scratched lens
Started Jun 24, 2017 | Questions
jf1020 Forum Member • Posts: 76
scratched lens
I bought a used Canon EF-S 17-55 f/2.8 for my Rebel T3i.
https://www.usa.canon.com/internet/portal/us/home/products/details/lenses/ef/standard-zoom/ef-s-17-55mm-f-2-8-is-usm
It was listed as very good condition for $450 vs $800 new
It arrived with a scratch on the perimeter of the lens and I was pretty disappointed.
I did contact the seller who agreed to take another $100 off which is why I am even considering keeping it
My question is am I crazy to consider keeping it? Is it possible that it wont affect my image quality? Can someone recommend a good test so I can assess the effects?
thanks!
Canon EF-S 17-55mm f/2.8 IS USM Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
ed rader Veteran Member • Posts: 9,068
Re: scratched lens
what you'll hear parroted on these forums is that small a small scratch "does not effect image quality".  maybe not most of the time but I had a small hairline on my 24-70L and occasionally when I shot into the sun i'd get a long flare in the image.
i'd offer him maybe $300 or else I would ship it back but bottom line is do what makes you happy!
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
nightfly Contributing Member • Posts: 567
Re: scratched lens
I'm pretty sure you won't see any effect from that. It's small and possibly too far away from the centre.
But, by all means, do you own testing and maybe go read these:
http://kurtmunger.com/dirty_lens_articleid35.html
https://wordpress.lensrentals.com/blog/2008/10/front-element-scratches/
 nightfly's gear list:nightfly's gear list
Canon EOS 60D Canon EF 50mm F1.4 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 105mm F2.8 EX DG OS HSM Tamron SP 70-200mm F/2.8 Di VC USD +1 more
noggin2k1
noggin2k1 Senior Member • Posts: 2,951
Re: scratched lens
From a purely 'sales' perspective, you need to show him the loss in value from the scratch - simply showing the scratch doesn't quantify anything.
Try and shoot it directly into the sun to get a flare off it (as mentioned above), and send him that image - it'll be obvious why the lens is worth even less, and puts you in a strong negotiating position.
 noggin2k1's gear list:noggin2k1's gear list
Canon EOS R3 Sony a7 IV Canon EF 24mm f/1.4L II USM Canon EF 35mm F1.4L II USM Sigma 105mm F1.4 DG HSM Art +7 more
(unknown member) Contributing Member • Posts: 724
When mounted on the camera, I wonder if that scratch is...
even in the field of view?
The Light Stalker
The Light Stalker Contributing Member • Posts: 960
Re: scratched lens
thanks!
I fell down landing on my photo backpack which in the process knocked the lens cap loose which effectively put a fairly small scratch towards the center on the outer lens element with my 24-70II.
Further shooting showed no problems until I started shooting into the sun for landscapes during sunsets. It was during the sunset shooting that I started to notice sun flaring that I hadn't experienced before.
A trip to Canon to have the front lens element replaced set me back about $600. Since the repair the flaring except for normal intentional flaring has gone away. The lens is much sharper also, so I could say it was money well spent.
A good test imho is to shoot into the sun to mimic previous photos and see if the results are different. I would suspect that since it is so close to the filter threads that you may not see any problems.
If you choose to return the lens I would suggest contacting the seller, ebay and paypal to obtain a resolution.
“Don't shoot what it looks like. Shoot what It feels like.”
— David Alan Harvey
 The Light Stalker's gear list:The Light Stalker's gear list
Hasselblad X2D 100c Apple iPhone 12 Pro Max +1 more
Kevin Omura
Kevin Omura Senior Member • Posts: 2,388
Re: scratched lens
If this was purchased on eBay I would register a problem on the system as buyer protection can then kick in.
Will the scratch be a big problem? Hard to say how badly it will show but lets take a different approach. Will this bother every time you pick up that lens? If yes do you think you will be hesitant to use it? If yes return it.
 Kevin Omura's gear list:Kevin Omura's gear list
Canon EOS D60 Canon PowerShot S100 (2000) Canon PowerShot S5 IS Canon PowerShot G2 Canon PowerShot G6 +69 more
dgumshu
dgumshu Veteran Member • Posts: 4,623
Re: scratched lens
thanks!
Resale value is what will be affected, I doubt that it will affect your IQ. Personally, and this is just me, I'd return it for a refund.  There is no shortage of good used lenses out there.
 dgumshu's gear list:dgumshu's gear list
Canon EOS-1D X Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R5 OM-1 +52 more
photonius Veteran Member • Posts: 6,895
Re: scratched lens
thanks!
if it's that scratch at the N of canon, it will most likely be outside the field of view. But as others said, depending on HOW (angle) the sun falls on it in a counterlight situation you can see effects. There was once a thread here, with a sample - however in that sample the scratch was near the middle. If it is outside the field of view, you could paint it black, then there shouldn't be any flare anymore.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
