Air Show Advice Needed
Started Jun 22, 2017 | Discussions
tintifax Senior Member • Posts: 1,057
Re: Olympus EE-1 viewfinder for airplane- and wildlife photographie
I would recommand the Olympus EE-1, an external viewfinder that you put on the cameras hot-shoe that shows you the center of your image (of the image the camera can see) with a red LED-point but shows you a much much bigger frame and you also can see the background around the frame .... that makes it possible to see the full sky with your eyes while having a frame in front of you/on top of your camera with a red LED point in the middle that shows you the center of the cameras sensor = your picutre.
That makes it easy to follow a fast moving subject like an airplane.
It is explained very well here: https://www.youtube.com/watch?v=gnTAbBSUHZk
Olympus homepage: https://www.olympus.at/site/de/c/cameras_accessories/pen_om_d_cameras_accessories/pen_om_d_other_accessories/ee_1/index.html
Otherwise - if you use only your viewfinder - it is hard to follow such a fast subject and if you have lost your airplane in the sky it is very hard to find it again.
Before you use it the very fist time you have to adjust it to your lens, but that's very simple
Use more focus-points = 9 or even all your camera has
Play and learn it before you go to the airshow!
with best regards from Vienna
Thomas T
 tintifax's gear list:tintifax's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +9 more
Dave Abrey
OP Dave Abrey Regular Member • Posts: 291
Thomas,
Thanks, I'I'll definitely look in to it :-).
 Dave Abrey's gear list:Dave Abrey's gear list
Olympus E-M5 II Olympus E-M1 II Canon EOS R Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital 45mm F1.8 +5 more
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
i prefer to use a viewfinder so i can concentrate on the framing of a shot when it comes to aircraft, aircraft at shows tend to do passes with a certain window where a good good shot can be taken
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon D2Xs Nikon 1 V1 Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
Wu Jiaqiu
Re: Air Show Advice Needed
paul cool wrote:
Got a weekend ticket for headcorn looks like they do fly close a real bargain £16 pound for the weekend or £12 for the day ,i am getting ready to get some practice in for riat first airshow of the year
https://www.flickr.com/photos/58365044@N05/
can't do RIAT as it's my wedding anniversary and i live in the Netherlands these days, next year hopefully, only done frisian Flag this year which is sort of close by.....well worth it for watching 50 jets scramble and take off
battybob Regular Member • Posts: 194
Hello Trevor,
always keep an eye out for your airshow pictures as so impressive. Question re the nd filters. Which make do you use, and what value do you opt for when we do actually get a bright sunny day here.
Bob
 battybob's gear list:battybob's gear list
Olympus E-3 Olympus E-510 Olympus E-5 Olympus E-M1 Olympus E-M5 II +13 more
Skeeterbytes Forum Pro • Posts: 23,184
Don't overlook CP filters, some of which have factors approaching 2 stops and all will improve color saturation from painted surfaces, plus cut haze scatter and make clouds pop.
Rick
John Renton Forum Member • Posts: 84
Old Warden is probably the best location in your area for photography as the sun is behind or to one side of you all day - you owe it to yourself to get there!
Predominately prop driven aircraft taking off from grass runways and passing relatively close to the crowdline, so plenty of practice in relatively slow panning (an essential skill) and decent tree backgrounds for take off and landing shots.
Duxford is relatively unforgiving for photography as you are facing south and the higher speeds of warbirds puts them at a greater distance for much of their routines - but admittedly Duxford is supreme for warbird variety!
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
3 stop marumi nd
... 3 stop is perfect for prop airshow when trying to reduce shutter speed enough to get some prop blur.
Marumi 72mm is realistically affordable.
Without it you may end up shooting at f22 and bringing home lots of very blurred plane photos just like I did the first time !!!
If the weather keeps alternating from sunny to cloudy a 3 stop should allow you to keep between f5.6 and f22 at a suitable shutter speed without having to make any other adjustments.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
battybob wrote:
Hello Trevor,
Bob
I've got a Hoya ProND8 4 stop 67mm which I use with a 72-67mm stepup  ring.  I already had this. I also was put off by the price of 72mms but this setup is working fine for me.  If I was buying new I'd buy a 3 stop 4 is just a tad too much if the sun goes in.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
paul cool
paul cool Veteran Member • Posts: 3,137
Trevor Carpenter wrote:
battybob wrote:
Hello Trevor,
Bob
I have just purchased the 77mm hoya Pro nd 4 2 stop now i am wondering if it will be enough oh well see how it goes also purchased a step up ring of 72mm -77mm so my 100-400mm and 40-150mm can use it ,two chances
 paul cool's gear list:paul cool's gear list
Sony a7R III Sony a1 Sony FE 70-200mm F2.8 GM OSS Tamron 28-75mm F2.8 III Tamron 17-28mm F2.8 Di III RXD +3 more
battybob wrote:
Hello Trevor,
Bob
Hello Trevor,
thanks for the reply. These filters are not so cheap, so your input will save me experimenting on a trial and error basis. A 3 stop it is.
