Sony & The “Star Eater” problem
Started May 24, 2017 | Discussions
nandbytes Senior Member • Posts: 5,972
Yay!!
Ari Aikomus wrote:
Hi,
This was a happy morning Sony released a new firmware updates...
http://www.sonyalpharumors.com/sony-releases-new-firmware-update-%ce%b19-%ce%b17-ii-%ce%b17r-ii-%ce%b17s-ii-%ce%b16300-%ce%b16500/
v. 4.0 for A7RII
I already installed (without problems), and I'm very glad to tell: Star eater is fixed! At least 4sec-30sec exposures... I'm not sure about bulb yet, I have to try it more carefully ...
Anyway, this was a great news. I almost feel that our hard work would be rewarded
Thank you sony,
Ari
Thanks for confirming.
Did you have to turn off LENR?
 nandbytes's gear list:nandbytes's gear list
Panasonic LX100 Sony Alpha a7R III Canon EF 100-300mm f/4.5-5.6 USM Sony FE 85mm F1.8 Sony FE 35mm F1.4 +2 more
Bill Gercken 2 Forum Member • Posts: 84
Re: Happy UPDATE! Star eater fixed! Thank you Sony....
Awesome!
English native speaker, so please ignore any misspelling generously!
Navman Regular Member • Posts: 278
Ari Aikomus wrote:
Hi,
v. 4.0 for A7RII
Thank you sony,
Ari
I just installed it and did a very quick test - its one night off a full moon here, so not ideal, but the 3.2 and 4 second exposures that I took are identical apart from the slightly greater star trailing in the 4 second. It looks as if they've fixed it.
Thanks so much for all your persistence with this Ari - you deserve a medal!
-John
Ari,
Can you try it with LENR on? Does it effectively just turn star eater on if you do that?
Then the question would be, what to do for dark frame subtraction? I don't have a solution for that for Sony raw files. Anybody?
Cheers!
-bill
Magnar W
Magnar W Senior Member • Posts: 2,875
Courious about Bulb...
 Magnar W's gear list:Magnar W's gear list
Sony Alpha a7R III Sony Alpha a7 Zeiss Loxia 21mm F2.8 Zeiss Loxia 35 Zeiss Loxia 85mm F2.4 +2 more
ISO 1 Million Regular Member • Posts: 461
Thank you so much Ari for your persistence in this issue.  We need more people like you who can be objective and willing to criticize the companies they purchase from.  All these Sony cheerleaders do a complete disservice to all of us.
 ISO 1 Million's gear list:ISO 1 Million's gear list
Sony Alpha a7R II Sony Alpha a7R III Sony FE 55mm F1.8 Sony FE 35mm F1.4 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +5 more
Almazar80 Senior Member • Posts: 1,045
Persistence pays - and it helps that you and other people (JimKasson) has been pointing out his problem for months.  The scientific testing methods that Mr. Kasson employs is really useful in identifying problems and other anomalies in the Sony cameras.  And as you said, thank you Sony, for listening.
FotoFrik
FotoFrik Forum Member • Posts: 85
Re: Sony & The “Star Eater” problem
New firmware of solving the problem of
Improved Image Quality When Long Exposure NR setting is OFF
 FotoFrik's gear list:FotoFrik's gear list
Sony Alpha a7 II Sony a6500 Sony Alpha a7R II Sony FE 55mm F1.8 Sony FE 28mm F2 +5 more
FF Pro
FF Pro Senior Member • Posts: 1,412
Bill Gercken 2 wrote:
Ari,
Cheers!
-bill
Capture One does wonders for Sony RAW files without LENR on prior to the 4.00 FW so I wouldn't think that would change?
 FF Pro's gear list:FF Pro's gear list
Sony Alpha a7 Sony Alpha a7R III Sony FE 35mm F2.8
BBQue Senior Member • Posts: 7,334
*** CONGRATULATIONS ARI !!!! ***
I want to believe that your incredible persistence in this matter played some part in this. Good news for all owners of A7rii !!!
mreynolds767 Senior Member • Posts: 2,284
Take a bow Ari!
Persistence by you and others made this happen, bravo!
online gallery at:
www.MattReynoldsPhotography.com
 mreynolds767's gear list:mreynolds767's gear list
Sony Alpha a7R II
getagrip15 Regular Member • Posts: 463
Quick question...does the A9 still have this spatial filtering issue? It appears that the update fore this was for the A7rii and A7sii.
I'm not super concerned since I don't do astrophotography...but just curious.
Jonneymendoza2 Contributing Member • Posts: 835
mreynolds767 wrote:
Take a bow Ari!
i also persisted on the opening of the lens while shooting in AF-C which is also fixed
Trollmannx Senior Member • Posts: 4,461
I am also interested in the A9 and the long exposure behaviour of this camera. Seems like a mind blowing camera - just this one issue is holding me back...
Now it is time to sit back and wait until someone image the stars with a very sharp lens (like the 1.8/55mm stopped down to f/4 or so, to really tease out the new algorithm) or a first class telescope like a Takahashi astrograph. That should settle the matter.
Still holding back until some thorough test results show up here.
Am a northener living under very bright summer skies at a high latitude so no possibility to run the proper tests needed from here - have to wait for the autumn darkness.
The star eater issue have been discussed for some years now. Good to see the issue finally getting (most likely) the proper medicine due to persistent ones around.
That's true Sony really did apparently listen and provide fixes for more than just 1 issue with this firmware.  Many studio folks were very unhappy with the stopped down AF should be quite pleased today as well!
Sony Alpha a7R II
JerseySailor Regular Member • Posts: 191
In reading the feature list of the 4.0 update, I didn't see a mention of fixing long exposures longer than 3.2 seconds (i.e., Star Eater).
They did say: "Improves image quality when Long Exposure NR setting is OFF"
Was that their Star Eater fix?
 JerseySailor's gear list:JerseySailor's gear list
Sony Alpha a7R II Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) Sony 70-400mm F4-5.6 G SSM Sony FE 24-70mm F4 OSS Sony FE 24-240mm F3.5-6.3 OSS +2 more
Yes, because previously NR was being applied on files between 4-30 sec. when the user had selected RAW and LENR off meaning they don't want any added NR.
The Star Eater was in camera applied noise reduction
Sony Alpha a7R II
Yes - it seems Sony avoids the word "Star Eater" - they don't want to acknowledge that there ever was a problem. Just a series of improvements
Ari Aikomus
OP Ari Aikomus Veteran Member • Posts: 9,339
Re: *** CONGRATULATIONS ARI !!!! ***
Thank you
Maybe my effort played a small role in this...
But I'm very happy that star eater issue is now fixed.
Happy shootings,
Ari
Ari Aikomus
We all Sony users are kind of big a family, no matter if we have different opinions. But I'm very glad that this ended well after all.... Also - Thanks  to Sony that they "listened" finally
Happy shootings,
ari
