Canon EOS 350D - LCD Viewer
Started Jul 12, 2017 | Questions
acrowe New Member • Posts: 18
I have owned this camera for a number of years but have not used it for a while and recently picked it up to use.
I am unable to view images previously taken as the LCD viewer does not load when pressing the play button (this has worked previously). At first I thought this may be to do with low battery so I fully charged and tried again. The next time I put the battery in after charging this then worked, although ever since it has failed to do so. I have explored different options. E.g. reset to factory settings from the camera menu. The firmware seems to be up to date. The button does not appear damaged and the surrounding buttons all work fine.
I cannot seem to see a setting in the unit that allows me to turn the LCD screen on/off. When taking photos and looking at the pop up image this is also fine. I am also able to delete that image as well if I wished to do so. I yesterday connected my camera to my computer to back up my photos which also worked perfectly. Wondering if anyone else has had a similar problem?
Many thanks,
 acrowe's gear list:acrowe's gear list
Canon EOS Rebel T6i Sigma 10-20mm F3.5 EX DC HSM Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF 50mm F1.8 STM
Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N)
deanimator Contributing Member • Posts: 719
Re: Canon EOS 350D - LCD Viewer
Have you gone through the menus?
I've also got a 350D which I no longer use. Isn't there a menu setting for "Preview" or "Image Review"?
Try this:
Image Preview
Lemming51
Lemming51 Forum Pro • Posts: 15,278
I am unable to view images previously taken as the LCD viewer does not load when pressing the play button (this has worked previously). At first I thought this may be to do with low battery so I fully charged and tried again. The next time I put the battery in after charging this then worked, although ever since it has failed to do so. ...
If you want to continue using this camera, I'd buy a new battery.  The battery ages, even without use, and will no longer deliver enough power even when "fully" charged.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
OP acrowe New Member • Posts: 18
Unfortunately there doesn't seem to be a menu setting for this model.
I thought that could be the case, I will have a look around and try this out. Thanks!
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
Batteries, plural. In addition to the big rechargeable NB-2LH battery, there's a CR2016 "button" battery, rated for 5 years use (see page 38 of the XT/350D manual). If the CR2016 starts running down, the camera can behave bizarrely.
The CR2016 is in the battery compartment, next to the NB-2LH battery.
Some camera settings, notably date and time, will be lost when you pull out the old CR2016. You'll have to reset them when you put the new battery in.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
Ah great, I'll replace that too. Many thanks
Unfortunately I have now replaced both batteries and still the viewer does not work when pressing the button. I have emailed Canon previously who advised to send it off although as i'm considering a new purchase this seems like a long winded way if doing things and prevents me from using the camera.
Give this a shot:
Reset EOS 350D
Unfortunately this did not work either. Thank you
