How do I improve the color of photos?
Started Jun 19, 2017 | Discussions
kevinNYC New Member • Posts: 5
Please see below two pairs of photos. You'll notice that the photos taken with the 350D have more true-er greens whereas the photos of the same object with a 650D show a more yellow-ish tint.
(Note that the lenses used are different, but I've tried swapping the lenses and it did not make a difference).
What do you suggest is the cause for the different greens? What do you suggest I change to make the photos from the 650D have the same color as the 350D?
Photo of grass with Canon 350D. Green of grass looks like a true color.
Photo of same grass with Canon 650D. Green of grass looks like it has more yellow.
Photo of tree with Canon 350D.
Photo of same tree with Canon 650D.
Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N) Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
photonius Veteran Member • Posts: 6,895
Re: How do I improve the color of photos?
if you are shooting jpg (not RAW), then there are several settings in the camera that effect this. You can set picture styles, or you adjust color balance, and/or white balance, all of which can affect the output. The 650D looks warmer. so you might want to reduce the yellow a bit. Check if white balance and picture style settings are identical between the cameras. If so, then adjust the tint to how you want it. Note, that overall proper color calibration is not trivial. It starts with your monitor, where you can't be sure that it shows the colors as they should, if it's not calibrated. You would have to buy a color chart, and then make sure that the final picture on the monitor will be as close as possible to the color chart when you hold it next to the screen (consider also the room light then, that falls on your color chart inside - best would be daylight, the same as when you took the picture outside.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
R2D2 Forum Pro • Posts: 26,551
Welcome Kevin,
Avoid "Auto" settings.  Set your White Balance to a preset, or custom.
Shooting RAW allows you to adjust White Balance during post-processing non-destructively (without having to be precise during shooting).  Canon's DPP does a great job on RAWs.  Also make sure your color space is consistent.
Happy shooting!
R2
Stan in NH
Stan in NH Senior Member • Posts: 1,898
One simple question:  are both cameras using the same white balance setting?  For most outdoor shooting, auto white balance does a decent job.  As others mentioned, this appears to be a white balance difference between the two cameras.
 Stan in NH's gear list:Stan in NH's gear list
Sony a6400 Sony a7R IV
OP kevinNYC New Member • Posts: 5
Thank you! I'm indeed shooting in RAW. It's been tedious to update the color in post-processing for all photos. That's why I'm trying to figure out a way to fix it on the camera itself.
Thanks for your pointers on adjusting the yellow, picture style settings, tint and color charts.
Both are using AWB. Thanks for the pointer on White Balance- it looks like I'll need to configure the white balance on the 650D.
Interesting- yes, I was shooting with AWB with Raw. I'll check out presets and custom. I've no clue what color space is, but I'll check that out.
Ok, if you shot RAW, then it's no issue whatsoever anyway. You can process your images to whatever you like afterwards in the computer (what software do you use?). If you use Canon DPP, it will take the settings of the camera (that the camera also uses to make jpgs), i.e. style and white balance, and apply that automatically to make the first default view - but of course you can change it to anything that you want - that's the point about RAW data - which is more or less just the RAW data from the sensor.
Exit10 Senior Member • Posts: 2,264
I would try shooting jpegs and see how you like the results. Its tough doing any diagnosis when you shot in raw and we don't know what you did to process the files.
Your examples with the newer camera are less than ideal - the first one is using a high ISO and the second is completely out of focus (or maybe there is movement? do you have IS switched on with the 24-105?).
Maybe try a couple of similar examples - jpegs straight out of the camera and post the results - keep the ISO low and make sure the picture is focussed and there is no motion blur.
If there are still problems and you can post those examples it should be easier to see the problem.
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Based on the replies in the thread, I tried the following:
1. Custom White Balance. This turned out to be harder than I had imagined. I used a blank page from my printer, but the custom white balance photos turned out to have too much green.
2. Preset White Balance. The Sunlight preset had the best results. It is still a little warm, but it is close.
3. Raw vs JPG. Although I believed I was shooting in RAW, the settings were actually in JPG. Switched to RAW & installed DPP. DPP provides some good tools to correct the green.
