Optically how good is the EF-M 55-200 IS STM lens?
Started May 24, 2017 | Polls
Hombre de Maiz Regular Member • Posts: 273
To those who own or have owned the EF-M 55-200mm IS STM lens, the following question:
In terms of image quality, how good is the EF-M 55-200mm IS STM lens?
POLL
Excellent
37.5% 21  votes
Good
39.3% 22  votes
It's ok, so-so, average
14.3% 8  votes
Quite mediocre and underwhelming
5.4% 3  votes
A real dog
3.6% 2  votes
  Show results
(unknown member) Senior Member • Posts: 2,153
Re: Optically how good is the EF-M 55-200 IS STM lens?
Side note, DLO via DPP4 turns the 55-200 into an L practically.
OP Hombre de Maiz Regular Member • Posts: 273
You say this as praise or criticism of the lens? Some could interpret this to mean that the lens cannot hold its own optically, and that significant PP hacks are needed to make it a good performer. Please cast your vote without regard for DLO or individual PP application since the poll is about the lens's optics, not about digital signal processing. You know that. Thanks.
Both.
Some lenses clean up well with DLO, others, DLO can't help to save it's life. The 55-200 is one of those lenses that it really helps with, not that it was bad to begin with but there is some CA it cleans up very nicely. Optically speaking, it clocks an insane almost 4,000 lines in the center wide open; doesn't do so well in the corners so it's subjective. I personally think center counts more than corners. I cast an excellent and stand by it, at least my copy anyhow.
Now if you asked me how well the IS performs (not the optics) I'd say crappy. That's one thing Canon could easily do a mark II of the lens with. You really need to shoot at least your shutter speed in terms of focal length which isn't that big of a deal as you can always push more shutter to compensate for meh IS (at least my copy once again). That and nano-USM of course would be welcome. The 18-150 does focusing and IS better (you can easily shoot between 1/15 and 1/40 at 150mm depending how careful you are for example, which there is no way the 55-200 can do), but is optically inferior vs the 55-200, no offense to the 18-150. The 18-150 on the other hand, is more optically distributed and handles corner sharpness better; obviously Canon's been adapting their optical formulas to favor distributed sharpness. So for example the 55-200 is sharper in the center vs the 18-150, but the 18-150 is sharper in the corners, in some circumstances than the 55-200.
Lightgreen wrote:
Both.
Great. This has been discussed on a handful of separate threads already. The goal of this poll is much simpler. Register your vote. Thanks.
Abu Mahendra Veteran Member • Posts: 5,312
23 votes in, the lens has an average rating of Good.
>> I'm already lovin' my Canon 35IS lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
Lumens77 Regular Member • Posts: 436
Excellent lens with good IS BUT.... IS is lagging. You need to wait half a second to benefit from fully engaged stabilisation. If you don't or if your subject has moved by then in one shot mode half pressed shutter you might obtain a blurry image and blame the optics. So this lens has a learning curve but is stellar properly used.
 Lumens77's gear list:Lumens77's gear list
Sony a7 II +24 more
plantdoc Veteran Member • Posts: 4,339
Strange about the IS since it is always ON if the camera is ON.
Greg
Michal Minich
Michal Minich Forum Member • Posts: 74
Greg
I noticed long time ago with 400D the 15-85 IS is fully on only when shutter button is half pressed. Otherwise it was only proximately half or third on. This was clearly visible when looking trough viewfinder. I assume this is to save battery.
 Michal Minich's gear list:Michal Minich's gear list
Canon EOS M5 Canon EF 50mm F1.4 USM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4 +6 more
robbert100 Contributing Member • Posts: 714
Size wise it is a nice lens but optically the EF-S 55-250 4.5/5.6 STM is a better choice if size and weight isn't a show stopper. The MFD of the 50-200 is a bit disappointing, another strong point of the EF-S 55-250.
But the compactness of the EF-M 50-200 is unbeatable!
Best regards,
Rob
www.namaqualand.wordpress.com
 robbert100's gear list:robbert100's gear list
Canon EOS M Canon EOS 7D Mark II Canon EOS M10 Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM +2 more
AndyC400D Regular Member • Posts: 147
I haven't used the lens that much, yet, but what I will say is that compared with the size and weight of the 70-200 f/2.8 IS USM II on a 7D Mark II body, I'll forgive a fair amount of sharpness for the portability.  Having said that, it's not really that much of a compromise.  The images I've taken are plenty sharp enough to warrant large size prints.
What I will say, is that I'm having to re-learn how to hold the camera steady.  At the 200mm end, getting a sharp shot at lower shutter speeds is very different from holding 2.3kg of camera and lens against your nose.
 AndyC400D's gear list:AndyC400D's gear list
Canon EOS Rebel T4i Canon EOS 7D Mark II Canon EOS M6 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Canon EF 70-200mm F2.8L IS II USM +7 more
