Old 24-85 USM on full frame?
Started May 17, 2017 | Discussions
sportyaccordy Forum Pro • Posts: 20,562
I'm looking to replace my Tamron 24-70 2.8 on my A7II... it's just too effing heavy (825g + 100g for the adapter). I looked at the 24-105 STM, and that looks like a great lens, but it's still a hair heavier than I'd like (525g + adapter), and I don't really need the extra reach. How does this lens compare to the 24-105 STM? My main shooting with these kinds of zooms is at the wide end, so performance there is critical. How is it there? I found a review that didn't sound too encouraging:
http://www.the-digital-picture.com/Reviews/Canon-EF-24-85mm-f-3.5-4.5-USM-Lens-Review.aspx
Wide open results from the 24-85 are reasonably sharp in the center (soft at 24mm), but very soft in the corners - especially the wide end of the focal length range. Stopping down to f/5.6 or f/8 will give you better results - especially in the corners. This is not a great option for full-frame sensor cameras.
Does this mirror other people's experiences, particularly on newer bodies? I'm torn between this, the 24-105 STM, and the Sony 24-70/4. I would go with the 24-70/4L, but at 600g it's still a bit too heavy IMO.
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
Canon EF 24-105mm F3.5-5.6 IS STM
ed rader Veteran Member • Posts: 9,068
Re: Old 24-85 USM on full frame?
ok lens back then but terrible by today's standard i'm sure.  what's next....retreads on the porsche ;^)?
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
fishy wishy
fishy wishy Veteran Member • Posts: 9,358
The 24-85 comes up quite cheap in used listings, and there's a reason. There are enough reviews and blog posts to judge it by. You should generally be able to predict what you get with older lenses: less contrast and generally more chromatic aberration. It has a bit more contrast than the 28-105 but more CA.
If you're completely obsessed with weight you're in the wrong system, try m4/3.
OP sportyaccordy Forum Pro • Posts: 20,562
I'm not obsessed.... but there are options for standard lenses that don't weigh 900g. Just exploring them.
fishy wishy
Maybe there's a Canon equivalent of a Nikkor 28-80 f3.5-5.6. The kind of thing that's about as light and cheap as you could expect to find whilst still be worth using. Since I use walkaround lenses at f8 for landscapes the speed wouldn't much bother me.
There is- the 24-85 3.5-4.5 VR AF-S. It's modern, but there are no Nikon AF adapters worth buying at the moment.
(unknown member) Contributing Member • Posts: 578
You've spent quite some dollars on the camera body and it deserves to have a decent lens on it, but if you insist on a budget Canon lens there are a couple more to try; the 28-80 usm version 1, the 28-70 II in either it's 2.8 form or 3.5-4.5 form.
28-xx are no go, I need a 24. I could just get the native 28-70 if that were OK. Not wide enough.
Tom Holly Contributing Member • Posts: 564
It wouldn't be my choice if good wide performance is your criteria.
If 500gm is too much you should probably go to a smaller system...
 Tom Holly's gear list:Tom Holly's gear list
Canon 6D Mark II Canon EOS 90D Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +11 more
As others have said there are better lenses in Canon line up. I used one on my Canon 6D for a short while and it's miles behind a 24-105 usm L lens version 1, let  alone a 24-70 f2.8 II Canon. You've got a camera body which sells for $1698.00 USD. put a decent lens on it or sell it and get something you can afford to kit out properly.
quiquae Senior Member • Posts: 2,265
Ever held the 24-105STM in your hands? At 525g, it's a surprisingly chunky lens for what is supposed to be an entry-class zoom. The old 24-105L is 150g heavier on paper, but when attached to a 6D they don't feel as different as you might expect. The chunkiness is only going to be exacerbated with the slim-body-plus-big-adapter nature of your A7II.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
fishy wishy
You are baffling me. You seem to have missed all of the relevant points. You want the lightest and cheap Canon standard zoom don't you. So why mention a $200+ Nikon lens? Dig around for a cheap Canon film kit lens that is actually worthwhile. If Nikon did one that Canon should have responded at some point.
Mark B.
Mark B. Forum Pro • Posts: 29,756
Switch to a smaller system...or join a gym
Already have... and I have one at home. Earlier this year I was squatting + deadlifting 335-345lbs for reps. Strength is not the issue.
Switching systems is not an option either. The FE 24-70/4 will work fine; it's 430g. But it's also $800 used. I don't mind as that's pretty much a straight swap for the Tamron, but if I could get a decent zoom of the same weight for less $$$ why wouldn't I?
Michael Thomas Mitchell Forum Pro • Posts: 12,158
The EF 24-85 3.5-4.5 was the first lens I ever paired with my original D30 nearly 17 years ago. Canon had originally paired it with their APS-C film system (the Elph or something like that), and used it on their promo literature and manual with the D30. For APS-C, the wider 24mm was a welcomed 38mm equivalent, compared to the 28-135's 45mm equivalent wide focal setting.
I actually still own one of these lenses today. It doesn't see much use, but it's a cheap lens to keep around as a general range backup.
The pros of this lens are it's incredibly small size and weight, especially for the range it provides on full frame. Of course, as previously mentioned, it's pretty cheap, too. With a maximum f3.5-4.5 aperture, it's brighter than the typical kit lens. And the focal range is quite reasonable, exceeding the popular 24-70 options.
The cons are minor. No image stabilization. Old. (It already had some years behind it when the D30 was first released.) Fair build quality. Image quality doesn't match modern glass.
Comparing the 24-85 to the 24-105 L:
The L is better in every respect. It doesn't make the 24-85 less usable, but the differences are enough to make this point clear: the ONLY reasons to use the 24-85 over the 24-105 L are if size, weight, and/or cost is a PRIMARY concern.
 Michael Thomas Mitchell's gear list:Michael Thomas Mitchell's gear list
Canon EOS-1D Mark II Canon EOS 7D Mark II Canon EOS 80D Canon EOS 5D Mark IV GoPro Hero7 Black +6 more
