First impressions on Oly 30mm macro
Started Jun 4, 2017 | Photos
richj20 Forum Pro • Posts: 10,181
Re: High Res madness
Astrotripper wrote:
Soo, here are a few shot with High Res.
This one is the best for me: everything is in sharp focus, and within the DOF. The fine edges of the inner flower parts have excellent resolution.
Another one at 48mp
Have you stopped down more than f/8? If you are concerned about diffraction, run some tests.
A good test is to photograph a cactus with tiny spines. As you stop down, you will see at what point the tips of the spines become less defined.
Other subjects will not be as obviously affected. You will learn how much you can stop down with different subjects.
Do you use the lens as a normal lens as well as macro? I think it is a wonderful focal length combination!
- Richard
OP Astrotripper Veteran Member • Posts: 8,676
Another one at 48mp
f/8 is as far as you can go with High Res mode.
I'm kinda comfortable up to f/11. If I can get the stuff I want in one shot, I will rather stop down than have stuff out of focus. But most of the time, I end up doing focus stacking (in camera or in post).
So far I'm so enthralled by the macro stuff, so this is what I mostly use it for. For casual walk around shooting I have a GM5 with Panasonic 20mm, so I'm unlikely to use the 30mm as a normal prime.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
(unknown member) Forum Pro • Posts: 19,317
Re: What x1.25 magnification looks like in practice
Im with you on this. The concept of 1:1went out with film. The new macro is the most pixels on the subject wins :-).
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
PentaxNick Senior Member • Posts: 1,831
Don
which is why the TG-4,is so good at "macro". Close focus with tiny good quality sensor
Nick
 PentaxNick's gear list:PentaxNick's gear list
Ricoh GR Fujifilm X100T Olympus Tough TG-4 Ricoh GR III Olympus PEN-F +12 more
robert j Veteran Member • Posts: 4,661
Re: First impressions on Oly 30mm macro
Give a $40.00 LED Ring light a try.
43review
43review Regular Member • Posts: 189
Some cheery picking with Oly 30mm
Mine arrived yesterday.
JohnGR
JohnGR Forum Member • Posts: 96
I preferred it with regard to the 60mm lens and until now  I am very pleased.
 JohnGR's gear list:JohnGR's gear list
Pentax K-3 II Olympus E-M1 II Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro Pentax 16-85mm F3.5-5.6 WR +2 more
SteveY80 Senior Member • Posts: 2,087
My main reason for wanting to use artificial light is to freeze subject movement, which LED lighting can't do.
I do actually have a ring flash stuck in a drawer somewhere. I was never satisfied with the results. Shots always looked unnatural compared with ones lit from above with a diffused hotshoe flash.
 SteveY80's gear list:SteveY80's gear list
Nikon 1 J1 Fujifilm X-M1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Sony a77 II +1 more
One from today
Harlequin Ladybird Larva
Nick
gameguru1360
gameguru1360 Regular Member • Posts: 448
Re: Aliens on the moon?
would be nice if olympus or panasonic come out with a macro lens with a built in ring flash.  Canon just released a 35mm f2.8 macro lens with a built-in ring flash with stabilization
"The best way to teach your kids about taxes is by eating 30 percent of their ice cream!"
Bill Murray
 gameguru1360's gear list:gameguru1360's gear list
Canon EOS RP Panasonic FZ1000 Canon EOS Rebel SL1 Olympus E-M5 II Olympus OM-D E-M10 II +2 more
Yeah, before release I was secretly hoping that Olympus will do some innovating with their 30mm. But Canon takes the win with their EF-M macro by not only being wider (44mm eq vs 60 of Oly) but also having this LED light. Both of which I would welcome with open arms.
Sdlv Regular Member • Posts: 357
Re: Lighting with the 30mm macro
To add LED lighting for the 30mm at close magnification, a macro arm light can be useful. I have the JJC version (with 6" flexible arms), as shown below -- see below. I got mine 18 months ago (for about $13) and haven't used it much, but it's the ideal length for the 30mm.
For flash, the Olympus STF-8 is also usable with the 30mm because the two flash units aren't forced to protrude beyond the lens front when turned toward the subject, so that even subjects at 1.0x (about 0.8" working distance) or 1.25x (1/2" WD) can be lit. (I had a chance to demo one with the 30.) It's expensive, however.
I bought the 30mm to photocopy -- for this, it's easier to work with than the 60 -- but it's also a great outdoor still-life lens. However, the short working distances (front of lens to subject) -- 0.25x is roughly 4-1/2"; 0.5x, 2"; 0.75x, 1-1/4"; 1.0x, around 0.8" -- will drive you nuts if you're chasing insects.
. . . Steven
E-M5ii with 30mm macro and JCC Macro Arm Light (each light operates independently)
Thanks for pointing out this option. I just ordered one. While STF-8 looks very nice for stills, I'm not yet sure if I'm gonna get so serious about macro as to warrant such a tool. But this little JJC arm light should be perfect for the kind of video I play around with recently (like this ).  And should do the trick in a pinch outside, hopefully.
