Focusing using manual lenses
Started May 22, 2017 | Questions
gaetanonline Regular Member • Posts: 117
Hi!
I love my Pentax and I sometimes use manual lenses with it.
I have da problem about focusing. I use catch-in-focus and all settings are fine.
I see camera always use center point to focus.
When I shoot half-lenght portraits at f.2/8 eyes are out of focus.
I tried to "focus and recompose technique" but I still have the same problem.
In my opinion that's because the focus point is not the head (the eyes) but it's lower, so even if focus plane is in focus, focus point is not.
Maybe I could solve the problem using smaller apertures f.5/6 or shooting only headshot for portrais
How do you suggest to solve the problem if I want to go on using manual lenses?
 gaetanonline's gear list:gaetanonline's gear list
Panasonic Lumix DMC-LX3 Olympus PEN E-PL1 Pentax K-r Olympus PEN E-PM1 Pentax K-50 +12 more
newmikey Veteran Member • Posts: 5,203
Re: Focusing using manual lenses
gaetanonline wrote:
Hi!
I suppose with portraits you'd want to either focus in live view or use a split-image focusing screen. Catch-in focus is incredibly handy and powerful but as you have noticed it does run into an issue in specific situations such as close-up portraits. Of course, increasing DOF by using a smaller aperture will also work but will defeat the main reason of using such lovely f2.8 lenses to begin with.
 newmikey's gear list:newmikey's gear list
Pentax KP Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 85mm F1.4 EX DG HSM Pentax 16-85mm F3.5-5.6 WR +2 more
Fenwoodian Contributing Member • Posts: 596
To get "critical focus" 100% of the time use:  manual focus, a Zacuto viewfinder and live-view.
I have Zacuto viewfinders attached "permanently" to both of my K1 cameras .
I now never have blurry images.   They are always in focus.
When shooting with a viewfinder you will need to both magnify the image on the LCD screen while focusing, AND have focus peaking enabled.  Read your camera manual on how to do these things.
 Fenwoodian's gear list:Fenwoodian's gear list
Pentax K-1
OP gaetanonline Regular Member • Posts: 117
Thank you for your suggestions.
Sorry to ask, but how can I enable focus peaking on my K-r? I can't find it in manual, maybe in italian it's called in different way
klimbkat
klimbkat Senior Member • Posts: 2,659
gaetanonline wrote:
Hi!
Consider changing your in-camera focus point to one closer to the eyes.  Also, consider experimenting with a model (anybody) to see where on a person you should focus to achieve the desired result when you recompose.  Finally, experiment with each lens more generally with varied targets to determine whether or to what extent the focal plane is curved, knowledge that will help you with your recomposition.
I can't change my in-camera focus point. My Pentax K-r focus only in the center using manual lenses. For the picture I want to shoot if camera take focus just in the center eyes would be always out of focus because focus point would placed lower, though focus plane is the same.
can you explain me better your technique?
Holger Bargen Veteran Member • Posts: 4,911
I use the viewfinder loup O-ME 53. It helps me to get a better impreesion about the sharpness.
Next point is to adjust the dipper correction of the camera correctly. If you see the writings/signals in the viewfinder sharp and clear the diopter setting is OK.
I don't use the sharpness trap of the camera as I want to decide when to release.
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
klimbkat
When you say "focal plane" you need to know for your lens whether it is flat or if there is some curve (common). Remember, as a matter of geometry, the distance from the lens to a range of subjects is not flat but, rather curved.
https://photo.stackexchange.com/questions/73687/what-is-the-shape-of-the-focal-plane
Do some testing with your lens wide open (f/2.8) to see if and to what extent you have such curvature.  For example, shoot at an angle towards a subject with many points of definition such as a lawn, then review to see where the focal pattern falls.
Once you have a better sense of how the lens works, you can adapt your focus technique to achieve the result you wish.  For example, if you find that when you focus on a person's chest the focal plane is in front of the eyes, back off the focus slightly.  You can determine this by using a home-made scale (say an 18" piece of wood with whit paper attached and lines drawn every inch) held by your subject at a 45 degree angle next to the head.  The focus on various parts of the body to determine the best point for getting the eyes in focus.
Hope these thoughts are helpful - good luck!
James O'Neill Veteran Member • Posts: 6,117
gaetanonline wrote:
Hi!
I think this has always been the case, if the lens is manual you get center point confirmation - it's true on the K1 and I think it was true right back to film
The simple answer is to shoot with a smaller aperture and more depth of field but I am guessing that you want shallow depth of field to isolate the subject from the background.
I think it is more to do with the field of focus of the lens, if you focus on a brick wall 2M away, the bricks at the edges of the frame are sharp but they are further from the camera than center brick. So the field of focus isn't an arc from circle 2M in radius, it is flattened (but not perfectly flat either). If the middle of the frame is focused at 2M something exactly 2M away at the edge is just a little too near the lens. So focus and recompose is not perfect , and will vary from lens to lens.
