Value wide angle prime: Rokinon 12mm - Any alternatives?
Started Jul 3, 2017 | Discussions
FTOG Senior Member • Posts: 1,359
Hi everyone,
it has now been a bit over a year since I returned to digital with an X-E2, a 27/2.8 and later a 18/2.0.
After the release of the 23/2.0 WR, I could only fight off my GAS for so long until I caved.
Now I am extremely pleased with the 23mm's performance, and happy to have a 35mm equivalent.
However, 27/2.8 and 18/2.0 see very little use now. Both are too close to the 23mm and will have to go. I have adapted Olympus OM glass between 24mm and 135mm, however nothing wider than that.
Which leads me to my "problem": What to replace the 18mm with?
  • I have considered adapted manual lenses, but anything shorter than, say, 18mm vintage glass is often either a fisheye and/or expensive due to it being an ultra wide lens on FF.
  • Obviously, there are 16/1.4 and 14/2.8, but wide angle photography isn't my main focus and I am a pure hobbyist, so at 900-1000 EUR they sit well above what I am willing to spend. (This also eliminates the Zeiss Touit 12/2.8)
  • Which leaves the Rokinon/Samyang/Walimex 12/2.0 as the hottest contender. Reviews I found were very positive: It's sharp, it's small, it's light and it's very affordable.
So is the Rokinon 12mm as much an uncontested winner as it appears to me?
Thanks for your input!
F
PS: I have heard rumours about a remake of the 18mm being in the works at Fuji. But even if and when that arrives, it will be rather close to the 23mm.
 FTOG's gear list:FTOG's gear list
Fujifilm X-E3 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR +2 more
Sjak
Sjak Veteran Member • Posts: 7,318
Re: Value wide angle prime: Rokinon 12mm - Any alternatives?
In my recent thread, the Rokinon 12 2.0 is also discussed:
https://www.dpreview.com/forums/thread/4174979
I found a newlike for 290 euro on the german Amazon. Seems hard to beat, looking at the alternatives at around 12mm FL.
Nokinon/Samyang/Walimex/whatever other branding it may sell also have 10mm and 8mm options.
I do agree that the 18mm FL seems pretty close to the 23mm, the exact reason I also went for something significantly wider.
Re. the 27 2.8: it is a convenient lens for a more stealthy and/or pocketable setup. For this reason, it is a keeper for me. And it's resale value (at least here) is not impressive. But for me, it complements the quite large (and expensive) 23 1.4. Maybe it is less of a consideration to you.
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
OP FTOG Senior Member • Posts: 1,359
Thanks for pointing me to your thread, I will have a read through that.
You also raise some very familiar points indeed. I would be surprised if I missed a blatantly obvious alternative to the 12mm.
As for the 27/2.8, it is a fine lens and indeed very compact. However, I don't find myself using it at all, since i got the 23mm. I am not ashamed to admit that when I need something pocketable, in many circumstances my phone will do (with all its obvious shortcomings). And if I have some carrying capacity, I will usually be able to accomodate the X-E2 w/ 23mm.
Rod McD Veteran Member • Posts: 8,589
Hi,
Yes, I suspect that when you factor in price, the Samyang 12/2 is a winner.  I wouldn't adapt UWA FF lenses.  Another contended might be to buy a used Fuji 14mm or 16mm to lower the impact on the budget.
Quite apart from price, may I suggest being very careful about choosing your FL.  There is a significant difference between each of the 12, 14, 16 & 18mm FOVs.  I wouldn't buy the 12mm on the grounds of price unless you know you like that FOV.  It's extremely wide.  I actually sold my 14mm and bought the 16mm because of exactly that problem.  Ie,  the 14mm was just that bit too wide for my preferences.   (That's most of the time.   I do miss it occasionally, but wasn't prepared to carry both all the time).  I find the 16mm a sufficient step wider from the 23/1.4 to be useful.  (NB The 23/2 is wider than the 23/1.4 - all the side by side posts indicate that it has a wider FOV - may be more like a 21mm lens... which might explain its closeness to your 18mm.)
Regards, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Unless you need that extra 2mm, another option is to wait for one of Fuji's lens sales where the XF14 is nicely discounted.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Rod McD wrote:
Quite apart from price, may I suggest being very careful about choosing your FL. There is a significant difference between each of the 12, 14, 16 & 18mm FOVs. I wouldn't buy the 12mm on the grounds of price unless you know you like that FOV. It's extremely wide. I actually sold my 14mm and bought the 16mm because of exactly that problem. (NB The 23/2 is wider than the 23/1.4 - all the side by side posts indicate that it has a wider FOV - may be more like a 21mm lens... which might explain its closeness to your 18mm.)
Ha! Very interesting note on the 23mm's capture angle. I would've never considered it.
As for the focal length, a very valid point indeed. The wider, the more critical will be to nail the horizon and vertical lines etc. I do wonder if a used 14mm would be an alternative.
maxxxx Senior Member • Posts: 1,179
To me the Rokinon 12 is a no-brainer. Good IQ, small, cheap. Great for astro.
 maxxxx's gear list:maxxxx's gear list
Sony a7 IV Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Tamron AF 28-200mm F/3.8-5.6 XR Di Aspherical (IF) Macro Sony FE 200-600 F5.6-6.3 Tamron 70-180mm F2.8 Di III VXD +1 more
