New to m4/3, little dissapointed
Started May 18, 2017 | Discussions
Pete_W
Pete_W Senior Member • Posts: 2,838
Re: I have exactly the same problem
Gary from Seattle wrote:
I blew up one of my images shot at ISO 12000, Aperture F22 and when blown up to billboard size when looked at with a 15 power loupe, it is not perfectly sharp!
Rookie error. You need to use an air blower on your sensor before every shot. Problem solved.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
Halina123 Senior Member • Posts: 1,632
Re: New to m4/3, little dissapointed
I believe in the goodness of people and that everyone deserves the benefit of the doubt, even if their opinions and the way they express themselves set of alarm bells inside me.
But you sound like a one post troll!
Ulric Veteran Member • Posts: 4,559
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
Kelpie Regular Member • Posts: 448
Sounds like shutter shock.
 Kelpie's gear list:Kelpie's gear list
Canon PowerShot G3 Nikon D300 Olympus E-1 Olympus E-30 Olympus OM-D E-M5 +21 more
cpt kent Contributing Member • Posts: 606
Re: Whoosh...
hindesite wrote:
...what on earth is wrong with people round here?
  1. username, check
  2. number of posts, check
  3. exaggerated claims, check
  4. lack of information,check
  5. dissing on m4/3, check
Yet, despite all that, almost all the replies in the thread are serious?
6. Starts thread then makes no further contribution (has places to go, other folks to troll)
(unknown member) Veteran Member • Posts: 7,274
Sure...
Having much fun?
You know how to pull a leg about pixel peepers and gear heads incapabilities to handle common photography...
Bravo!
Re: I wish that
Photo Pete wrote:
I wish that people replying to this sort of thread would change the title of their post. I don't know if the OP is a troll or not, but if they are then they have successfully multiplied the chances of a search engine finding hits which indicate disatisfaction with the camera format due to the fact that the title is repeated in each response.
They say "There is no bad publicity"...
I actually think we should take seriously the OP and break down the problem. As the problem isn't in the OP, the problem is actually on the responders not getting few basic things about common photography.
This! VVVV
Ulric wrote:
You need to print much, much larger.
You bring up the exact point about common photography requirements and real world limitations.
When looking the OP image, you can see there is nothing wrong in it, contrary it is very sharp and detailed that would definitely be capable to be printed up to 40" with fine details, or then just jump to huge prints like behind your link, where it doesn't anymore matter what megapixel race there is going on.
Martin.au wrote:
800%?
I think you need to stop doing photography. Perhaps take up testing callipers as a hobby.
I think you are one of the few who noticed about that. A 800% enlargement with pixels clearly visible and talking about pixel peeping
And then some say that the kit lenses are soft, while I don't know what kind a details do others here even consider to be expected to be results when looking at those 800% ones where your details are down to single pixel size! You can't go sharper than that!
But pixel peeping, like gear headiness is a serious illness and it is difficult to be cured from it. Like look the OP post, says that the prints looks great but then the digital image looks soft. That is because two totally different mediums, different outputs, different ways to use the photographs etc. A pixel peeped digital image can show serious differences, but huge prints can show no noticeable difference (negligent difference) that puts every compared photo to be identical, or so close to such that it doesn't matter.
800% and those details in the flowers or the stick and seems that the lady has had stockings, and people say that 4/3" can't deliver details for large prints?
But if the illness of pixel peeping is so advanced, it requires more common photography to be done. And for that a E-M5 with a kit lens (what lens?) will still today perform great what comes about sensor. But I wouldn't buy a E-M5 used, if used a too little or too much, so you can see it is "driven in" and "not weared out" either.
Did you calibrate your printer heads? Sounds like they are knocked off....
AccursedSpermaceti Contributing Member • Posts: 554
Add a small amount of diamond dust to the sensor to sharpen the image.
Photo Pete Veteran Member • Posts: 5,430
There IS bad publicity, but we should respond politely
They also used to say the world was flat
Yes. The OP should be advised with responses which are informative and respectful... each posted under a suitable new post title which reflects the response, rather than just a reiteration of the original title. Changing the post title is good posting etiquette anyway.
But, hey, it's a forum and people are free to post how they want as long as it doesn't contravene the dpreview forum rules.
Have Fun
Photo Pete
dinoSnake Veteran Member • Posts: 3,570
Re: There IS bad publicity, but we should respond politely
Perhaps you might have noticed that the OP, which 'should be taken seriously', has only 1 post - this one - done 22 hours ago?  Which means that they aren't even serious enough to reply to their only post after almost 1 day?
Yes, the post may be an honest one but the signs are not promising.
s_grins
s_grins Forum Pro • Posts: 14,011
Changing the title
It is not a post, it is a poop that bird dropped flying over...the nest.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
Gary from Seattle Veteran Member • Posts: 7,852
Whoa...give me a break you guys. Ok, here is the proof. The pixies just aren't sharp enough. Still, it is a nice image to have hanging on my wall. But, really, I wish I had shot it with my cannon.
Foggy day at the beach just after sunset.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
fuego6
fuego6 Senior Member • Posts: 2,525
thought the whoosh sound was my Delete Recycle Bin noise...
  1. username, check
... can we lock this thread please?
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Quick, send that camera back!!!
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
WhiteBeard
rsmithgi wrote:
I can't tell anything from the image you posted. Maybe post a full size version of the original image.
I think you're missing the point here...
George1958 Senior Member • Posts: 1,475
What? A Sony user buying M4/3?
Seriously, have a look at some of the ample good stuff on flicker and then your own stuff if your output is very different it's probably you and not the camera.
 George1958's gear list:George1958's gear list
Sigma DP1s Sigma SD15 Olympus PEN E-P3 Sigma sd Quattro Olympus E-M1 II +6 more
victorul Regular Member • Posts: 168
Re: Whoosh...
He threw a bone in the M4/3 crowd and everybody fell for it.
 victorul's gear list:victorul's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-ZS15 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G6 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
