SDQ-H 85 1.4 Art, 17-50 2.8
Started Jun 1, 2017 | Discussions
khaledgawdat Regular Member • Posts: 372
5
my first trial of the SDQ-H. Day light ISO 100. The 17-50 2.8 gives heavy vignetting at the wide end, the 85 1.4 is incredible my son's portrait is great, all pictures are unedited OOC JPG. I need to compare it to the SDQ and SD1 but I am really impressed.
Get a life, before it is too late.
K.Gawdat
 khaledgawdat's gear list:khaledgawdat's gear list
Fujifilm FinePix Real 3D W3 Sigma DP1 Merrill Sigma DP2 Merrill Sony RX1 Sigma dp3 Quattro +108 more
Sigma 17-50mm F2.8 EX DC OS HSM Sigma 85mm F1.4 Art Sigma sd Quattro Sigma sd Quattro H Sigma SD1
motomanDK
motomanDK Contributing Member • Posts: 895
Re: SDQ-H 85 1.4 Art, 17-50 2.8
Really show the qualities of the Q-H and the 85mm.  Great shots!
/Henrik - Denmark
(SD14 and 2 * SD15 and SD-quattro and SDQH ... and about 7 kg glass)
 motomanDK's gear list:motomanDK's gear list
Sigma SD14 Sigma SD15 Sigma sd Quattro Sigma sd Quattro H Sigma 10-20mm F4-5.6 EX DC HSM +9 more
StoryInPictures Regular Member • Posts: 205
Thank you. Uncropped images from the 17-50 are very helpful.
richard stone Veteran Member • Posts: 3,135
I have the standard SDQ (not H) and the 17-50 2.8 OS, and there is of course no vignetting. What is worth noting is how good the images are and how well balanced  the camera is. In context the 17-50 is not a large lens. The OS makes the camera far more versatile.
Richard
 richard stone's gear list:richard stone's gear list
Sigma SD10 Sigma sd Quattro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 30mm F1.4 DC HSM Art
oldfashioned Senior Member • Posts: 1,040
that vignetting is disturbing: but it's not like that's the hood ?
OP khaledgawdat Regular Member • Posts: 372
The vignetting is because the sensor size is larger with a crop of 1.3 on the sdq-H and the lens is designed for the 1.5 crop sensor. I don't think the hood is the reason.
K.Gawdat
thanks  I have the sdqh but I don't have that lens  but I remember similar lenses for cropped with a much bigger black circle than that  when mounted on bigger sensors
that small vignetting only at the corners reminded a wrong hood or a thick filter immediately
a simple shot on wide without the hood and filter could give a definitive answer because you sound right and the hood thing may be wrong but you never know
