New Fuji Lens for newborn
Started Jun 29, 2017 | Discussions
Mons1eur New Member • Posts: 4
Hi,
I know this is very early but my Mrs is expecting and we are planning for our first born's arrival next year. So after becoming a soon to be daddy I somehow have managed to convince my wife to to let me buy a new lens to take those awesome photos for our child.
I have an X-T10 with an 18-55. I am not a pro but like I have learnt a lot with this setup. I have been looking at Fuji's XF 90mm F2 R LM WR.
Just wondering what the guru's of dpreview think about the best lens for a newborn to go along with 18-55 or if that is enough?
TIA
Fujifilm X-T10 XF 90mm
colombiano
colombiano Contributing Member • Posts: 696
Re: New Fuji Lens for newborn
18-55 is not enough. You don't want to use flash on a child on first days/weeks when he/she comes out and with slow 18-55 you would have to use flash.
I propose 35mm prime, either 1.4 or 2.0. Some will advise 2.0 version because of presumably faster focus but my advice is 1.4 because 1 stop more of light can make a difference and in low light 1.4 lens focuses quicker than 2.0.
And also, 56mm f1.2 is excellent for portraits, but more expensive.
23mm primes distort too much "small objects" (baby or baby's face), so don't buy it.
If you'll buy just one, get 35mm f1.4. But if you can persuade your wife to buy you two lens, than add 56mm f1.2 also
TomasT Regular Member • Posts: 320
35mm 1.4!
 TomasT's gear list:TomasT's gear list
Ricoh GR II Fujifilm X-S10 Fujifilm 50-230mm II Fujifilm XF 23mm F1.4 R LM WR +3 more
Camnu Regular Member • Posts: 213
While the 90mm is great, I doubt it's a good fit here since it might be hard to shoot at that focal length indoor. You need a lot of space.
As for the 56mm, it's a great lens too, but I find it's hard to have a close-up shot. For the baby, I love the close-up shot on his/her hand, foot, eye, belly button, etc. The minimum distance between the lens and the subject is quite high. Moreover, it's too slow to focus. And this lens is expensive.
You might consider the macro 60mm f2.4, or the 50mm, or the 35mm. The prime 18mm and 23mm are bit short for portrait.
Stflbn Veteran Member • Posts: 3,733
I'd suggest the 35 1.4
It would be a great low light option for you.
Newborn faces are very forgiving and dont require longer focal lengths to avoid distortion of noses and such, and it will be some time before you have to worry about running around chasing for photos.
It's a very nice all around creative tool with it's 50mm equivilent,  close focusing,  and nice bokeh.
Fuji X-T2 | 16-55 2.8 | 50-140 2.8 | 35 1.4 | 56 1.2
Roboshoot MX-20+/RX-15/RX-20 | EF-X500 Flash | Yongnuo 568EX
http://501concepts.com
 Stflbn's gear list:Stflbn's gear list
Sony RX100 V Sony a6500 Sony a7 III Sony FE 55mm F1.8 Sony FE 28mm F2 +9 more
brew1brew Senior Member • Posts: 2,067
I say the 35mm f2.0, all of the xtrans III sensors can do 1600 ISO with low to no noise. the faster focus will come in handy when the baby starts moving. Also the super narrow DOF at 1.4 will be difficult to capture in focus when the baby is on the move. just my $0.02!
Les
anthisphoto.smugmug.com
 brew1brew's gear list:brew1brew's gear list
Pentax K-3 Fujifilm X-T2
drewmey123 Regular Member • Posts: 248
I would stay away from the 90mm if you primary interest is photography a newborn at the moment. Although it is great for portraits, I don't think it is great for this kind of portrait.
Keep in mind that a little baby/newborn can't stand up You will be taking pictures looking down at him/her. Probably mostly between a 90 and 45 degree angle. 90mm is just too long unless you want to be a on a ladder!
