NX1100 Problem
Started May 31, 2017 | Discussions
MattyC75 New Member • Posts: 4
NX1100 Problem
Hi guys new to the Forum so go easy on me
For some reason my camera has stopped working full stop, I recharged the battery and the only thing this camera does now is show the power light when you turn it on and when you turn it off the power light is still left on for some reason
Any info would be greatly appreciated guys...
Matt
Samsung NX1100
VisualFX
VisualFX Senior Member • Posts: 1,241
Re: NX1100 Problem
There is no magical way to reset the camera, if it doesn't turn on. Best to find a repair store or send it to Samsung for repair.
 VisualFX's gear list:VisualFX's gear list
Fujifilm X-E3 Fujifilm X-E4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR +4 more
flip 21
flip 21 Senior Member • Posts: 1,439
NO!!!!
No!!!!
Connect it to the USB of a computer, and let it stay there for sometime. It will then recharge normally ... This is a common issue with all NX cameras
Hope this help
VisualFX
Re: NO!!!!
flip 21 wrote:
No!!!!
Hope this help
And what NX camera do you personally own that has that issue?
OP, I suggest you click "ignore" on flip21 too, like i did. He doesnt own any cameras nor take photos to share with us.
flip 21
Re: NO!!!!
VisualFX wrote:
flip 21 wrote:
No!!!!
Hope this help
What? Ignore Flip21? How dare you say something like that.? Bad boy!!!
I own the Samsung NX2, the Nx600, plus the NX50, all prototype models, that were made, but that aren't available to anyone, except some VIPs, like Kisaha, and some Samsung Trolls, like me...
Visual (can I call you Visual?) I had the same problem with some of my Samsung gear ... Hence I believe this is the problem. In fact, I'm almost 100% this is the problem...
PS: about sharing. I love to share, but the problem is that with the Internet, everyone shares, and nobody cares about the owner rights. that is why Piracy prevails. Until there are some good laws to protect the owner rights, I avoid sharing on the Internet my stuff...
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
Re: NO!!!!
I like how you seemingly state this so casually; if I didn't know better, I would assume you're speaking from a vast reservoir of experience. So I will speak from my very limited experience of having owned just seven NX cameras (I still use three extensively), this has never been an issue.
I can't believe I just repeated your use of the word issue . I have stated for years that men haveproblems; women have issues .
Hope this help
BTW, I hope it works too.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
flip 21
Re: NO!!!!
Hope this help
Bu!!!!! I'm not an english native speaker man. For me issue is a problem... I had the same problem with an nx30, and then I read it here that if you connect the camera to the USB it started functioning again, and it did. The camera seemed dead until I connected to the USB port... and then came alive...
I'm only sharing what I learn here. I'm not that experienced. Anyway, my Nx30 is always doing that same thing, and I'm always connecting it to the USB...
I don't share photos, but I try to share knowledge
PS: Well, I found it. here it is:
https://www.dpreview.com/forums/post/57200112
OP MattyC75 New Member • Posts: 4
Re: NO!!!!
flip 21 wrote:
No!!!!
Hope this help
hi again do i keep it turned off once i plug it in via the usb? i cant afford to take it to get repaired so its kind of last chance saloon for it lol
(unknown member) Senior Member • Posts: 2,265
Re: NO!!!!
MattyC75 wrote:
flip 21 wrote:
No!!!!
Hope this help
How about removing the battery and leaving the camera for a week or even a fortnight to allow the internal battery to drain. This will give a hard reset unless stuff is stored in non volatile memory.
It has been discussed in other forums and has I believe worked and is the only way to get this always on kit to actually switch off.
flip 21
Re: NO!!!!
MattyC75 wrote:
flip 21 wrote:
No!!!!
Hope this help
hmm... try both... on and off.
vatazhka
vatazhka Regular Member • Posts: 355
Re: NO!!!!
Hope this help
Battery can't be charged via USB in this NX camera.
Check here if your Samsung NX / NX mini camera & lens firmware is up to date!
 vatazhka's gear list:vatazhka's gear list
Samsung NX1000 Samsung NX mini Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +3 more
flip 21
Re: NO!!!!
vatazhka wrote:
Hope this help
Ups! I didn't know that. Anyway, you can connect the camera to the USB, so you can see what is in the SD card. So it can be charged, or operate, under USB, right? I'm sure this works. And then, you can try recharging it again.This happened to me with an old Samsung device..
Re: NO!!!!
vatazhka wrote:
Hope this help
Hi again still no joy i can't even access the memory card when it is connected to the USB so i can't update firmware..  oh well thanks all for trying
flip 21
Re: NO!!!!
MattyC75 wrote:
vatazhka wrote:
Hope this help
Oh, well... that's the problem of having a camera from a brand that don't support it anymore
Sendeva Regular Member • Posts: 319
Re: NX1100 Problem
Hey lets see if we can find out whats going on with your camera.
Are you sure the battery is getting a charge? (Can use avoltmeter to look for a charge on the battery)
Have you tired a different usb cable?
Have you looked in the micro usb port on the camera for obstructions or damage? (If dust or other obstructions use air to blow it out dont pick it out but if you must be extremely careful not to damage the contacts)
When you plug it into the pc/mac will the computer find a device?
When the camera is plugged in is the charge light on?
When camera is turned on is there any activity from the camera or does it remain in an off state?
If the pc/mac wont see the camera i want you to try this for me:
Turn camera on and plug it into the computer and SLIGHTLY push down/up (not hard) the usb thats connected to the camera and look to see if the computer finds the camera, what we are trying to see by doing this is to find out if there is a bad connection from the usb port to the camera's board.
 Sendeva's gear list:Sendeva's gear list
Samsung NX1000 Samsung NX1 Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +5 more
Re: NX1100 Problem
The battery charges ok with the charger, when i plug it into the pc it doesn't find any device, no charge light on either..  When the camera turns on the only thing it does is a yellow/green light near the menu button(which when you turn the camera off stays on for some reason).. tried the the last step and nothing happens..
Matt
Re: NX1100 Problem
Matt
Ok now i want you to remove the battery and clean the contacts on the battery and on the camera with isopropyl alcohol and a qtip.
Then demount lens, remove SD card, without battery in power on the camera for 15 seconds.
Turn off the camera re insert the battery and turn on the camera (lens is not connected, sd card is still removed) leave camera on for a few minutes.
If it still wont turn on pull the battery, turn off camera, re insert the battery and turn on, do this a few times.
Also the issue might be the battery, do you have a spare to test? If not use a voltmeter to check to see if the battery is putting out the right voltage.
LPencis New Member • Posts: 1
Re: NX1100 Problem
Did you ever get this issue resolved, my camera is doing the same thing and I've tried multiple "fixes" with no results???
