UHS-II SD Card slower when read by non-UHS-II reader?
Started May 25, 2017 | Questions
jeffcarlson
jeffcarlson New Member • Posts: 1
I need a sanity check, friends. I'm testing some USB-C SD card readers and have run into an odd result.
Testing read speeds from a SanDisk Extreme Pro 32 GB UHS-II/280 MB/s card, I get great results when I use the SanDisk Extreme Pro UHS-II USB-C Reader (the one Apple sells), because it reads the second row of pins on the card. Great.
However, when I put the same card into a reader that does not support UHS-II (i.e., it reads just from the first row of pins), I'm seeing speeds slower than when copying with a SanDisk Extreme Pro 64 GB SDXC/UHS I/95 MB/s card.
(I know the speeds listed on the cards are theoretical maximums; I'm mostly using those to differentiate the cards here.)
For example:
Copying 12.9 GB from UHS-II card (280 MB/s) via SanDisk UHS-II adapter: 01:06
Copying 12.9 GB from UHS-I card (95 MB/s) via SanDisk UHS-II adapter: 02:29
Copying 12.9 GB from UHS-II card (280 MB/s) via Cable Matters USB 3.1 reader: 04:55
I get similar results using other readers.
So the question is — thanks for reading this far — is it normal/expected that a higher-rated card should perform worse in most readers than a "slower" card? Is the UHS-II card taking away some throughput from the first row of pins in order to use the second row when using a compatible adapter?
Many thanks in advance for your nerdy help!
Jeff
hotdog321
hotdog321 Forum Pro • Posts: 20,884
Re: UHS-II SD Card slower when read by non-UHS-II reader?
I don't know if this helps, but when I updated to high speed UDMA 7 cards I found that most of my older readers wouldn't even read the card or worked dead slow. Even my Hoodman RAW Steel 3.0 performed poorly--until I contacted Hoodman and found a firmware update for the reader that fixed the issue.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
