Canon SX50 HS vs Lumix 100-300mm II lens
Started Jun 15, 2017 | Questions
sigmazen123 New Member • Posts: 1
Hi
I recently purchased a Lumix GX85 as a step-up from my old Canon SX50 HS.
I've just treated myself to the Olympus M.Zuiko 12-100 f4 lens which will give me a lovely range and am looking forward to trying that all out.
The question I have relates to the 200mm+ range which I get on my SX50 (200-1200 f6.5) vs the lumix 100-300 II lens (200-600 f5.6).
Assuming I'm using this range fairly infrequently for occasional wildlife shots, and that I won't be doing any cropping, and that I don't have a ton of cash left now I've blown it on the body and Oly-lens ... do the masses agree spending $650 on this lens is worth it, and that I'll see a significant difference in my resultant shots?
Thanks in advance
Panasonic 100-300mm F4-5.6 II Panasonic Lumix DMC-GX85
Hatstand Senior Member • Posts: 1,623
SX50 is slow slow slow
SX50 is snail-like in comparison to the GX80's AF speed, shot-to-shot speed, burst-to-burst speed, buffering and card writing, general speed of operation etc...
Never mind lens quality - image quality of missed shots is zero...!
And GX80 has way better stabilisation. And larger sensor has better noise characteristics, better high-ISO performance, better dynamic range etc, 100-300 manual zooming is way faster and arguably more accurate...
The question is, would you really use the 100-300 so infrequently, that the cost isn't justified...?
Bernie_B New Member • Posts: 1
Re: Canon SX50 HS vs Lumix 100-300mm II lens
sigmazen123 wrote:
Hi
Thanks in advance
Hi,
Also got a GX85 and bought the 100-300 II used for about 400 Euro a few month ago. In good light I get nice pictures, in low light I am a bit disapointed with the keep rate. Don't expect miracles from stabilization although the GX and the lens should harmonize well together. A tripod for sure helps but even then some pictures of static objects are still not sharp although they should. Maybe it is me screwing up but I actually do not think so (short enough exposure, smartphone trigger).
Bird pictures typically need to be cropped even when the birds are getting relatively close. Forget about BIF pictures at full range BTW. Still waiting for that special bird or deer picture I am really happy with, can't seem to get a decent pecker image although this guy is a regular guest.
Also as you can imagine the IQ is not exactly excellent compared with other lenses. So as always this is a compromise you could be very happy with or disappointed, depending on what you need or expect.
I do not use it as much as I was thinking, my favorite is the 14-140 II and primes if I want to do "special" pictures.
So I am not "the masses" but I would be careful. Maybe there is an option to get a used one and sell it if you are not happy.
Good luck and happy shooting
Bernhard
Astrotripper Veteran Member • Posts: 8,676
[...] do the masses agree spending $650 on this lens is worth it, and that I'll see a significant difference in my resultant shots?
Well, I think the 650 EUR I spent on mine was worth it. It's a good price for a consumer grade super tele zoom. I think image quality is good with my copy, see some full res samples here . With GX85 you will not have to worry about shutter shock, so that problem is out of the way.
And if you don't want to spend as much on a lens you will be using rarely, get the smaller and lighter Olympus 75-300 II for 430 EUR and get a 100 EUR cashback (that promotion ends in a week). So at literally half the price, you get the same reach, similar image quality but with no Dual IS, no DFD, no weather sealing and a bit smaller aperture at the long end.
Either way, I would expect both to offer better image quality than the SX50, but that's more of a guess.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
Not really if you only need the 200mm occasionally
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
SterlingBjorndahl Senior Member • Posts: 2,642
Advice on a 7 month old post?
Did you notice that you're replying to a post that's 7 months old? Do you think the Original Poster might have already made a decision on this?
Sterling
Lens Grit
 SterlingBjorndahl's gear list:SterlingBjorndahl's gear list
Olympus Air Panasonic Lumix DMC-GX85 Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix DMC-FZ50 +18 more
