New to m4/3, little dissapointed
Started May 18, 2017 | Discussions
peeppixel New Member • Posts: 1
Hi all!
I buy a used camera from a friend, the E-M5 with 14-42 kitlens to compensate a broken NEX-6 and kitlens. But I am not so happy about the digital quality I get. I do prints in local one hour photo and their max is 40x30cm for 5,99 euros and then I did a two test images and they are great and sharp but the file just lacks the punch.
800%
pixel peeping some of the details and they look somewhat soft on computer.
Should I sell it off or buy something better? I love the size and handling! Would the 12-40mm be better or just get a 20Mpix?
Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus OM-D E-M5 Sony Alpha NEX-6
fft2000 Contributing Member • Posts: 987
Re: New to m4/3, little dissapointed
7
Probably the best would be to look for a new viewing software that uses better sacling algorithms when viewing at 800%?
[if 30x40 prints are great why view at 800%? Look for another place where you get 60x80cm prints and I am sure it will be sharp ad great, too.]
rsmithgi Senior Member • Posts: 2,939
6
I can't tell anything from the image you posted. Maybe post a full size version of the original image.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus 40-150mm F2.8 Pro +5 more
Dennis12345 Regular Member • Posts: 293
Ditto.
 Dennis12345's gear list:Dennis12345's gear list
Ricoh GR Digital II Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II
(unknown member) Veteran Member • Posts: 7,274
I think you don't get it.... You are not pixel peeping
Seriously, download the file and peep it at 100% and you get it...
Day Hiker Forum Pro • Posts: 10,829
always will be disappointed
18
Judging from your user name, you are one of those people who will never be satisfied with the results from a sensor as small as µ4/3. Yes, there are differences. To a vast majority of people, the differences do not manifest themselves in any relevant way.
If you really crave more image quality, you must buy a good camera with a larger sensor, spend the money on a quality lens (prime?) that can take advantage of the larger sensor, and use careful technique so as not to degrade the image at the time of exposure.
I'm not saying that your disappointment is unwarranted. I just have a feeling that µ4/3 may not be where you should be.
peeppixel wrote:
Hi all!
800%
Jim Pilcher
Summit County, Colorado, USA
Life is good in the woods. All paths lead forward.
Robin U Contributing Member • Posts: 592
6
Interesting comments.
Since you are pro, and a pixel peeper, sell everything to cut your loss.
Why not consider a full frame digital camera , or a MF digital camera like the MF Fuji, or MF Hasselblad?
Report what you decide to get.
Good luck.
 Robin U's gear list:Robin U's gear list
Olympus PEN-F Panasonic 12-35mm F2.8 Apple iPhone X +2 more
pannumon Veteran Member • Posts: 4,130
6
For pixel peeping purposes, those images look oversharpened with too large sharpening radius. Changing the radius/brush size should help.
The kit lens is still just a kit lens, don't except miracles at pixel level.
Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GM1 Panasonic G85 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GF1 +21 more
jwilliams Veteran Member • Posts: 6,400
Try this
Buy a good prime.  Inexpensive, but good ones are 20/1.7, 25/1.7 or 1.8, 45/1.8, 42.5/1.7.  Any of these will produce results much better than the kits lens.  Next shoot both RAW and JPG and see how much more the photos are to your liking once you process them yourself.
Jonathan
knickerhawk Veteran Member • Posts: 7,615
8
What makes you think the OP is a pro? The OP didn't state that he/she was one and no pro that I know uses "the local one hour photo" to produce prints. I would also note that this was his/her very first post on DPReview. Given the pretty ridiculous expectations implied in the original post and the poster's lack of posting history, I'd advise extreme caution before engaging with him/her in any further discussion.
Max Iso
Max Iso Veteran Member • Posts: 8,652
Sony is that you?
 Max Iso's gear list:Max Iso's gear list
Nikon D300 Canon EOS M50 Olympus E-M1 II Panasonic Lumix G 25mm F1.7 ASPH Canon EF-M 15-45mm F3.5-6.3 IS STM +8 more
Danielvr Veteran Member • Posts: 6,863
If they lack punch..
..go into the menu and look at your Picture Mode settings. 'Vivid' should look punchy and if desired you can further increase contrast and saturation there too.
