Mirror Lock Up is Amazing!
Started May 17, 2017 | Discussions
Marc dbr
Marc dbr Regular Member • Posts: 365
Today I updated my AFMA values of the 5D3 + 70-200 f4 L IS, and to calibrate it I took a first picture with live view, then through the viewfinder with different AFMA values. I noticed on a monitor that the closest sharp AFMA value (+2) at the tele end was quite soft compared to the image I took using live view. Since shooting with live view locks the mirror up, I am guessing that this is the reason the live view image is quite sharper... What do you guys think? do you use mirror lockup yourself either when you're shooting with live view and through the viewfinder?
Marc
Live view shot - so with mirror lockup. focussed near the little green branch/leaf
Focused through the viewfinder without mirror lock up turned on, AFMA value of +2
 Marc dbr's gear list:Marc dbr's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EOS R5 Canon EF 135mm F2L USM Canon EF 16-35mm F4L IS USM +6 more
Canon EF 70-200mm F4L IS USM Canon EOS 5D Mark III
dave_bass5
dave_bass5 Veteran Member • Posts: 7,342
Re: Mirror Lock Up is Amazing!
Live view uses a different type of AF so that will explain the difference. Cant remember the two terms used off hand but there are loads of threads about it.
Mirror lock up can make a difference if using long shutter speeds, but i doubt this is the case for you.
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
beagle1 Forum Pro • Posts: 11,742
Marc
I never use mirror lockup
www.flickr.com/photos/mmirrorless
Dan_168 Forum Pro • Posts: 11,055
MLU has been around for long long time, i use it all the time when i shoot landscape picture, which is 99.9% on tripod no matter day or night, i normally use LV which is practically in MLU all the time, for manual focus, i shoot my landscape picture almost 100% in Manual focus whether i am using  AF or MF lenses.
Marc dbr
OP Marc dbr Regular Member • Posts: 365
Thanks for your reply, I think that live view uses contrast AF, it is accurate but slow, that is why I calibrate my lenses for AFMA, with the +2 adjustment it was very similar, and I do think that Mirror lock up is handy whatever the shutter speed is: the vibration caused by the mirror equally affects the IQ whatever your settings. I could be wrong but it does seem logical to me...
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,601
... always Live View and 10 X focus, plus LV makes me think more and seeing the grid helps me along,
Rodger in Edmonton
Quaecumque vera
Tempus fugit
Nemo iudex in re sua
dave_bass5
Did you take the same shot with and without mirror lock up?
Agree about LV being slow on the mkiii, but its very fast on the newer cameras. A pleasure to use even for moving targets.
jvc1 Senior Member • Posts: 2,202
Marc
You can't use mirror lockup then use the viewfinder. If I use a tripod, I always use live view so the mirror is always locked up.
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
ed rader Veteran Member • Posts: 9,068
I ALWAYS use MLU for long exposures, which is a very common practice
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
Marc dbr
Yes you can by pressing twice the shutter button. The view finder gets black but you'll have to get your composition right beforehand
My point is that with the mirror up you can't see through the viewfinder. I've never tried pressing the shutter button twice though.
dave_bass5
You press once to raise the mirror, and a second press brings it back down after the shot has been taken.
I still cant see how having the mirror lock up can make a shot taken at 1/125 on a tripod sharper. Think its a case of emperors new clothes although happy to be proven wrong.
I never ever use MLU for long exposures  ............. which is a very common practice
(in the current era)
dave_bass5
I think these days its very common to use Live view when using a tripod, so no need for ML for those that do.
correct, my view is always "live"
Blake Cook
Blake Cook Veteran Member • Posts: 3,129
I think you will find that around 1/125 on a tripod is probably the best point to begin MLU.
Blake in Vancouver
Canon and Zeiss Stuff. Mac Stuff & annoying PC & Windows stuff.
 Blake Cook's gear list:Blake Cook's gear list
Canon EOS 5D Canon EOS 7D Mark II Canon EOS-1D X Mark II Canon EOS 5D Mark IV Canon EOS-1D X Mark III +14 more
dave_bass5
I dont agree, but thats just based on my opinion. What i really dont agree with is at this speed it will make a huge difference when mounted on a tripod, as per the OP's images.
Marc dbr
I shot the two example images from a tripod
I assure you if you're using live view the mirror is up
