EM-1 Mark II - show focus point in playback?
Started Jun 12, 2017 | Questions
JerryGNYC Regular Member • Posts: 129
Hi,
On my Nikon D7100, I was able to press the "OK" button and the camera would zoom in at 100% to the spot where it had focused. Is there a similar function on the Oly? I have not seen anything like that in the manual, but the terminology/search terms may be different (not that I haven't tried various <grin>).
Thanks,
-Jerry
 JerryGNYC's gear list:JerryGNYC's gear list
Panasonic Lumix DMC-LX7 Olympus E-M1 II Panasonic Lumix DC-GX9 Olympus E-M1 III Olympus 12-100mm F4.0 +4 more
Nikon D7100 Olympus E-M1 II
reggieandtfe Regular Member • Posts: 238
Re: EM-1 Mark II - show focus point in playback?
I don't know if you have to turn it on, but I can see a little green box on mine during playback in the screen that shows the histogram and all the other shooting data. If I then zoom in with one of the scroll wheels it shoots directly to that point.
JLDigitalMedia Regular Member • Posts: 119
I never noticed that! Very helpful, thanks for pointing that out.
John
 JLDigitalMedia's gear list:JLDigitalMedia's gear list
Panasonic LX100 Olympus E-M1 Panasonic Lumix DMC-GX8 Olympus E-M1 II Sony a7R II +13 more
OP JerryGNYC Regular Member • Posts: 129
Thanks much! I cycled through the different playback modes with the INFO button, I'm not seeing that little green box, but I will take a better look in the playback section of the manual!
Helen
Helen Veteran Member • Posts: 7,606
Indeed.  You can also jump straight there with two presses of the Fn1 button, as with the other OM-Ds.  Unlike them, but like earlier Pens (prior to the E-P5 and Pen-F, which are like the other OM-D models) you can also jump straight back out to unmagnified with the OK button (and all of them will also do so with a couple more presses of Fn1).
Helen
You need the Overall option to be ticked in gear menu D1 so that the thumbnail playback surrounded by shot details and compact histograms shows for image review and playback.  Then, first click of Fn1 gives a full screen image and second dives in to the AF point at your last-used magnification.
OK, the OVERALL setting is already checked off.
The Fn1 button provides no apparent function in playback, any screen. Also, I don't see the focus point indicated on the picture.
I'm on firmware 1.2, and FWIW, in shooting mode, I have Fn1 set to home the AF point, and the video record button for the zoom-focus function. Pressing record (zoom) results in a little red check mark in the upper-right side, and a second press turns that off. I don't see that reassigning those buttons would make any difference in playback mode...
Bug in the latest firmware? Does one have to have an eye-detection focus mode enabled? I have it turned off.
drj3 Forum Pro • Posts: 12,303
JerryGNYC wrote:
Hi,
Thanks,
-Jerry
Press the Arrow for Image Review, press the Info button until you get the screen with the small image and all the shot information.  In the small image you see the green box for the focus point.  Turn the rear dial to the right and it zooms to the focus point.
drj3
 drj3's gear list:drj3's gear list
Olympus E-M1 Olympus E-510 Olympus E-5 Olympus OM-D E-M10 Olympus E-M1 II +13 more
drj3 wrote:
JerryGNYC wrote:
Hi,
Thanks,
-Jerry
OK... many thanks to all who've answered me. This method works, but only for pictures taken in iAUTO mode! At least with my camera... I'd like to see Olympus implement this function for all still image records modes!
-Jerry
Helen
So I started to investigate mine ....
Mine worked on your firmware version and the latest, but I found the issue.  My Fn1 is set to Magnify; on previous models, what it was set to didn't disturb its playback function (in a similar way to how you find that the Rec button sticks doggedly to marking with a red tick and unmasking in playback, no matter what it's set to do in Shooting mode).
Not sure why you're not seeing the target - I'll investigate further.  I don't have eye detection on.
"Common sense is on perpetual backorder..."
https://www.flickr.com/photos/jerrygnyc/
https://www.instagram.com/jerrygnyc/
Helen,
Thank you. I'm probably going to try and reset everything to defaults, tonight. I'll have more time to play... But I'll be watching this thread too!
-Jerry
Garry Schaefer Veteran Member • Posts: 3,325
This is how it works on my E-M1-1 as well. As a side note, if you, for example, use the single central point, focus and recompose, the thumbnail will show the green box in the centre rather than on the off-centre point which you actually focused on. If you didn't recompose after half-press, everything is as you might like it.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Olympus OM-D E-M10 Panasonic Lumix DMC-G3 Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
Thanks, Garry. Just wish that mine would work as designed.
-Jerry
Hi gals & guys,
I did a factory reset it now have NO problem! I will slowly add my customizations back, and if the problem happens again, will report it to you all and to Olympus...
Thanks again for all your help!
-Jerry
JerryGNYC wrote:
Hi gals & guys,
-Jerry
Setting S-AF to mode 3 (back-button focus via AEL/AFL button) kills the function. Now to find out how to report this to Olympus!
(unknown member) Forum Pro • Posts: 19,317
its works on m em5mk2 , I just press review button and use the rear control dial to zoom in and it zooms in on the focus point no problem at all.
even works on face detect
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
Don
Thanks, Don. It seems I've found a bug in the latest firmware (at least on my camera body).
-Jerry
syberman7 Senior Member • Posts: 1,500
That's probably on purpose. If you use back button focus then you have disconnected the focusing composition from the shooting composition. Showing an overlay of focus box would in many instances be totally unrelated to the actual scene when using back button focus.
Just a theory.
Interesting to know that that's what happens in firmware though. I can imagine that one day in the future I may have been bamboozled by this anomaly myself.
 syberman7's gear list:syberman7's gear list
Nikon Z6 Nikon Z7 II Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon Z 24-70mm F4 Nikon AP-F 70-300mm F4.5-5.6E +6 more
Firmware Bug!
I just got off the phone with an Olympus technician, and the results are reproducible. Mode 3 in S-AF mode will not record the AF point that was used. The technician will report this up the chain and hopefully it will be fixed soon.
He also found that if you hold the button down, it will record the AF point. And he admitted that this kind of defeats setting the button to mode 3 in the first place... (I concur <grin>).
-Jerry
Photo Pete Veteran Member • Posts: 5,424
JerryGNYC wrote:
Firmware Bug!
-Jerry
It has always been so.
Only the focus point which is active when the photo is taken is recorded. If you focus with the back button and then release the button no focus point is active. The same happens if you use manual focus or lose focus during a C-AF burst... no focus point is active so it doesn't display it.
If you focus and hold down the button (even if focus is locked in S-AF mode) it is still classed as active and the point is recorded in image review.
Nothing wrong with that.
Have Fun
Photo Pete
