Samsung 16mm 2.4 on NX1
Started Jul 7, 2017 | Discussions
baksteen1 New Member • Posts: 7
Hi, I've been using my NX1 for almost 1 year now and I absolutely love it. I have used it for some commissioned projects, NX1 + 16-50S.
The only issue I have with this setup is that I barely carry it with me for my daily street pictures. The 16-50S is way too big and heavy.
I have looking to get a new body (Fujifulm X70) or getting a pancake lens such as the 16mm 2.4 (the desired 28mm equivalent). The 16mm 2.4 will only be used as street photography lens.
Have any of you used the 16mm on the NX1? Do you recommend me to get a X70 for an 'all-day' camera? My NX1 lifespan would perhaps be longer if I get a second body.
Fujifilm X70 Pentax X70 Samsung 16-50mm F2.0-2.8 Samsung NX 16mm F2.4 Pancake Samsung NX1
wpstl Senior Member • Posts: 1,251
Re: Samsung 16mm 2.4 on NX1
I use the 16mm on my NX1; it's a very good lens. But it's not a 28mm equivalent; it's 24mm. Maybe that's not a big enough difference for you but it is quite a bit wider. The 20mm pancake lens comes closest to the 28mm equivalent (30mm).
"Sometimes I like to throw a grenade and run away."
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
OP baksteen1 New Member • Posts: 7
My bad,  making mistakes with basic calculating hah.
Do you have any experience regarding the 20mm? it's sad that it's F2.8 instead of the 2.4 of the 16mm.
The lens is almost the same price as a second hand Fuji X70, I'm leaning towards the Fuji now.
I'm a fan of all the NX pancake lenses. The 20 isn't as nice as the 16mm but it's more than adequate. The problem is finding one at a reasonable price these days.
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
It is a great combo.
For me it is the same; for these purposes I like the pancake lenses - especially on the NXx00 cameras.
Either choice could be a lot of fun for you, I'm guessing. One advantage for the NX combo is that it would be wider when you need that and the 28mp's to work with gives you the opportunity to crop to the 28mm focal length of the 16mp X70 and still have more mp's to play with.
I have had both the 16 and 20 mm pancakes since they first came out. They have been used on 6 different NX cameras from the 14mp NX10 to the 28mp NX1/500. With each increase in mp's and improved sensor as they developed the camera line the 2 lenses have produced better output with each step.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
VisualFX
VisualFX Senior Member • Posts: 1,241
Samsung 16mm pancake is going to be wide for street shooting. Is that what you want? Maybe try the 30mm pancake and see if you like that FOV.
I have used samsung 30mm, and also Pentax-M 28mm f/3.5 which is equivalent to 42mm FOV.
 VisualFX's gear list:VisualFX's gear list
Fujifilm X-E3 Fujifilm X-E4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR +4 more
norman shearer Senior Member • Posts: 1,418
I use the 16mm pancake on my NX500 for street - it's the best match I've found so far. I zone focus and shoot from the chest. I also have the 20 nad 30mm pancakes but find the 16mm easiest to use.
 norman shearer's gear list:norman shearer's gear list
Samsung EX2F Nikon Coolpix A Sony RX1R Canon EOS 5D Canon EOS 5D Mark II +10 more