I would suggest a 23mm if he/she is going to be on the ground (you on your knees) or a in a crib (you standing). You could probably go up to the 50mm/56mm if you were going to stand while your baby was lying on the ground. I would say the 23mm f2 or 35mm f2.
 drewmey123's gear list:drewmey123's gear list
Fujifilm X-T2 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 16mm F1.4 R WR Fujifilm XF 35mm F2 R WR Fujifilm 50mm F2 R WR
colombiano
6
You can always stop down from 1.4 to 2.0 but can never open up from 2.0 to 1.4
shakenmartini Regular Member • Posts: 348
Mons1eur wrote:
Hi,
TIA
The 90 mm f/2 is too long for a newborn. I use the 56 mm f/1.2 with my newborn and can just barely make this work within the confines of a pretty large living room and a large nursery.
I have the 56 f/1.2 and 23 mm f/2. I use both extensively with my newborn.
I have been experimenting with this lens side-by-side with my Nikon FF gear and I am very impressed with the quality of the 56 mm for newborn portraits. It helps a lot that the X-T20 is easy to carry around.
I am considering one of the 35 mm lenses, likely the f/1.4 since the 23 mm is a touch on the wide side for a newborn. The only issue is the that f/1.2 and f/1.4 lenses focus a bit slower than the new f/2 lenses. The f/2 lenses are near instant. The older ones take a split second or two longer to initially grab focus. Once you have the initial scene in focus, the subsequent focus is easy to get. But, focus is slower than the f/2 lenses.
The quality of the f/2 lenses is very high. I don't often open the aperture beyond f/2 since the DOF is to shallow even for a newborn.
 shakenmartini's gear list:shakenmartini's gear list
Nikon D810 Nikon D750 Nikon D7200 Fujifilm X-T2 Fujifilm X-T20 +15 more
eliehbk Senior Member • Posts: 2,762
My favorite lens for my 7 months old (don't move much yet), is by far the 56mm
ons1eur wrote:
Hi,
TIA
 eliehbk's gear list:eliehbk's gear list
Leica Q2 Leica M11 Leica Summilux-M 35mm f/1.4 ASPH
321estrellas Regular Member • Posts: 491
I would vote for the 35mm f2 or 50mm f2.
The 35mm f1.4 is a great lens but the slower AF might frustrate you when the baby starts moving more.
On the same note, if you used a 90mm on a baby that's starting to move, crawl, and walk, he/she will move out of focus very quickly! You will then want a new lens after 6 months.
 321estrellas's gear list:321estrellas's gear list
Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F2 R WR
elfroggio
elfroggio Veteran Member • Posts: 3,228
Here's what you could do, with real birth photos
http://f16.click/gear/shooting-day-in-the-life-story-with-f2-lenses.html
http://www.sritch.com
The Dogs of Vancouver, BC
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
TomasT wrote:
35mm 1.4!
Would be my first choice followed by the 56 f1.2.
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Quayton New Member • Posts: 8
ons1eur wrote:
Hi,
TIA
I'm in a similar boat (new baby arriving soon). My spouse won a new x-t20 for me, which replaced an 11 year old Evolt-500 (which I loved) about a month ago, but our budget won't stretch to get anything beyond the included 16-50 that was included with the camera.
I was considering the Yongnuo YN 50mm f/1.8 and a FotodioX Canon EF to Fuji adapter, which would total around 120 bucks for a fast 50mm, albeit with manual focus.
Although that might seem like a crazy expenditure to get a manual lens, I've read good things about the yongnuo 50mm.
 Quayton's gear list:Quayton's gear list
Fujifilm X-T20 Fujifilm 16-50mm F3.5-5.6 II
Quayton wrote:
ons1eur wrote:
Hi,
TIA
The kit 16-50 lens will be much better than this setup. You'd be better served to save a few $ and buy the 18-55 2.8-4, or a used f/2 prime lens than wasting $120 on this setup.
LexMi Regular Member • Posts: 125
23 f/1.4 all the way. Anything longer forces you to be far away from your baby. If he was standing, that would be OK, but since he is mainly flat, and I cannot fly, the 23 (or wider) is what works.
 LexMi's gear list:LexMi's gear list
Fujifilm X-H1
Bisonbison
Bisonbison Contributing Member • Posts: 683
Mons1eur wrote:
Hi,
TIA
Hi Mons1eur,
I had asked the same question when my kid was on the way and I will pass on the comment/piece of advice that I received and that turned out to be the most on point.