Bob
Hatstand Senior Member • Posts: 1,623
In my opinion, 2 stops is fine for "regular" prop blur - I use a 2-stop for my favoured shutter speeds of about 1/250th, which gives what I consider (!) a "pleasing" blur.
But if you try for a "full-disc" prop blur (eg. 1/50th or slower) on a sunny day, 3+ stops would be better.
(Personally I avoid the "in-between" shutter speeds from about 1/100th to 1/160th... because at those speeds the propeller blur looks like "butterflies" or "windmills", and I don't find it pleasing).
Rick
I'm now very wary of polarising filters  - variable ND filter (which is two polarising filters working together)... did NOT play nice with my 100-400 and G80. Innacurate focus for a great many shots, and I suspect it messed-up stabilisation too - creating unwanted motion blur for a great many more.
A fixed-value ND filter created no such problems (metallic deposition coating creates the effect, instead of polarising)
Dave Abrey
Ok, I have a little update... I'm still going to Duxford on Sunday, however, I've just managed to score tickets for RIAT the following weekend! I've never been, so assume the flight line is further away than at Duxford. I guess I'd need a lot more focal length for that, right? But 100-300 or 100-400...?
I might bring some upgrades forward a bit...
100-300mm should be OK for RIAT, but 100-400mm would be better. The issue is not so much that the flight line is further away... rather, that it's a lot longer. The high-energy displays and fast jets in particular, will cover a lot more distance.
I went to RIAT last year, but my 100-400mm hadn't arrived by then... so I used a 45-175mm on my Panasonic GX80... with a Nikon 1.7x TC-E17ED teleconverter stuck on the front. That gave roughly 75-300mm.
You can see some of the resulting photos HERE - they should give you an idea of the type of shots you might expect to get with the 100-300. Actually perhaps you can do better, if you're closer to the front of the crowdline than I was (I was in the Aviation Club enclosure, which was about 25m back)
I missed a few shots that were simply too far out of range, and I had to crop into many shots more heavily than I'd like - but it wasn't too bad and I didn't feel too frustrated. Sometimes atmospheric heat haze is more limiting than the lens anyway.
This year I'll be taking the 100-400mm though, on a Panasonic G80...
icexe Contributing Member • Posts: 789
Dave Abrey wrote:
In a couple of weeks, I will be going to the Flying Legends air show at the Imperial War Musem at Duxford in the U.K. I will be taking my EM5 ii along with the Olympus 40-150mm Pro and the 1.4x teleconverter. However, it's been a while since I took photos at an air show, and this will be my first time with the EM5 ii, so I am hoping to get some advice before I go.
1) If anyone is familiar with Duxford, will the 40-150mm + 1.4 teleconverter have enough reach? That would be a maximum of 210mm, or 420mm full frame equivalent field of view. The only other time I've taken photos at an air show was with a Canon 10D and a 100-400mm (640mm full frame equivalent field of view). That seems like I'll be coming up short, and the smaller planes may be quite small in the frame. Long term, I plan to get either the 100-300mm or 100-400mm, but that's unlikely to be an option before the show (100-300mm may be possible, 100-400mm definitely not).
I've shot all my air shows with a 450mm equiv. (300mm on a 1.5x crop sensor) and it worked fine, so 420 equiv., while a little shorter should still be able to give you some good shots.
2) I am aware that the EM5 ii doesn't have the best continuous autofocus, so is it best to just stick to single AF? Also, which focus points would be recommended? I had problems recently when I tried to photograph F15s at RAF Lakenheath using a single point, would it be better to use the 9 point group to give the AF more chance?
90% of the time at air shows you will be focusing at infinity anyway.  So just manual focus to infinity or use back-button focus to reduce focus hunting
3) Related to the previous question, what drive mode would be best, single or continuous?
see above
4) Is there anything else I should do, e.g. settings etc.?
bring an ND filter if it's a sunny day.  You want to slow down your shutter to capture spinning props.
