GX7 Question please
Started Jun 18, 2017 | Questions
rolandb
rolandb Veteran Member • Posts: 3,193
GX7 Question please
Hi guys,
Looking to maybe "move up" from my compact "combo" of LX7 & TZ70 and to take my photography a bit more seriously so,,, the questions are,,
Any of you guys use a GX7, if so how do you rate it.
Also,, is there a difference between the
14-42 3.5-5.6 ii ASPH & OIS lens ? or are they in fact the same lens ?
Looking to shot mainly days out / holidays. Church interiors / stained glass,, flowers.
Any help / info would be greatly appreciated.
Roland.
http://www.flickr.com/photos/rolandb52/
"" I'm a snap-shooter! I shoot anything that interest me. Sometimes, I get lucky and some of my snap-shots turn into a photograph.""
 rolandb's gear list:rolandb's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-LF1 Casio Exilim EX-ZR800 Panasonic Lumix DMC-ZS50
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS50
d3xmeister Veteran Member • Posts: 3,395
Re: GX7 Question please
Why not the GX85 with the 12-32 ?
The 12-32mm is sharper
It is much more compact
You lose some of the reach
You gain a lot on the wide angle, important for the type of photography you mention.
You gain a lot in image stabilization (Better IBIS, Dual-IS), very important for your photography
You gain stabilization in video, absolutely necessary for hand held
Plus many other stuff the GX85 has (smaller lighter body, better screen, better AF, USB charging, better shutter mechanism without shock, electronic shutter to 1/1600, 4K video, 4K photo mode)
The GX7 was a fine camera, but with what we have these days available, I woulnd't think it worth more than $200 to be honest.
dmokn Regular Member • Posts: 136
+1 on getting the 12-32. I bought that for my GX7 years ago and it's really nice to have the 12mm end. While the GX85 is better on paper in most respects, if money is tight and you get a good deal, image quality should be similar and you get the AF/MF switch, which I use all the time.
 dmokn's gear list:dmokn's gear list
Panasonic Lumix DMC-GX85 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +3 more
rolandb
OP rolandb Veteran Member • Posts: 3,193
Hi d3x,,
Thanks for the reply. Over here in the UK I believe its the GX80, not read up on that one so will give it a look later.
Regarding the 12-32 lens,, the only "problem" that springs to mind is that,, I use my LX7 as my main camera and with the 24-90 lens it gets 95% of the shots I take,, I'm not sure if the shorter zoom on the 12-32 would start to pee me off with possibly having to change lenses more often ?. Not having had a micro four thirds camera / system before I don't know if this would be the case or not, or if in fact there is a lens that would cover the same range as the 24-90 of the LX7,,,,
Roland.
rolandb
Hi dmokn,
I"ve just replied to d3x regarding the lens,, would love the wide end but not sure if its too short a zoom compared to the 24-90 of my LX7.
"image quality should be similar" then I'm possibly temped to go for a GX7 first of all just to see if I get on with the camera system or not,, I have seen one with the 14-42 lens for around £350,, not sure if that's good or not ??
Roland.
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
rolandb wrote:
Hi guys,
Roland.
The GX7 when partnered with the Panasonic 14-140 Mk2 is a superb and in my opinion a faultless combination that will cover most photographic scenarios and so easy to carry in a very small bag/case.
Best results are acquired by using the electronic shutter - which I do 99% of the time.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
rolandb
Adrian Harris wrote:
rolandb wrote:
Hi guys,
Roland.
Thanks Adrian,
Having taken a quick look at prices for both a body and then the 14-140 lens,, I'd have to be 100% sure this is the right way to go for me before spending that much on a camera / system that I've never had before,, but yes the lens does sound a good one.
Roland.
I guess it depends on what focal lengths you gravitate towards. If you're used to zooming in a lot on your current 90mm then you'd probably prefer the 14-42. If you often use the 24 end, then the 12-32 is great and my preference. If you stick with the system, the relatively adorable Oly 45 or Panny 42.5 is really small and would be a significant upgrade for portraits, and small enough to throw in a pocket.
That price doesn't seem tremendously cheaper than the GX85 though.
Pete_W
Pete_W Senior Member • Posts: 2,838
Similar situation to me. I moved up from an LX5 to an M4/3 camera last year and went with the GX85.
I had the same concern about focal length with the kit 12-32mm lens so I asked the store to swap it out for the 12-60mm lens which covered the same wide angle and went a bit further on the telephoto end. It's been a good lens for that.
Of course, I've since added more lenses to my bag.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
rolandb
Thank you Pete,,
That lens sound good, and its given me something else to check out.
Roland.
