Fujifilm XF 50mm f2.0 WR Reviewed vs 56mm f1.2 Locked
Started Jul 11, 2017 | User reviews
This thread is locked.
Lobbamobba Contributing Member • Posts: 514
The difference in aperture and therefor lowlight and shallow depth of field is obvious and goes without saying.
I was more interested in their performance for street photography and for my style of aesthetics.
Pros 50mm:
  • Small and light (the 56mm needs at least an XT1 for balance imo)
  • Cheaper
  • Faster
  • Smaller filter needed
Pros 56mm:
  • f1.2
  • Mojo
  • Better filter size for video
Cons both:
  • Brittle metal in the rings
Video Review
Here is a video review with more comments and plenty of samples:
https://www.youtube.com/watch?v=Wn1VLCDq2w0
Samples
The 50mm f2.0 on the X-T2
The 56mm f1.2 on the X-Pro2
Fujifilm XF 50mm F2 R WR
Prime lens • Fujifilm X
Announced: Jan 19, 2017
Lobbamobba's score
4.0
Average community score
4.7
Fujifilm 50mm F2 R WR Fujifilm X-Pro2 Fujifilm X-T1 Fujifilm X-T2
HeavyDuty Veteran Member • Posts: 3,036
Re: Fujifilm XF 50mm f2.0 WR Reviewed vs 56mm f1.2
Re: brittle metal used in construction - have you had a problem with lens breakage?
Ken in Illinois
Railroad Action: http://www.pbase.com/kjford
Candids: http://www.pbase.com/kjford/other
 HeavyDuty's gear list:HeavyDuty's gear list
Nikon Z9 Nikon Z 24-70mm F2.8 Nikon Z 70-200 F2.8 VR Nikon Z 14-24mm F2.8 Nikon Z 50mm F1.2 +15 more
OP Lobbamobba Contributing Member • Posts: 514
Not breaking completely but the focus rings on fujis and Sonys tend to get a bit out of shape without any force applied.
Leads to a scraping sound when turned. Annoying for stills, bad for audio.
celestialemissary
celestialemissary Contributing Member • Posts: 795
As soon I saw that dog I knew it was you, Mattias.
 celestialemissary's gear list:celestialemissary's gear list
Ricoh GR Digital IV +1 more
Peter Foiles
Peter Foiles Senior Member • Posts: 2,389
I don't think "brittle" is the term you are looking for. The definition is "hard but liable to break or shatter easily" What you describe is metal that is maybe a bit too malleable.
 Peter Foiles's gear list:Peter Foiles's gear list
Sony a1 OM-1 Fujifilm X-H2S Fujifilm X-H2 Sony a7R V +23 more
Brittle is another word for fragile as well. But its all good, call it what suites you the best
michaeladawson Forum Pro • Posts: 18,315
If you are talking about something like "brittle emotions", perhaps.  In the area of material science (e.g. metals) brittle has a very specific meaning.  It does not mean "bendable" or "deformable" or "malleable".
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
Im not exactly the first to use the word so I think it will be fine. Languages evolve.
But thanks for taking the time to explain
fcracer Senior Member • Posts: 1,632
If your goal is to communicate your experience with the product to give people a sense of what to expect, then common language should be used. I'm with Michael in that I got the wrong impression by your use of "brittle". Languages do indeed evolve, but I've never seen "brittle" substitute for "deformable" in a metallurgy context (actually can't think of it doing so in any other context as well).
Instagram: fcracer
Flickr: fcracer
 fcracer's gear list:fcracer's gear list
Fujifilm X100V Fujifilm X-Pro2 Fujifilm X-T4 Fujifilm GFX 100S Leica M11 +19 more
Thats dynamite, I would have thought by now you knew that I politely and respectfully don't care. So no point in discussing this with me. But feel free to talk among yourself
synonyms: breakable, splintery, shatterable, fragile, frail, delicate, frangible;
bowportes Veteran Member • Posts: 4,337
If you politely and respectfully don't care, why do you keep trying to make your case?
