XF 60mm v 50mm F2 for macro
Started May 24, 2017 | Discussions
jasimpson Forum Member • Posts: 90
On another thread I was discussing that I would like a lens which can do both portraits and macro work. I enjoy macro a lot more than portrait but I am attending a lot of weddings this year and want something which is double use.
So I just wondered if people could post some of there macro shots with both of these lens so that  I could compare
Many thanks for all your help in advance.
James
io_bg
io_bg Senior Member • Posts: 1,548
Re: XF 60mm v 50mm F2 for macro
For macro one would naturally consider the 60mm even though it's not a true macro lens (doesn't offer 1:1 magnification). As for portraits, 60mm is a bit more flattering focal length. However the new 50mm is faster to focus. I've the 60 and it has a great rendering and I've only looked at samples from the 50 which also seems to produce nice images.
Here's a close up from the 60 which IIRC is taken at the minimum focusing distance:
And here's a portrait:
Considering you'll be shooting mostly macro I think the 60 is the way to go.
Hope this is of any help to you.
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
bs1946
bs1946 Veteran Member • Posts: 7,778
As far as I know, the new 50mm f2.0 is not a macro lens. The 60mm f2.4 is a 2:1 macro lens. If you want a new true 1:1 macro lens than your current choices are the Zeiss Touit 50mm f2.8 Macro or the Samyang/Rokinon 100mm f2.8 Macro. Or, you could wait for the new Fuji 80mm macro to be released next year or get an adapted Canon or Nikon macro lens, which is what a lot of macro shooters seem to do.
Bill S.
billschaffel.500px.com
instagram.com@billschaffel
When all else fails, maybe it's time to read the manual.
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
MariusMasalar
MariusMasalar Forum Member • Posts: 92
I think you might find the 60mm to be frustrating in a wedding context. It's among Fuji's best lenses, optically, but it's slow enough that I would not feel confident deploying it in a shooting scenario that required fast AF.
The 50mm ƒ/2 is a rocket ship by comparison. Slows down in low light, but it's significantly more reactive in general. Not a great macro lens though, so if that's the priority then you're still better off with the 60mm.
Basically each of the lenses you mentioned excels at only one of your required shooting contexts, and is pretty bad at the other.
Your best bet might be option 3: the 50mm plus one of Fuji's macro extenders—that would get you good AF for weddings and a much better working distance for macro.
Here's an example I shot recently with the 50mm ƒ/2 + MECX-16 extender for reference:
 MariusMasalar's gear list:MariusMasalar's gear list
Nikon Z6 Nikon Z 50mm F1.8 Nikon Z 35mm F1.8
(unknown member) Contributing Member • Posts: 832
I never used the 50mm but I have, a few months now, the 60mm. Not going to say it's a speedking, not going to say my X-Pro1 is a speedking, but when I tested this combination during the Carnaval it works out fine. For me and my kind of photography this combination is fine. If you have worries about the speed you need to take weddingphoto's go to a shop and try both lenses. I think they're both great for portrait. Macro, I think the 60mm might be better. But there is an 80mm macro on the way, as rumors say . . . .
OP jasimpson Forum Member • Posts: 90
Thanks all. I should of said that I realise that the 50mm wasn't a macro lens. Also both of these lens are in my budget that have auto focus. The other macro choices don't.
Does the minimum focus distance change with the macro tubes and the 50mm.
Does anyone know what the focus is like on the 60mm under artificial lighting and in poor lighting is really that bad?
csxfan
csxfan Regular Member • Posts: 467
having just used the 60 for a photo shoot on monday, i will say that it is a slow lens when doing inside work. the client had excellent lighting from the overhead lights and natural lighting from outside, so lighting wasnt an issue. it was slow to focus and just getting a focus lock was a chore. now having said that, the iq of the pictures was beyond excellent and worth the extra time. I also had the 50 f2 available to me, and it was faster and easier to get a lock. Images quality was also excellent.
under low lighting imho, the 60 can be a bit of a challenge. so if a majority of your shots are going to be in low light, get the 50, else the 60 could fit your bill.
cheers
 csxfan's gear list:csxfan's gear list
Sony Alpha DSLR-A700 Pentax K-5 Canon EOS M Fujifilm X-E1 Fujifilm X-T1 +15 more
MariusMasalar
Minimum focus distance does change with the extenders, yes, and your working distance becomes much smaller, especially with the MCEX-16.
The lens will no longer focus past a certain distance, so it's a case of putting the extender on as a deliberate "I'm shooting macro now" thing.
Thanks for the information. So I was thinking that maybe I would use the lens in the evening as well for the reception and dance floor but this is looking more and more unlikely, I'll probably just have to stick the kit lend or get another prime.
cheers
drewmey123 Regular Member • Posts: 248
James
If you want the dual use you speak of, I would definitely get the 60mm. If you are looking solely macro, I would think a 1:1 magnification option with an adapter would be preferable. You are going to be manually focusing anyway. Maybe the Tamron 90mm macro which is in the same price range.
If money were no object, a 90mm macro and the 56mm 1.2 would be my choice. But in my case (and many others) money IS a factor. Personally I don't shoot much macro, even when I had one for Canon, so I just bought the 50mm f2.
 drewmey123's gear list:drewmey123's gear list
Fujifilm X-T2 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 16mm F1.4 R WR Fujifilm XF 35mm F2 R WR Fujifilm 50mm F2 R WR
