Canon eos 400d/xti purchase
Started Jun 7, 2017 | Questions
D148xZ New Member • Posts: 12
I just bought a canon eos 400d for €36,50 the flash is broken but the rest still works perfectly fine. Included are a charger, the manual and three battery's. Was this a good deal or could I have gotten a better dslr for the same price?
 D148xZ's gear list:D148xZ's gear list
Canon EOS 400D Olympus PEN E-PL5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +1 more
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X)
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
Re: Canon eos 400d/xti purchase
When you say the flash is broken, what's broken about it?
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
RobBobW Contributing Member • Posts: 990
I think you did fine.  You would only use the popup flash for fill in and you can always use an external flash on the hot shoe if you want to do any serious flash photography.  My 350D is still going strong and continues to take excellent photos as my back up camera.
Enjoy your "new" purchase!
 RobBobW's gear list:RobBobW's gear list
Samyang 14mm F2.8 ED AS IF UMC Samyang 24mm F1.4
em28 Regular Member • Posts: 266
Is this some kind of joke? That is couple of beers, and i bet you would still be sober after that. Btw, in my country, only one for sale is 220 EUR (but it does include kit lens).
Btw, give it a good clean. I had all sort of problems with my 100D, until i finally cleaned "vents" where AF sensor is. Ok, AF still sucks on any point except center point, but i do get now 3/10 good focus, versus 9/10 failed focus on outer AF points, but i am addicted to opening lens wide, i shoot poor 50mm 1.8 wide open just to get FF look (and i get only soft photos ).
 em28's gear list:em28's gear list
Sony a6000 Canon EOS R Sony E 35mm F1.8 OSS Sigma 60mm F2.8 DN Art Canon EF 50mm F1.8 STM +2 more
OP D148xZ New Member • Posts: 12
It arrived today, the flash shows absolutely no signs of life. I installed 400plus on it for some reason. My grandma gave me three of his old fd lenses, I saw that they were expensive so I thought that I might as well use them.
Doug Pardee
What do you mean by "no signs of life"? Does it refuse to pop up, or does it pop up and refuse to flash?
If it refuses to pop up, does nothing at all happen or does it make some clicking noises followed by ERR 05?
If it refuses to pop up and makes no noise, that's an easy fix:
https://www.flickr.com/photos/dougpardee/133066175/
Canon FD lenses won't fit on an EOS mount. You have to use an adapter. If you use an adapter without glass, you only get close-focus. If you use an adapter with glass, the cheap glass usually wrecks the image quality.
FD lenses work okay on mirrorless cameras with glass-less adapters, but honestly, the state of lens design and manufacture has moved so far ahead over the past 30-40 years that you'd probably do better with some cheap Chinese manual-focus EOS-mount lens.
Wow... That actually worked, thank you so much for your help. It is fully working again!
guinness2
guinness2 Veteran Member • Posts: 4,617
Perfect, Doug ! This is why I like this forum
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
