ep5 usb wire question
Started Jul 8, 2017 | Discussions
eclipsechaser1 Regular Member • Posts: 360
Well I cant find my oly ep-5 camera lead. I tried a few standard USB leads but couldn't get it to fit. Now before I go an push a little harder or try and stretch the sides of the port a little I thought I would check if there is anything special or non standard about the oly lead.
Thanks in advance.
 eclipsechaser1's gear list:eclipsechaser1's gear list
Olympus PEN E-P5 Olympus E-M1 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 17mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH +3 more
Olympus PEN E-P5
Elmokki Regular Member • Posts: 276
Re: ep5 usb wire question
Yes. It is a proprietary cable that supports A/V output. Do not try to force a standard mini or micro usb cable in.
 Elmokki's gear list:Elmokki's gear list
Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 12-35mm F2.8 +3 more
wolfychi Senior Member • Posts: 1,158
I bought a remote shutter release recently, found the mini USB a bit tight, so I grinded all the sides of the cable's mini USB on fine sand paper a bit, now goes in and out easily, works fine. do make sure you clean the dust off the plug thoroughly before using.