True about the bigger range but keep in mind that the 12-32 is much smaller and keeps the whole package pocketable in a jacket. All about figuring out your priorities.
brentbrent Veteran Member • Posts: 5,766
GX7 vs. GX85
I think the GX7 is great. It's still my favorite camera based on all the features that they managed to squeeze into that compact body (as compared to its predecessor, the GX1). The GX85 has several significant improvements, including 4K, 5-axis IBIS, DFD, Dual IS, and a shock-proof shutter. And Panasonic released it at a really good price point. In order to reach that price point, however, Panasonic "downgraded" it in several respects from the GX7. Here are some of the features present in the GX7 as compared to GX85:
Faster flash sync (1/320 with built-in flash, vs. 1/160)
Faster mechanical shutter (1/8000 vs 1/4000)
Tilt EVF
Perhaps better EVF (some who have used both say the GX85 has distortion not present in the GX7)
12-bit e-shutter (vs. 10-bit)
Built-in flash can tilt (I don't think that is true of GX85, but I may be wrong)
Built-in flash can be used as master for off-camera flash
Remote release jack
Metal body (vs. plastic)
Physical switch for AF/MF
Has three custom settings available on the exposure mode dial (vs. one on the GX85)
Comes with an external battery charger (but its easy to buy one with extra aftermarket batteries)
Most buyers now might well think that the improvements in the GX85 outweigh those differences. I won't argue against that. They just weren't enough for me to give up my GX7.
As for the 14-42 v.II, it is a very good lens for a "kit" lens. Sharp, compact (only extends about 1/4" when zoomed), and operates smoothly. The 12-32 is also good, but no manual focus ring, and the "twist to open" requirement before you can shoot requires a bit of an adjustment. The lower priced 12-60 would be a good option if you can get it as part of a kit for an extra $100.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
rolandb
Good point,, thank you.
Roland.
rolandb
Re: GX7 vs. GX85
Tilt EVF
Remote release jack
Thank you Brent,
All good points and useful info for me to consider.
I think I need to try to find a "local" retailer that has one in stock so at least I can take a good look at it before spending any money.
Roland.
Mark Kaprielian
Mark Kaprielian Regular Member • Posts: 400
Re: GX7 vs. GX85
Just be sure you won't be happier with the non-rangefinder style by taking a look at the G80.
  • I have and no longer use the GX7 as I much preferred the G7 when it came out and now the G85 (G80 over there) for being able to hold onto it more comfortably  and easier to get to the functions.
  • G80 has all the most current Panasonic tech just short of the GH5.
  • Has Inbody Stabilization for Video
I concur that the 14-140 lens should work well for you as a single all-around lens covering the range that you like.
Mark
 Mark Kaprielian's gear list:Mark Kaprielian's gear list
Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-GH6 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +9 more
richj20 Forum Pro • Posts: 10,181
Looking to shot mainly days out / holidays...
I love the camera. It's a very nice travel camera, small, and compact.
The flip up LCD is very handy for tripod work.
Church interiors /
It's small, and the flip up LCD is great for indoors, such as church interiors, since I can easily photograph at chest and waist level rather unobtrusively.
stained glass,,
flowers.
The tilt EVF is handy for low to the ground positions for closeup and macro focusing.
I've been very happy with the camera!
- Richard
rolandb
Re: GX7 vs. GX85
Mark
Thanks Mark,,
Its certainly something I'm going to look at further.
Unfortunatly my "local" camera shop,, only a 40 min drive so not too far,, has sold out and are waiting for more stock to arrive. Once they have stock I"ll take a ride over to have a play.
Roland.
rolandb
Church interiors /
stained glass,,
flowers.
- Richard
Thanks Richard,, great set of photos.
The G series is certainly something I'm looking into further.
Roland.
maggiemole Senior Member • Posts: 1,988
Re: GX7 vs. GX85
Thank you Brent,
Roland.
Try John Lewis.
Maggie
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
woof woof
woof woof Senior Member • Posts: 1,897
Isn't the 12-32mm the one that doesn't have a focus ring? If so I wouldn't touch it with a barge pole as I like to be able to intervene and focus manually if the camera either wont lock on or locks onto the wrong thing. For example I was photographing squirrels the other day and AF can lock onto a twig rather than the squirrels eye, shooting through glass, fences or foliage can cause issues and it's an advantage to be able to tweak the focus without too much faff on.
I have the 14-42mm mega ois. There seem to be several lenses with more or less the same description so just to be clear the one I have is the one which is quite small, prime sized really, and used to come as a kit lens and indeed I got mine with a GX80. I'd take this lens every time over any similar range lens that doesn't have a focus ring.
Anyway, I have a GX7 and it's a fine camera but I want to mention a couple of potential issues.
Firstly the camera can induce shutter shock when used with some lenses and this can cause anything from a slight blurring which is hardly noticeable to a slight double image which may be noticeable in a whole image when viewed normally. Switching to the electronic shutter negates the shutter shock issue but brings a couple of new issues such as rolling shutter effect and banding under some flickering lighting. So, really the best solution is to use lenses which are not affected by shutter shock or buy a camera that doesn't induce it.
I also have a GX80 which doesn't seem to suffer from shutter shock. The GX80 brings other improvements such as a quieter mechanical shutter and other goodies but it costs more and lacks the GX7's tilting EVF and physical MF/AF switch.
I'd advise caution when looking at older MFT bodies due to the shutter shock issue. I like my GX7 but I wouldn't recommend one to anyone who wasn't aware of the issues it has when used in combination with some lenses.
