Blue Skies and Wide Angle Lens Canon 16-35 f4
Started Jun 5, 2017 | Photos
Steve Balcombe Forum Pro • Posts: 15,582
Re: Blue Skies and Wide Angle Lens Canon 16-35 f4
Dale Garman wrote:
I realize that what a posted did have vignette correction. This is all vignetting correction turned off. This reduces the effect, and now the lighter areas are mostly on the horizon. Perhaps that is just how the light looked at this time not sure.
That looks much better. The horizon looks correct too, it's normal for it to be lighter. Notice too how the plants at the bottom previously seemed to have a reflector shining into them - now they look as expected. Problem solved!
RA40 wrote:
As noggin mentioned, some additional reading here:
http://hyperphysics.phy-astr.gsu.edu/hbase/atmos/blusky.html
That's a really good resource - I remember first using it years ago when I needed some info about polarisation, it's great that it's still there. The whole thing (http://hyperphysics.phy-astr.gsu.edu/hbase/ligcon.html) should be compulsory reading for all serious photographers.
RA40 Contributing Member • Posts: 706
Your post corrections are looking good! When there is a "U" or a look similar to shooting through a PVC pipe with tunnel vision that is it. Happens similar at seaside locations with fog, sea spray and sand. Glad that there are resources like this online to reference. You'll spot this occurrence frequently in varying degrees.
For a moment you may have pondered if the 16-35/2.8 would fix this.
Mike:)
 RA40's gear list:RA40's gear list
Canon PowerShot G6 Canon EOS M3 Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 24-70mm f/2.8L USM +10 more
OP Dale Garman Senior Member • Posts: 1,025
Yes I had an EFS 10-18 and thought maybe this fancy L lens would exhibit different characteristics.  But perhaps physics trumps all else.
 Dale Garman's gear list:Dale Garman's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM +9 more