4. IS & Filters. As expected, IS options didn't have any impact. Filters (UV and CP) did not have any impact on the color.
My best bet seems to be to use the Sunlight Preset White Balance and then color correct using DPP.
You can modify settings in the camera more, i.e. you can create your own custom picture styles. Or you can completely customise your WB (white balance correction), see page 137 of the manual for the 650D.
Also, as a side note, which color reproduction range is set (p139)? sRGB or Adobe, that makes a difference.
Check also your monitor. Compare the same image on different monitors if you can.
I presume you cannot directly compare 350D and 650D shots anymore? (take exactly the same scene at the same time).
Dareshooter Veteran Member • Posts: 5,842
Not sure if you can directly compare the color output of both cameras as the picture styles we have today had not been a feature of the 350D. It only had two options which were named parameter 1 and parameter 2 . Picture styles were only introduced on the rebel line when the 400D was released.
AnthonyL Veteran Member • Posts: 3,686
"white" paper can be many shades of white
On my 450D I was usually set to Cloudy for results I liked
DPP is a much under-rated tool.  Make sure you have the latest from the Canon Support sites.  There are Canon Digital Learning Centre/Center videos of how to best use it - take advantage of batch processing and copying/pasting settings across a selected range of images.
My 700D is much better at being on Auto WB than my 450D was - yep - I'm on AWB.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
(unknown member) Forum Pro • Posts: 13,189
Not that he's switched to raw (#3 above). Those settings have zero effect on the raw data, just the JPEG.
Andrew Rodney
Author: Color Management for Photographers
The Digital Dog
http://www.digitaldog.net
Yes, but the sample images were done in jpg (he initially thought it was RAW).  My point was actually, he doesn't necessarily have to go to RAW. There should be enough settings to customise the white balance in the body, so that jpgs look like he wants. - This is assuming his only reason to use DPP is to change the white balance. If that is the case, the OP can save time and storage space by just getting the jpg in the camera right.
Again, to the OP, check your monitor as well - that's an important part of the equation. I find auto white balance usually quite ok.
Andrew Rodney
The Digital Dog
And now he should continue to capture raw and my post remains factual.
Yes he should. Please don't recommend he go back to JPEG for so many reasons!
Moot with raw.
Andrew Rodney
The Digital Dog
Andrew Rodney
The Digital Dog
I thought we live in a free world, where the OP can choose himself.
Moot with raw.
Andrew Rodney
The Digital Dog
Andrew Rodney
The Digital Dog
He can. Based on good or poor advise! He's now shooting raw; good move on his part based on understanding the massive advantages of a raw workflow,
Moot with raw.
Andrew Rodney
The Digital Dog
Andrew Rodney
The Digital Dog
Andrew Rodney
The Digital Dog
The Light Stalker
The Light Stalker Contributing Member • Posts: 960
Simple answer, shoot with RAW. If you have to, take a sample picture of a white card. Heck I even sometimes use my 18% grey lens cleaning cloth.
Open the capture in Canon's DPP and use the eyedrop tool with RAW for WB. Click on the white (or 18% grey) target to get a good white balance. I open the RAW file in PS CS6 as a TIFF to do further enhancements. Your methods may vary.
“Don't shoot what it looks like. Shoot what It feels like.”
— David Alan Harvey
 The Light Stalker's gear list:The Light Stalker's gear list
Hasselblad X2D 100c Apple iPhone 12 Pro Max +1 more
Exactly and for so many reasons.
For the OP or others, a superb if not somewhat long piece on why rendering an image is such an important part of the art/technology of photography:
http://www.lumita.com/site_media/work/whitepapers/files/pscs3_rendering_image.pdf
Here's an inexpensive WB tool (I still prefer an X-rite Passport so I can build custom DNG camera profiles something DPP doesn't support however):
https://photographylife.com/diy-reliable-and-cheap-universal-white-balance-reference-device
Andrew Rodney
The Digital Dog