Your composite image in B/W doesn't really illustrate anything. Next time, it's better to just post an actual image (or crop thereof).
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Carl Zeiss Planar T* 1,4/50 Panasonic Lumix G 25mm F1.7 ASPH +2 more
Astrotripper Veteran Member • Posts: 8,676
Overprocessing?
It's pretty obvious from the image you posted that you cranked up some sliders (or in-camera settings) way too much. Try not doing that, should help. Excessive noise reduction and sharpening are a great recipe for poor facebook-style image.
Also, maybe you got a lemon of a kit lens. I know that my 14-42mm kit was pretty bad past 25mm. If yours is similar, I don't blame you for being disappointed.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
G Rash Senior Member • Posts: 2,890
It would be more helpful for you to post images from the NEX 6 that you apparently like, and similar shots from the EM5 that demonstrate the differences you don't like.  Kit lenses, in particular, seem vary a good bit in quality.  And the kit zoom is not going to anywhere close to as good as one of the good primes or the f/2.8 zooms.
There should not be a whole lot of difference between the NEX 6 and the EM5.  I've owned both and think the 6 has a little better sensor while the 5 has a number of features that help make up for that difference in other ways, such as excellent IBIS and better ergonomics.  But you need a good lens on them to see what they can do.  For the Sony, the 50mm f/1.8 is pretty darn good for the money.  On the EM5, the 45mm f/1.8 is also very good for the money.
Finally, if "punch" is your issue, have you tried the iEnhance color mood and increased contrast?
Based on your reference to your broken NEX 6, I assume you think it is better than your EM5.  I think they are awfully close.  If you prefer Sony's colors, then buy an a6000, which is nicely priced now.
G
 G Rash's gear list:G Rash's gear list
Sony a7R III Olympus PEN-F Canon EOS R5 Nikon D610 Olympus E-M1 II +3 more
Photo Pete Veteran Member • Posts: 5,430
Re: New to m4/3, really pleased
peeppixel wrote:
Hi all!
800%
the EM5 is quite old now and kit lenses are not the best for pixel peeping.
A later m43 body and 12-40 will almost certainly do better.
Have Fun
Photo Pete
s_grins
s_grins Forum Pro • Posts: 14,011
peeppixel wrote:
Hi all!
800%
Of course you should sell and buy something better, with more pixels to enjoy peeping.
Also I did not understand your posted photo. Is it a photo of the 40 cm x 30 cm printout?
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Sigma 60mm F2.8 DN Art Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Samyang 12mm F2.0 NCS CS +3 more
joeletx Veteran Member • Posts: 4,127
Expectation and know the camera limitations
5
It seems to me that you have not shot with that broken NEX-6 you replaced either. If you have, you should have some levels of expectation of the outcome; that is the results from NEX-6 and E-M5 should be very close in IQ, with kit lens!
You shot the tiny bed of white flowers at ISO-1600 in black and white the blew up the tiny white specks 800% and observed softness! Well, you expect too much.
You should go ahead sell everything and get a full frame with kit lens, shoot the same flower bed at ISO-1600 then report back to the forum and make your case.
 joeletx's gear list:joeletx's gear list
Olympus E-500 Olympus E-M1 Olympus E-M1 III Olympus Zuiko Digital ED 18-180mm 1:3.5-6.3 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +10 more
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
peeppixel wrote:
Hi all!
800%
If you only want to pixel peep, I suggest you buy a Press camera or a Hasselblad... If you want to do large prints, look at this post of murals with µ4/3. People at that office seem satisfied but then again, they don't view the prints from 10 cm with a magnifying glass.
Third option, upgrade slightly to a µ4/3 20 MP camera: Panasonic GX8, GH5 or Olympus Pen-F , EM-1 MkII.
If you just want to make good photos, your present camera will do just fine...
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +4 more
hindesite Veteran Member • Posts: 4,893
Whoosh...
36
...what on earth is wrong with people round here?
  1. username, check
  2. number of posts, check
  3. exaggerated claims, check
  4. lack of information,check
  5. dissing on m4/3, check
Yet, despite all that, almost all the replies in the thread are serious?
(unknown member) Forum Pro • Posts: 19,317
set the sharpening to -2  it produces more detail . I would clean the sensor as well.
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