The first three synonyms are material qualities while the last four are more figurative, pertaining to emotion or temperament.  Were you suggesting that the lenses are emotionally fragile or materially breakable? Which was it?
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro3 Fujifilm GFX 50S II +15 more
Peter Foiles
If you go to the trouble of looking up the synonyms you apparently care at least a little bit and none of them accurately describe the problem below:
"Not breaking completely but the focus rings on fujis and Sonys tend to get a bit out of shape without any force applied."
A couple of problems here. First, if the rings do indeed get out of shape without any force being applied that would be an interesting problem. Much more likely is that force is being applied when the lenses are mushed about in camera bags and the rings become deformed.
Second, the not breaking part is pretty much the opposite of brittle or any of the other synonyms you list and is leading to the confusion I and others have pointed out.
You may not care about this thread but presumably you do care about the issue being addressed. If you complain to Fuji and Sony that their rings are brittle they will attempt to correct the problem by making them not brittle, that is more bendable or malleable which will make the problem you describe worse not better.
I see that you live in Sweden, many/most Swedes speak English reasonably well but if not a native English speaker you may not be familiar with the precise definition of technical terms and that is perfectly understandable.
Paulaner_RRS Regular Member • Posts: 288
The term Brittle is very well defined, likely to crack or rupture before plastic deformation occurs.
You are using it in totally the wrong context, see the previous 2 replies.
 Paulaner_RRS's gear list:Paulaner_RRS's gear list
Fujifilm X100V Fujifilm GFX 50S Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +6 more
Not really, they feel like they are going to shatter at any time = brittle.
I just answered what problems actually had occured.
But either way, I dont care. Word police are my favorite people to have a friendly banter with and its a gorgeous summer night. Its all good
eric333 Senior Member • Posts: 1,434
So you've actually bent/broken an aperture ring on a Fujifilm lens because of the brittleness you describe?
Which lens? And can you post a photo of the damage?
I've been reading this forum for a while and I've never heard of such a thing.  I'm not saying it didn't happen but I'd be interested to know how it happened and under what circumstances.
It wouldn't show on a photo. But you can hear it.
Same thing happened with the Sony/Zeiss 35mm and Fuji X100t.
Im sure most wont notice since they use AF and some dont care (I can live with it,). Its just a shame imo that such expensive lenses are made from such brittle metal. Might as well use plastic then..
Voigtlander are one of the few still sticking to proper metal. For some reason I haven't experienced the same issues with Panasonic or Olympus. And of course not in Canikon who use plastic for the most part.
EugeneC Regular Member • Posts: 483
No point in carrying this any farther, the mob has spoken. You are guilty of using the word brittle instead of malleable in a language that is secondary to you. How silly, I knew what you meant as soon as I read it. Thanks for the review.
 EugeneC's gear list:EugeneC's gear list
Fujifilm X-H1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro Sony FE 55mm F1.8 +8 more
No there isn't any point. One of the things that bothers me a lot with forum behavior (not just DP Review, but all on-line chatter) is the inability of people to just admit they made an error and move on.
The OP is clearly wrong in his usage of the word "brittle" when using it to describe characteristics of metal. Rather than recognize and simply admit that it is not the correct word and move on, he has to try to prove that his usage of the word is correct. He goes on to label those that point out his mistake as word police and continue in his use of the word.
Ever read "Through the Looking Glass"?  “When I use a word,” Humpty Dumpty said, in rather a scornful tone, “it means just what I choose it to mean."
At this point who actually cares about his lens comparison?
Mike Dawson
Greg7579
Greg7579 Forum Pro • Posts: 14,044
What? Huh?
What the Hell are you guys talking about?
I have all the Fuji lenses except the brick and I have never noticed whatever it is you are talking about.
I'm so confused.... Is my 50 F2 as good as I think it is or not?  Brittle?  Malleable?  Huh?
No comprendo Baby....
 Greg7579's gear list:Greg7579's gear list
Leica Q2 Fujifilm GFX 50R Fujifilm GFX 100 Fujifilm GF 32-64mm F4 Fujifilm 120mm F4 Macro +8 more
