Lumix GX8 RAW files = High Dynamic Range
Started May 12, 2017 | Discussions
pickleshoes
pickleshoes New Member • Posts: 24
It's surprising to me that this little camera hasn't received the attention it deserves. Working with the sliders on its RAW files in Lightroom shows the GX8 captures light with great dynamic range. Here are some samples from a recent photoshoot. I show how the GX8's RAW files can really be pushed to the limits with satisfactory results. (Lens used was the Lumix 14mm prime)
-RV
 pickleshoes's gear list:pickleshoes's gear list
Panasonic Lumix DMC-GM1 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS
Panasonic Lumix DMC-GX8 Panasonic Lumix G 14mm F2.5 II ASPH
jhunna Senior Member • Posts: 2,738
Re: Lumix GX8 RAW files = High Dynamic Range
Do you think it's the new improved 20mp sensor?
Would like to think I will be able to pull the same types of dynamic range from a gx85.
 jhunna's gear list:jhunna's gear list
Sony a7C Sony E 20mm F2.8 Sony FE 50mm F1.8 Sony FE 85mm F1.8 Sony FE 35mm F1.8 +7 more
pickleshoes
OP pickleshoes New Member • Posts: 24
Hi jhunna,
I'm sorry for the late reply. I think the GX8's 20mp sensor has a lot to do with the great dynamic range. As for the GX85, I can only assume that it would have similar, if not better, dynamic range since it is newer technology. Have you been able to process the RAW files from the GX85 yet?
Cheers