My long term plan is to upgrade to the EM1 ii, but that won't be happening until later in the year, so I want to try to get the most out of what I have at the moment for this air show.
just add an ND filter, you have everything you need.
Thanks,
Dave.
Before you can start taking good photographs, you must first learn how to recognize bad photographs.
 icexe's gear list:icexe's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Fujifilm X100V Pentax K-5 Olympus E-M1 II +11 more
bradevans
bradevans Senior Member • Posts: 1,029
if the choice is 100-400 vs 100-300 first version then its absolutely the 100-400, as the 100-300 will focus hunt, has limited burst speed (due to the lens, not due to camera settings).  The AF of the 100-400 is magnitudes better than the 100-300.  The "useability" and "user experience" of the 100-400 is just that much better.
If you can get a 100-300 second version that might work well as I believe the DFD and AF speed / communication is very similar to the 100-400
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
Dave Abrey
Quick post show update...
First, thanks to everyone for the input and help in the thread so far.
I've had a quick sort through the photos and deleted the rejects - there were quite a few! No images to share yet, but here's some things I've learned from today's experience:
  1. When doing a software update on your camera, check ALL settings afterwards. I updated to v3 a couple of weeks ago, and changed some settings for the event, but forgot to check what image quality it was set to. As a result, I found out after I got back that I'd been shooting in JPEG only, not RAW 😢.
  2. As a result of shooting JPEG, I can't do much with adjusting the exposure compensation. Which I think I would need to do in many cases, as in a lot of the shots, the plane is too dark.
  3. I bought a 4 stop ND, that seemed to do the job, as I was able to shoot at 1/125 or 1/160 (I think), and was able to get some ressonable prop blur.
  4. The EM5 Mark II C-AF is really not great for air shows. I tried some S-AF, but I don't think they worked (does the EXIF data have focus mode in it anywhere?). I also tried C-AF with tracking, which seemed to work a bit better, but again, I'd need to check.
  5. The 40-150 with 1.4 TC was just about ok for reach, but more would have helped. I'll be cropping some shots.
  6. My wife doesn't like air shows 🙁.
So, a lot of that I can work on my technique to fix. The C-AF issue is more of a problem. The obvious option is to get an EM1 mark II, but hey are very expensive. Another option I've though about would be a G80/85. This would clearly benefit from the DFD used in the Panasonic 100-300mm or 100-400mm (both of which are possible lens options), but would that give an improvement for C--AF over the EM5 Mark II? I've never used a Panasonic body, so I have no idea how DFD performs.
Another more radical idea would be to get an APS-C DSLR from Canon or Nikon and maybe something like the Sigma 150-600mm just for air shows...
Any more thoughts from anyone?
Thanks,
Dave.
Sounds like a mixed bag but you 1. gained valuable experience and 2. got some shots regardless.
In Olyland an E-M1.1 will work far better with that lens for not much investment these days, but doesn't give you more reach. A jump to Panny and the 100-400 would give DfD and dual IS, so worth considering. I wouldn't "settle" for one of the 300 zooms because compared to these two lenses they're a step back in IQ and aperture.
Good luck!
Rick
Been there, done that!
  1. As a result of shooting JPEG, I can't do much with adjusting the exposure compensation. Which I think I would need to do in many cases, as in a lot of the shots, the plane is too dark.
You might still be able to work with them a bit.
  1. I bought a 4 stop ND, that seemed to do the job, as I was able to shoot at 1/125 or 1/160 (I think), and was able to get some ressonable prop blur.
You could have probably gotten away with a bit higher, like 1/250 to 1/500
  1. The EM5 Mark II C-AF is really not great for air shows. I tried some S-AF, but I don't think they worked (does the EXIF data have focus mode in it anywhere?). I also tried C-AF with tracking, which seemed to work a bit better, but again, I'd need to check.
I find for most airshows, you don't need any kind of auto-focus, I just manually focus to infinity, stop down to f8 or so and then forget about it.
  1. The 40-150 with 1.4 TC was just about ok for reach, but more would have helped. I'll be cropping some shots.
I shoot at about 450mm equiv and rarely have to crop, but it really depends on where you are relative to the airplanes.
  1. My wife doesn't like air shows 🙁.
Neither does mine
I think you would just be throwing a very expensive solution at a really simple problem. Just try leaving the lens locked at infinity next time. Planes in the air are going to be at the farthest focus distance of the lens anyway.
Thanks,
Dave.
