Hen3ry
The Panny f4-5.6 45-175mm in action
May 29, 2017
6
I am really pleased with this lens which I bought this year, used and three or so years old, on eBay.
It feels good on both the G85 and particularly the smaller GX7. It has just that bit more range than the 40/45-150s, and while it has been tested as performing under them (e.g. Photozone.de), I really like the images I am getting.
The lens is light and the zoom ring action is smooth. It zooms internally so there is no change to the physical length of the lens as you zoom in and out. The hood is deep.
There is one thing to be careful of in handling -- the electronic zoom lever on the barrel. The first time I actuated it by accident, I was peering intently through the EVF and was gob-smacked to see the lens zooming in -- and the little zoom graphic on the screen/EVF heading out to 175! (Love that zoom graphic!)
I changed the supplied lens cap for a generic pinch cap at a cost of couple of bucks. much prefer pinch caps -- I can put them on while lens hoods are in place and I can get them on without sticking my fingers onto the lens!
I bought this lens with two objectives in mind:
- To have a moderate, general purpose tele zoom covering an extended range beyond the 45-150, which I was selling. An important factor was modest size since this would be a supplementary walkabout lens (the Olympus 40-150, much as I like it, is actually a little large, comparatively).
- To be my primary close up/macro lens with the Raynox 250 fitted. To this end, I bought a 43-46 step up ring so I could screw the Raynox into the filter thread of the 45-175. The lens's (tiny!) 46mm filter size is too small for the Raynox quick fit clip mount. The huge advantage of this lens over the 40/45-150s is that it does not change physical length when zoomed, so you can set up your camera on a tripod, get focus, then zoom in or out without the physical length of the lens changing and forcing repositioning of the tripod.
So far, the lens has performed right up to my expectations in all areas.
Acting as a medium tele zoom fo0r general work. This is a 100% crop from the bottom left hand corner of the frame. OOC JPEG from the G85.
A 100% crop from a companion shot to the one below.
Walkabout zoom, here with the GX7.
In close-up mode with the Raynox 250. Cocoa beans. Ordinary looking, aren't they? But they sure pack a flavor punch! OOC JPEG cropped at the sides with a small exposure adjustment.
Panasonic Lumix DMC-GX7
Panasonic G85
Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6
Olympus M.Zuiko Digital 45mm F1.8
Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS
+7 more
Comment & critique:
