GH5 sensor readout (scan speed)...
Started Jun 21, 2017 | Discussions
_vlad Senior Member • Posts: 2,744
11
is sensitivity related.
After discussion in another thread I did one more comparison of ES readout between GH5 and GX80. I did not believe the result in the beginning, but yes - GH5 read fast with ISO 800 and below and read slow with ISO 1000+ up to max ISO.
It is just a simple artificial light test where you can see number of stripes (flickering) related to sensor speed. I used the same lens for cameras same basic Shutter speed and prefixed ISOs. Cameras changed the AV to get proper exposure.
GX80 (G80 I suppose is same). This is consistent for all ISO from 200 up to max. So I do not post other samples.
This is GX80 1600 ISO shot using 50Hz light bulbs. You can see roughly 4 stripes which means 50*2/4= 1/25th of second readout.
GH5
ISO 800 and all ISOs below are same - as shown here
GH5 ISO 800 same setup as above shot. You see only roughly two stripes - readout is roughly 1/50s
ISO 1000 and all ISOs beyond that treshold - so again no other samples
GH5 ISO 1000, readout is roughly two times slower than in above picture and barely slower than GX80 - however this is 12bits.
As you see there is good correlation between Frederick Gluckner findings - he tested the readout at 3200 ISO - which is territory above 1000 ISO.
Now the 6K mode. Again same settings just one difference in output - result is same across all ISOs.
6K mode same across all ISO. roughly 1/50 s. Same as normal mode below 800 ISO. Sorry no exif data - captured from stream.
Now that seems to me interesting as I never thought of different readout with different ISO settings. Seems to me that Panny - at higher ISOs - has made trade-off with scan speed for better image quality.
Vlad
 _vlad's gear list:_vlad's gear list
Panasonic Lumix DMC-GX85 Panasonic GH5 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS +5 more
Panasonic GH5 Panasonic Lumix DMC-GX85
DH007 Regular Member • Posts: 181
Re: GH5 sensor readout (scan speed)...
Nice work _vlad.
At the lower iso levels is the output still 12 bit?
 DH007's gear list:DH007's gear list
Panasonic Lumix DMC-G7 Panasonic GX850 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +10 more
OP _vlad Senior Member • Posts: 2,744
DH007 wrote:
Nice work _vlad.
Yes they are all 12bits. No difference when pushing heavily in post.
Vlad
Robiro Veteran Member • Posts: 6,807
About 3.5 stripes to me more precise. A 50 Hz bulb blinks 100 times a second. So, sensor readout is 3.5/100 = 0.035s, which is rounded to about 1/29s.
GH5
I am seeing roughly 1.8 stripes. 1.8/100 = 0.018s, which is rounded to about 1/56s.
I am seeing roughly 1.3 stripes. 1.3/100 = 0.013s which is rounded to about 1/77s.
As you, I am puzzled why this would be a case.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
Yes the measurments here are just aproximative - however pretty much indicative what is happening below/above ISO 800. I would like to know whether other camera makers (OLY, Sony) are consistent with their sensor scan time across all ISOs. So far - AFAIK - nobody was even thinking of such a possibility (i.e sensitivity related readout).
We do not know why Panny has decided to slow down sensor read above 800 ISO (and I am pretty sure they had a reason) - maybe noise? That is a question. Fact is that while 6K photo is pretty impressive - once it get to 1600ISO or more there is more noise in captured frames - not that much (maybe 0,5 stop or even less) but it is there. And 6k photo is full speed readout.
Vlad
Vesku Senior Member • Posts: 2,964
Thanks a lot. My biggest worry about GH5 ( slow e-shutter) is gone.
Androole Senior Member • Posts: 1,455
Extremely useful observations, and a very interesting conclusion!
I was quite shocked when I heard the early reports of such a slow readout speed, especially given that the comparable sensor generation to the ~1/60s E-M1 II. Now it's quite clear the decision that Panasonic has made to optimize the readout at different ISOs.
Glad to hear that at anything below ISO 1000 the e-shutter is totally usable in the majority of situations.
 Androole's gear list:Androole's gear list
Olympus Stylus Tough TG-850 iHS Panasonic Lumix DMC-GX7 YI M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +2 more
whumber
whumber Veteran Member • Posts: 3,614
I'll post pictures later but it looks like the E-M1ii does the something similar except the change occurs between ISO 6400-12800.
 whumber's gear list:whumber's gear list
Fujifilm X-T1 Olympus OM-D E-M1X Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 +9 more
Great, please do so - n/t
Vlad
drj3 Forum Pro • Posts: 11,129
The change in sensor readout speed with the E-M1.2 occurs at ISO 8000.
Flash:
"The sync speed for silent mode and focus bracketing (P. 94) is 1/50 second. The sync speed at ISO sensitivities of 8000 and above and during ISO bracketing (P. 94) is 1/20 second.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +9 more
Thanks - great info n/t
Vlad
Jon555 Veteran Member • Posts: 7,298
It would be interesting to test 1080p and 4k video as well. (I'm assuming the tests other than 6k were for stills?)
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
_vlad wrote:
DH007 wrote:
Nice work _vlad.
Assuming the files are 12 bit, I would probably save RAW files, set my maximum ISO for 800 and use the Electronic shutter for most moving targets where the actual ISO would be no more than 2 stops higher and then correct the exposure in PP.
drj3
Yes I was concentrating on stills performance. Testing 4k and 1080p is interesting idea though. I will try later when having some extra time. Me myself do not expect much of a difference in 4k mode - it is 50/60 FPS scanning the whole sensor area, so assume to be similar in readout (slightly better?) . Now for 1080p - I do not know what to expect performace wise.
Vlad
whumber
Re: Great, please do so - n/t
As the other posted pointed out, the switch does indeed occur at ISO 8000.
ISO 8000
ISO 6400
_vlad wrote:
DH007 wrote:
Nice work _vlad.
I wonder what is the actual difference between slow and fast sensor reading if the both are true 12bit? Why read sensor slower?
drj3 wrote:
_vlad wrote:
DH007 wrote:
Nice work _vlad.
Agree this is obvious solution. Either limit the ISO to 800 and eventually underexpose or use 6k with full readout. Or leve it as it is - I have had rarely a real problem with 1/25s readout (GH4), but I am not denying that it might occur under some circumstancies.
Just to say - setting where the treshold is positioned is just firmware decision. I would prefer to set it to ISO 3200 or at least 1600 - even at risk of having slightly more noise.
Vlad
Interesting what testing target did you use?
I never saw anything like this.
Vlad
whumber
Re: Interesting what testing target did you use?
It's a monitor with a high frequency strobe.
BOOM.
I'm looking at upgrading from the G7 where I use e-shutter a lot since I need to freeze stuff and its usually outdoors.
8bit (e-shutter read out on G7) > 12 bit - Yes!
16mp > 20mp - Yes!!
No anti aliasing filter > Yes!!!
Four times the price > F***
_________
Vlad I don't suppose you have any info on if the 180fps option for video outputs at 10bit? The options on what it does for video and what it might do are a bit hazy.
