Comparing EF-S 55-250mm STM vs EF 70-200mm f/4L pictures
Started May 25, 2017 | Discussions
Gudmundur Regular Member • Posts: 124
JPG straight from 70D. iso 100. Focus on house in the middle.
Ef-s 55-250 STM 250mm F 5.6
Ef-s 55-250 STM 200mm
Ef-70-200 f/4L
Conclusion: It is better to take picture at 200mm with EF 70-200mm f/4L and crop the picture to look the same as picture taken with EF-S 55-250mm f/4-5.6 IS STM at 250mm
Sorry for the last image. Can't remove it.
 Gudmundur's gear list:Gudmundur's gear list
Canon EOS 70D Canon EF 50mm F1.4 USM Canon EF 70-200mm F4L USM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-S 18-135mm F3.5-5.6 IS STM +2 more
Canon EF 70-200mm F4L IS USM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EOS 70D
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Comparing EF-S 55-250mm STM vs EF 70-200mm f/4L pictures
EXIF?  Difference in exposure appears greater than the diff in resolution.
The little IS lens is going to be preferred when shooting hand-held with shutter speeds longer than 1/200.
IMHO, YMMV
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
OP Gudmundur Regular Member • Posts: 124
Next time I am gonna make sure the shutter speed is the same.
Comparing these pictures here in 100% details the Ef-s 55-250mm stm lens seems to have little bit more details in dead center of the image at 250mm than the Ef 70-200 L at 200mm .But when you move from the centre of the image Ef 70-200 f/4 L beats it.
jvc1 Senior Member • Posts: 2,202
When you do that, show us how to make the wide end of the 70-200 look like the wide end of the 55-250.
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
Easy . You crop the wide end of the 55-250 to match the wide end of the 70-200
ddixon Regular Member • Posts: 250
I use both an SL1 and a 6D, and both the 55-250 and the 70-200 f4 L (IS version), depending on what I'm doing.
I use the SL1 if I'm traveling light, or if I need maximum reach. On the SL1 I find the two zooms pretty equal in the center but the L lens is noticeably sharper away from center. So, I use the L lens when possible, but don't hesitate to use the 55-250 in certain situations. For example, I'm going on a family trip to NYC in July and will take the SL1 with 55-250 instead of the L lens for the extra reach and reduced weight and bulk.
Note: The 70-200 is noticeably sharper on the 6D than on the SL1, so that's my best IQ combo.
 ddixon's gear list:ddixon's gear list
Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 35mm F2 IS USM Canon EF 16-35mm F4L IS USM +3 more
beagle1 Forum Pro • Posts: 11,742
right, the 70-200 is sharper and faster focusing but the 55-250 is hard to beat for size and light light for traveling   ...  well, actually it can be beat but the 55-200 is more expensive
www.flickr.com/photos/mmirrorless
Same aperture and shutter speed.
Crop
HosseinG
HosseinG Regular Member • Posts: 288
L series lenses have higher quality, sharper pictures. They are heavier and more expensive.
STM lenses are good for video.
 HosseinG's gear list:HosseinG's gear list
Canon EOS 400D Canon EOS 7D Canon EOS 7D Mark II Canon EF 35mm F1.4L USM Canon EF 135mm F2L USM +4 more
ThrillaMozilla Veteran Member • Posts: 7,681
For the 55-250 you need to do the Canon lens corrections, especially the chromatic aberration correction. Then you should find the performance much closer.
The 70-200 also performs extremely poorly at 55mm.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
Abu Mahendra Veteran Member • Posts: 5,312
Did you focus in LiveView or through the viewfinder?
>> I'm already lovin' my Canon 35IS lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
HosseinG
You can do the same for 70-200 too.
you mean at 70mm?
you mean at 70mm?
I think this was just a tongue in cheek remark reminding that in comparing the two lenses, the 70-200 will not cover the 55-70 range
Roberto 21 Regular Member • Posts: 221
The 70-200 looks better, especially on the borders.
 Roberto 21's gear list:Roberto 21's gear list
Canon EOS 5D Mark III Canon EOS-1D X Mark II Canon EOS M6 Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM +10 more
Jon_T
Jon_T Veteran Member • Posts: 6,407
One would certainly expect that the 70-200mm f/4 L would have better IQ; be quite embarrassing to Canon if the 70-200mm f/4 L did not have better IQ than the less expensive EF-S 55-250mm STM IS.
IMHO I would trust the-digital-picture.com for a more accurate comparisons HERE. Or Imaging-Resouce.com EF 70-200mm f/4 L HERE, and EF-S 55-250mm STM IS HERE.
I also have the EF-S 55-250mm IS STM and the 70-200mm f/4 L IS.
No doubt that with 100% pixel peeping comparisons the 70-200mm f/ L SHOULD have better IQ. However with viewing RAW PP images on computer display or prints at normal viewing distances doubt most people would be able to easily see differences between the two lenses.
For general purpose/ travel (12" x 6" x 8") gear bag when size/ weight a factor I have absolutely NO reservations mounting the EF-S 55-250mm IS STM on my 70D along with the 6D with EF 24-105mm f/4 L, and the Sigma EF-S 10-20mm f/4-5.6; i.e., a 16mm - 400mm focal length range.
Been pleased enough of the IQ from the EF-S 55-250mm STM IS along with matching the-digital-picture.com's and Imaging-Resouce.com's results have had no interest in spending the time to do my own image comparisons.
EF-S 55-250mm STM IS; 60D @ 3200 ISO • EXIF Data in image
Jon
Of course you can, but if you do it for the 55-250, you might be surprised at how good the results are. It won't match an L lens, but it is a heck of a lot lighter, and your wallet will be a heck of a lot heavier.
mordor_74 Contributing Member • Posts: 622
Yes, but if there is near nothing to correct there is near no point in doing so.
I think that the L lens philosophy is "the best image that the lens can deliver to you"
While the "Consumer" system philosophy is "the best image that a digatl processing can give you"
I think that everybody is ok with the fact that an L lens HAVE to be better than a consumer one and i am also OK with the fact that for a prowork you need "the best image that the lens can deliver to you" but the result of the 55-250 STMis at least remarkable in its ballpark. Especially compared to other comsumer lenses.
STM Trinity in progress! 18-55+55-255+40 Actually
http://samsungnxtips.blogspot.com
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
Canon Ef-s 55-250 stm is a much better lens than you give it credit for.
Taken from DXOMARK  https://www.dxomark.com/Lenses/Canon/Canon-EF-S-55-250mm-F4-56-IS-STM-mounted-on-Canon-EOS-7D-Mark-II---Measurements__977
Maximum lateral chromatic aberration vs focal length and aperture
Canon Canon EF S 55 250mm F4 56 IS STM on Canon EOS 7D Mark II
Chromatic aberration correction won't do much for the performance of this lens at all.
I actually wrote that you might be surprised at how good this lens is.
It is pretty good for chromatic aberration, but if you look at the posted photos, there is some visible lateral chromatic aberration. Fortunately, it's quite easy to correct for in software or in camera.  If you haven't already done it, it might improve the images further.  For another few hundred dollars the L lens is a heavier but better lens.
