GH5 Problems - Blurry View Screen - What does your screen look like?
Started May 2, 2017 | Discussions
Forkenbrock
Forkenbrock Junior Member • Posts: 41
I bought the GH5 when it was released and I think I'm going to send it back.
The display on the camera screen is so blurry I can hardly make out the details of a shot.  I use the Lumix 12-35 lens and with the GH5 the focus highlights are so faint I can barely tell when the camera is in focus, so not only can't I see when the image is crisp enough to be in focus, I can't see when the electronic highlighting tells me it's in focus.  Output through the HDMI and the picture is clear.  Yes, the lack of a crop makes it more difficult to see the picture detail than my GH4, but that body absolutely had a clearer picture.
On a separate note, the MOV files I recorded (4k, 30fps, 10-bit) will not play back on my computers; they play fine from the camera, but offload the file onto my Windows desktop and laptop and they won't play with VLC, Windows Movie or PowerDVD and they also won't play on a Mac with Quicktime player.
Can anyone else comment on what they've heard about these two issues?  What does the image look like on the view screen of your GH5?
Panasonic GH5 Panasonic Lumix DMC-GH4
Vesku Senior Member • Posts: 2,964
Re: GH5 Problems - Blurry View Screen - What does your screen look like?
The display on the camera screen is so blurry....
Sounds odd.
I have been talked a long time that screen and EVF should have sharpness setting. Many wants to shoot video with minimal sharpness and manual focusing. It would be easier to see focus if we could set the screen very sharp.
gteague
gteague Veteran Member • Posts: 3,005
Re: GH5 Problems - 10-bit support
it's going to take awhile for support for the 10-bit files. adobe announced support for premiere cc in about two months i think. in the meantime, you can transcode them if you have to shoot in 10-bit mode.
btw, this is a good thing. it lets you know you're on the bleeding edge.
/guy
"Before you take that shot, ask yourself: What Would HCB do?" ~/s
 gteague's gear list:gteague's gear list
Leica Q2 Leica CL Panasonic S1 Panasonic S Pro 70-200mm F4 OIS Panasonic Lumix S Pro 16-35mm F4
shipdriver Regular Member • Posts: 260
Have you adjusted the diopter (if you mean EVF)?
 shipdriver's gear list:shipdriver's gear list
Nikon D500 Nikon D5 Nikon Z6
Nicholas Smith Forum Member • Posts: 71
I understand it is frustrating about not being able to play 10bit files, but the main problem seems to be limited codec support on Windows for 10bit. Hopefully the situation will improve if/when windows adds native support or other software companies update their codecs. In the meantime, try potplayer (for windows). It will probably be quite laggy though.
For focus peaking, have you changing its settings to high or low, or the colour? I personally am OK with Peaking on High and Blue. Play with the settings until you find something that works for you. Focus peaking will not work on all subjects - it works best for detecting edges of colour. It works really well when combining it with magnified live view, which can be turned on if using AF+MF and turning the focus barrel or pressing the crosshair focus mode button.
Can you explain more about the blurry display? Is this the main display or EVF, or both? Is the entire screen/EVF blurry (text/icons and the live feed) or is it just the live feed from the sensor?
Hopefully we can all help you get to grips with the camera, and avoid having to return what is a great tool.
 Nicholas Smith's gear list:Nicholas Smith's gear list
Fujifilm X-T3 Fujifilm X-T30 Fujifilm XF 50-140mm F2.8 Fujifilm 50-230mm II XF 90mm +5 more
bleeboo Regular Member • Posts: 153
My images in the EVF and the touch screen are fine.
As far as video playback is concerned, you didn't mention how old your computers are.
If they're over say...two or three years old, you probably don't have the processor or video graphics card processing horsepower needed to play them as well as possible, and it won't matter what player you use.
I did a lot of searching for a portable way to view the 4K 60p .MOV files, and found that even the Samsung Galaxy Tab S, with what might be perceived to be a limited CPU, plays the 4K60P files beautifully in the native Windows 10 movie player application, and it has a QHD OLED display, which is stunningly superb, with no off axis angle viewing issues, and since each pixel is lit individually, inky and true blacks, along with magnificent contrast. The only issue I found is that there is only one USB-C port, however, you can overcome this limitation with a myriad of available adapters so you can plug in a microSD, or regular sized SD card. And, it weighs less than two pounds.
One can be had for about $700, but I believe this is going to be discontinued soon by Samsung.
Also, in order to play and edit the files adaquately, whether 4K30p or 4K60p, you're going to need at least a quad  core CPU, and a current iteration of one of the more recent nVidia or ATI (AMD) graphics cards, whether you buy a computer off the shelf, or build it yourself.
If you have an OLED TV, or OLED monitor, and you can afford the necessary computer ecosystem, you will be flabbergasted at the quality and resolution that the GH5 produces with 4K video. It's truly revolutionary.
 bleeboo's gear list:bleeboo's gear list
Panasonic GH5
Pete Berry Veteran Member • Posts: 4,322
My GH5 has the sharpest, most color-accurate EVF and screen I've seen on any camera. Panasonic finally got it right!