The camera you will have with you most and therefore end up using the most - is your smartphone. It will give you some of the most memorable photos of your kid. Also, babies do not move fast, you will be able to get great pics with the 18-55mm you have right now. (I had been told to get a pin-hole camera as a joke).
While not lens advice, as a dad, I can say - if you had to 'somehow manage to convince the wife' that you need a new lens, it is most likely G.A.S. which can come regardless of baby on the way or not. You are spending too much time thinking about the camera, which i can assure you is not that important in the grand scheme of things.
Cheers!
 Bisonbison's gear list:Bisonbison's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0
shakenmartini wrote:
Quayton wrote:
ons1eur wrote:
Hi,
TIA
You make a good point. I probably should wait, and it's probably not worth suggesting this idea to anyone else either. Thanks for the opinion.
Pritzl Senior Member • Posts: 1,477
Another vote for the 35mmF2. Our son was born 2 weeks ago and I got that lens specifically for that reason. Here is the reasoning if you're interested:
  1. A fast prime is necessary to shoot in natural light with a fast enough shutter speed to avoid motion blur; anything slower than 1/100 might show it.
  2. Wider than 50mm equiv will distort features too much and/or include too much background - something that's likely to be very cluttered around a newborn.
  3. OIS is irrelevant at those shutter speeds and focal length.
  4. I tried a 50mm (80mm equiv on Canon 1.6 APSC) with our daughter and while the results were decent, I had to back up quite a bit for full body shots at which point it's hard to hold the child's gaze - it just wasn't as flexible.
  5. The much smaller size of this setup means the camera is always close at hand to capture fleeting moments.
  6. Why not the faster F1.4? I was more comfortable with the F2's faster focusing and that I could shoot at F2 without worrying about sharpness.
To my mind there is only one downside  to this lens for newborn photography: due to the wider angle of view, slightly longer than normal close focus distance and image quality deterioration at close focus it makes for very poor isolation when you want to shoot say just your baby's wrinkly little hand. Not sure I've identified the best lens for that in the Fuji lineup yet.
 Pritzl's gear list:Pritzl's gear list
Fujifilm X10 Canon EOS 70D Fujifilm X-T2 Canon EF 50mm F1.4 USM Tokina AT-X Pro 12-24mm f/4 DX II +9 more
Mark Johnson Regular Member • Posts: 118
I've been photographing my baby since he was born with XT1, XT2, and iPhone. He's just walking now. Once the baby is 3months the wiggle will get you and the f1.4 lenses focus too slow and the depth of field is too small anyway. Get close in with 23mm f2, 35mm f2, heck even get in close with 18mm.  As soon as baby starts moving you will want fast focus of the new f2 lenses or the pro zooms. Getting in close to baby and close the ground with 23mm f2 works great - babies head & face proportions are different than a child or adult, so I find that shorter focal lengths work well. At 90mm my babies head looks way huuuuge. A bit of perspective distortion from a wide angle to have a big face and small body, a hand close to the lens, or a toe reaching out can be really fun. Also to capture the interaction you need some space that a portrait lens won't give you. And, they turn and lean and roll and just plain jump around so quickly that framing wide and cropping in post is a good way to go.
I also used the 23mm f1.4. Fantastic lens, fast focus. But really that weight and cost isn't really worth it. The bokeh on a close subject is a bit nicer than the f2, but there's very little in it, and f1.4 really is only good for a stationary subject anyway.
Fleeting expressions are magical if you can capture them, so you can use a tele and just cover the face, cropping the head. One of my best was using the 55-200 with a close focus tube, manual focused, but baby was sleepy so it was a rare posing moment. But you can also just crop those in post if you don't mind the drop in pixel count. (55-200 is good for outdoors, but indoors its slow to focus. Not recommended for babies.)
I've also found that I need to shoot at at least 125 or faster to suppress babies motion blur, so f2 without stabilization beats f3.5 with IS. 1/60s doesn't cut it.
Where my 18-55 shines with baby is video. f5.6, fix the focus plane (actually on the XT2 I can reposition using the joystick and refocus with a half press and it turns out OK) and film. Don't forget, 1/30 or 1/60s for video. You will want an ND filter if you want to shoot video outside. I have a 6 stop and it works OK for CA sun.
One more tip - framing: its great to include the arms / hands etc when a kid or adult are holding the baby, showing that connection.
