85 WR lens.  All good, but then the rain picked up and I anchored for a few hours in a sheltered cove.  Upon starting up, I thought to take a few photos of the nice cove --- and my camera went bonkers.  It took a bit of time to guess what had happened, but then realized that there was condensation on the viewfinder and immediately turned off the camera.  After a few days of drying, started everything up and found that the exposure meter doesn't work in viewfinder mode.  Everything else seems to work as normal, and in particular the exposure meter works fine in liveview mode.
So in any case, I'm using the camera now to practice the art of manual exposure estimation.   Not the end of the world, but kind of painful when just trying to take a quick photo before running aground.
I read statements about how the Pentax zoom lenses, despite being marked as WR lenses, pull water vapor into the camera.   Or alternately, the viewfinder fix might have left the camera unsealed (though it wasn't raining that heavily).  Does anyone have any other thoughts or ideas?
Happiness,
Andrew
Pentax 16-85mm F3.5-5.6 WR Pentax K-3 II
jamesm007 Veteran Member • Posts: 5,820
Re: Water Damage to Exposure Meter
Andrew Schwartz wrote:
Hey All,
Happiness,
Andrew
The repair company probably left out a seal and or did not place them properly. I have been using them for a long time now. Not saying this as a fanboy (although I am). But they are pretty reliable. Notice no water got in until the day the camera struck something and needed repair.
Hope all goes well.
 jamesm007's gear list:jamesm007's gear list
Pentax K20D Pentax K-5 Pentax K-3 Sigma 10-20mm F4-5.6 EX DC HSM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +12 more
OP Andrew Schwartz New Member • Posts: 18
Thanks!  The previous repair was done by Precision, who give a 90 day warranty.   The camera is back with them, and we'll see how it goes.
I liked my Pentax when it worked, but am definitely off the brand by virtue of after-sales support.
Happiness,
Andrew
Hey All,
Happiness,
Andrew
Hope all goes well.
arkady_z New Member • Posts: 22
Hi! I've had the same problem.. Although my camera wasn't in service before.. Posted on another forum:
"I was shooting under the moderate rain with K-3II and DA16-85. After a couple of hours exposure meter of the camera stopped working. Actually it was not very active shooting - I've taken just a dozen of pictures. I took the camera to authorised service center and reply I got from them embarassed me:
"The cause of the malfunction was the liquid entering the internal components of the camera.
K-3II does not have a design regulated by JIS and / or IP standards, therefore it is not sealed, so it must be protected from rain and splashes.
Based on the above facts, it can be concluded that the malfunctions identified during the diagnosis are not classified as production flaw. Camera repair is not possible under warranty."
Thank you very much: that was a very informative thread and our scenarios seem very similar.  Will wait to hear back from the repair people, but am guessing that the problem was lens/camera combination rather than an error during the repair.
This was my first DSLR and in retrospect buying a Pentax for durability was a mistake.    Next time, will likely go for a smaller, more easily protected mirrorless camera.
GPGeneralPhoto
GPGeneralPhoto Senior Member • Posts: 2,157
I believe that your camera was not sealed properly during the repair. Having taken Pentax DSLRs apart for repair, I noted that the seals are small and seem to be greased and are very difficult to reinstall correctly. I can see that it would be easy to get a misalignment of the seals. Getting the repair center to admit this seems a long shot, though you could ask. I used a K-5IIs through a tour of Niagra falls and despite being soaked in the mist, the camera performed, and continues to perform as intended by Pentax.
I'm thankful to still be able to...
 GPGeneralPhoto's gear list:GPGeneralPhoto's gear list
Canon PowerShot SD400 Pentax K-01 Pentax K-5 IIs
There is no grease on the seals. The sealing is industry standard foam, silicone and rubber. The tech does not have to align many seals as most are part of the body and structure. Sealing is not a science in the works. Its a well known art if you don't take short cuts. Pentax IMO takes no shortcuts sealing bodies. I have never seen any leaking trend in almost ten years of tracking and sometimes reading in depth this forum. Just do a deep search on each forum to prove to yourself overtime which have done well or not.
BobORama
BobORama Senior Member • Posts: 2,842
What?
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
BobORama
What specifically do you mean?   Is the metering merely inaccurate?   Severely over or under exposed?
Metering in live view is accomplished by the image data read directly from the sensor.  Metering in TTL is does through a small sensor located approximately above the view finder above and behind the pentaprism.   So water entering around the eye piece could have created a problem,  but as the sensor is a sealed IC package, I have a hard time believing that this did not dry out which would restore function.   Just condensation should not cause permanent damage, IMO.
Interesting.  I still haven't heard anything from the repair people, but must admit that I'm tending to the theory that water came via the DA16-85.  In any case, the answer to your first question is that the exposure meter is completely toasted --- pretty much independently of the amount of light, it sets exposure a the 30 second maximum.  Which was very confusing at first because it seemed instead that the shutter had malfunctioned (the shutter would open and I'd give up well before it closed).
Happiness,
Andrew
GPGeneralPhoto
I worked on a K200D, maybe newer models use different seals, but I remember the greasy seals in the K200D. You can see dust that has stuck to the seal in the pic.
Re: Seals are dry...
A seal collecting dust is not greasy. There has never been grease applied for weather sealing on any Pentax dSLR camera. I own the K200D brother the K20D. The build concept is the same with both.
I think we might be using the word for different meanings. Grease on a body seal, really any seal would push out the joint and cause a mess. It would collect tremendous amounts of debri. And just isn't needed in non moving parts in a camera. The only place there is grease in Pentax Digital SLRs is the Mirror Box assembly and its gears. Usually small amounts on gears here and there. There is also a very small dab in the edials. Not for weather sealing. But on the little clicking ball bearing to help keep it smooth through the years.
I can believe a seal being sticky, but just sticky not greasy.
Here is a small collection of Pentax service manuals to enjoy. The password is also with the downloads (8639).
http://www.pentax-hack.info/documents/downloads.html