I'm assuming you're talking about the touch screen being blurry. You did peel off the protective plastic? What about shooting through the EVF?
Neither 4K 10-bit 30p or 4K 60p will play back normally on my older desktop with VLC, etc, but I'll have to give it a try on my wife's newer Win 10 laptop. This is to be expected as plain 4K doesn't play entirely smoothly on mine.
Pete
Jon555 Veteran Member • Posts: 7,721
I find the 10-bit files play okay on my PC with a combination of MPC-HC and suitable codecs (LAV filters in my case, using Nvidia's CUDA video decoding).
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
LUT sharpen ?
Is it possible to use some LUT to just sharpen the EVF and monitor image?
Forkenbrock
OP Forkenbrock Junior Member • Posts: 41
After spending more time with the GH5 I have a better understanding of the camera.   What I'd experiencing is not an actually blurry screen.  In large part, the lack of crop makes it substantially more difficult to make out details than with my GH4 screen, using my 12-35 Lumix lens.  My GH4 screen and viewfinder is just substantially easier to  use for manual focusing.  With the GH5 I find myself having to rely much more on the touch screen to focus feature.  It's easy to touch and focus, so probably will be something I get used to.
Anyone else coming to this conclusion?
fin3ak New Member • Posts: 1
I've also been going crazy with my display when taking stills and trying to see if they are sharp or not.
They mostly look pixelated, just bad quality but having just had a look in lightroom and exporting they are actually sharp. This causes me a huge headache though as when quickly wanting to get a preview of an image at a wedding for example, I'm left thinking all my images are unsharp. Not what I pay thousands for. For Video however, the playback on the display screen is crisp and impressive.
If you or anyone has a solution to this please do share!
Two thoughts:
(1) Is it zooming in to beyond 1:1 so you are seeing the image stretched more than there is detail?
(2) Is it doing a quick initial visualisation and a better one will be along as soon as it sorts it out.
I've seen both the above on Panasonic m43 cameras.
_vlad Veteran Member • Posts: 3,213
Are you shooting RAW-only or JPG (ev. JPG+RAW)?
Vlad
 _vlad's gear list:_vlad's gear list
Panasonic Lumix DMC-GX85 Panasonic GH5 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH +6 more
Forkenbrock
I ended up returning my GH5 to Amazon and exchanging it for a new unit.  The view screen on the new one isn't much different.
Frankly, I don't know how anyone using the GH5 is able to manually focus the camera with a lens like my 12-35 Lumix.  In a slightly dark room and my glasses on, I can hardly see the focus detail on the screen.
I set the focus zoom to full screen, which helps and I adjusted the focus peaking settings.  I realize my GH4 view was cropped, but any way you look at it, manual focus on the GH5 (at least with my lens, which is one of the most popular) ranges from extremely difficult to impossible.
It's not a problem of not enough zoom; a zoomed view is still blurry and the focus peaking so light I can hardly see it....the difference between focused and almost focused is very difficult to discern.  My GH4 with this lens was 100X easier to manually focus.  I have to pretty much rely on push-button focus with the GH5.
Mark9473 Veteran Member • Posts: 6,428
Did you peel off the protective film? Did you put on something else?
Do you have the peaking settings at the most sensitive "Low" setting?
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
bluelemmy
bluelemmy Senior Member • Posts: 1,098
I had the same problem with a G80. Panasonic replaced it.
David
Home Page: www.dthorpe.net
YouTube Channel: https://goo.gl/2ugCb3
Blog: http://m43blog.dthorpe.net/
 bluelemmy's gear list:bluelemmy's gear list
Olympus E-M1
Forkenbrock
I have since replaced the camera and there was no improvement.  I have the same problems with my new Samsung Galaxy Note 8...I've come to the conclusion that these OLED screens are terrible on small devices.  My LG OLED TV is gorgeous, but I will not buy another phone or camera with one of these screens.
3dwag
3dwag Veteran Member • Posts: 4,674
This all seems a bit strange.  It would be helpful if you could take a photo to show what you are talking about.
I've handled a couple of GH5s now and both the back  large display and the EVF are sharp under all conditions.  I have also seen only sharp clear displays, including both OLED and LCD, never anything like what you are describing.
Are your eyes OK looking at other things close up?
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
Forkenbrock
Note that there is a tiny adjustment switch near the viewfinder that will focus the image seen in the viewfinder (not the display screen though).  This feature isn't talked about much, but it makes a big difference.  You might also try turning up the brightness on the screen.
I hated the GH5 so much I sold it.  I found it really difficult to shoot with, because I couldn't see anything and most of my footage was crap.  I never had this problem with the GH4 and when I went to the GH5S it was like a revelation...everything I shoot looks amazing.