Shooting only headshots and moving closer would mean you had a shallower d.o.f so the problem might be worse.
Two ways. One is to just live view and/or a magnifier, or any other focus aid you can get. The other is through practice to know that if focus a little short when you recompose things will be right, but you need to learn how short to focus.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
Skip py Senior Member • Posts: 1,157
Hi
Another one, cheaper and easier to use I guess, is the magnetic LCDVF (probably the 4:3 model for 3'' screens if it the size for k-r ?).
Drawbacks :
- you have to glue something "permanent" to the back of your camera
- you have to clean the screen first, then put the base on the screen and keep something heavy for one night on it to get a good contact (some users reported it could take off : I never experienced such a thing)
- always take firmly the camera, not the LCDVF : magnetic power is enought to keep it on the camera ... not the other way round !
- no diopter if you wear glasses (well, I use it with glasses too and that's ok for me)
- really BIG with small camera and lens : see below O-ME 53 is more inconspicuous !
- depending where you live you can find it at different prices it seems !?
Advantages :
- when it's well glued, just put the LCDVF on it and that's all, take it off and put your camera in your pocket
- nice to have for video or photography as it helps stabilize the camera
- you can use focus peaking, if available on you camera, to get the focus where exactly you want, with a BIG viewfinder, even on a sunny day
Regards, Fred
K01 + wide angle 15mm f/4 : not a pancake, but too small for the LCDTV
 Skip py's gear list:Skip py's gear list
Pentax K-01 Pentax K-3 Pentax K-1 Sony a7R III Sony a7 III +6 more
Browntee Regular Member • Posts: 100
If you are using manual focus lenses and relying on the camera to tell you when it is in focus either with the focus trap method or the focus confirmation beep, a focus adjustment may be needed to ensure that the lens is infact in focus when the camera thinks it is.
I was struggling with manual focus with my old helios lens so I did a focus test and found out it was way out. I adjusted and now I am getting much better results
Hope this helps
 Browntee's gear list:Browntee's gear list
Pentax K200D Pentax K-3 II Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc DA 12-24mm F4.0 ED AL (IF) +6 more
Hope this helps
My lens is a Helios too.
Which kind of adjustment do you mean? Do you mean just focusing manually?
Are you using lcd screen and magnifier?
MightyMike Forum Pro • Posts: 41,691
Which lens? Which camera? some manual lenses due to spherical aberrations seem to do better when the global AF adjustment is set to -10 (don't forget to turn this off when using a different lens). also some lenses have a focus shift from wide open to stopped down this potentially could be an issue. Also note that the focus point is rather a lot larger than the dot that appears in the OVF and anything within that point could trigger the AF to think somethings in focus. Finally if you're using the K-1 something has changed, where i could get amazingly accurate pinpoint focus with manual lenses on the K-3 and older bodies the K-1 seems to want to trigger early regardless of which direction you're focusing. on static subject i went from getting most of my shots dead on to 2 out of 3 early triggers (using burst) before one that is appropriately in focus, For action photos i went from 2 of 3 in focus to 1 of 3 in focus after switching to the K-1.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Kerusker
Kerusker Senior Member • Posts: 1,446
Mike,
knowing your professionalism and reputation, I trust in your findings.
I.e. focusing from far results in BF and from near in FF?
Personal note:
By time I got tired in investigations like yours above and trying to setup adjustments or work arounds. For my kind of photography (mostly of personal and family use) I get around with simpler cameras. My old Pentax M , A and FA lenses don't require more than my K-5II - I think.
Mike, thanks for all your contributions and images of course.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Sony RX10 IV Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited Pentax K-5 IIs Pentax smc FA 50mm F1.4
You have to determine if you think the lens is front focusing or back focusing then using the focus adjustment option in your menu to correct the focus
A lot of people do not think of doing a focus test with a manual focus lens, but if you are using the focus confirmation of the camera, the focus calibration should be checked
Check out the link below. He is adjusing a different camera brand.. but the principals are the same
I have  helios 44-m and once I got the focus calibration set I achieved much better results
https://youtu.be/52fBIp4BI84
I always use focus trap with this lens and like the results I get. It's a fun lens to use...
Kerusker wrote:
Mike,
Yes this is how it behaves
Personal note:
][.Kerusker
Mike from Canada
hanhait Senior Member • Posts: 1,296
In my experience the central area the focus confirmation reacts upon is rather extended, and within that area he reacts on the closest point, or maybe the first point that is in focus.
 hanhait's gear list:hanhait's gear list
Pentax K100D Pentax K-5 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Pentax smc D-FA 100mm F2.8 Macro WR Sigma 70-300mm F4-5.6 APO DG Macro +9 more
