First time use of Zhiyun Crane with a NX1 and 16-50 pz lens
Started May 1, 2017 | Discussions
Hirsti Contributing Member • Posts: 660
Here is a quick video of the Samsung NX1 and 16-50 pz lens mounted on a Zhiyun Crane 3 axis gimbal.
The gimbal is amazing, easy to use when you get used to the weight, the NX1 balances well, I have tried the following lenses and they all work fine:
Samyang 12mm
16mm NX
16 - 50 pz NX
30mm NX
50 - 200 nx
Samyang 85mm
I would definitely recommend using the 16-50 pz in most cases as the optical OIS turned on in mode 2 does make a big difference.
Do not however use the DIS as this introduces warp effects.
https://youtu.be/FT_C5VoOSZk
 Hirsti's gear list:Hirsti's gear list
Sony RX10 III Sony a7R II Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +1 more
Samsung NX1
Martin Meier Contributing Member • Posts: 640
Re: First time use of Zhiyun Crane with a NX1 and 16-50 pz lens
Nice Zhiyun example for your equipment. I am using Crane, SmoothC and soon SmoothQ. For Samsung NX500, Lumixes etc.  and 4K phones.
 Martin Meier's gear list:Martin Meier's gear list
YI M1 Panasonic Lumix DC-GX9 Fujifilm X-T30 Fujifilm XF 16-80mm F4 +1 more
jwang88 Regular Member • Posts: 391
I tried the same gimbal too with my NX1 + 16-50 S lens and the result is not very ideal. I guess the lens is too heavy for the product. Is there any gimbal which can handle the NX1 with 16-50 S lens?
Barple Regular Member • Posts: 263
Have you updated the gimbal with the latest firmware?  It is supposed to support up to 1.8kg with later firmwares.
 Barple's gear list:Barple's gear list
Samsung NX300 Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +6 more
selar rao Contributing Member • Posts: 527
Thank you for a very good demonstration of the capabilities of the Zhiyun crane with the NX1.
To my mind the NX500 with 16-50 Pz lens would work even better, less fatigue from holding the weight and possibly less drain on the Crane's battery.
 selar rao's gear list:selar rao's gear list
Pentax Q Panasonic Lumix DMC-GH4 Samsung NX500 Panasonic Lumix DMC-GX8 Pentax K-1 +20 more
OP Hirsti Contributing Member • Posts: 660
Thanks,
The problem with the NX500 is the cropped video, it makes a wide angle unappealing to use.
The NX1 and 16-50pz doesn't feel too heavy.  And mounted on the Crane you get about 12 hours battery life.  I have the new version with the larger batteries and to be honest, if the NX1 is balanced properly it shouldn't use any more battery than a NX500.
I bought a Samsung 10mm for 1/3 of regular price in Switzerland
- it is "perfect" for 4K video, gives  ~14mm with cropping.
And it is ideal for use with Zhiyun Crane.
Kisaha Senior Member • Posts: 2,300
Switzerland is not a real place, and therefor they do not have real prices!
(even though I have been there almost a dozen times, I still do not believe it exists!)
Shouldn't that be 24mm with the 4K crop? Possibly even more with de-fishing?
14-15mm is with the normal APS-C crop, with the 4K crop is closer to 24-25mm.
No, 10mm 3840x2160 with crop = ~14mm,
with 1.6 factor APS-C it is aequivalent with ~ 22mm FF.
4K cropping .. makes ~14mm
no cropping
no cropping
NX crop factor is 1.54 * 10mm = 15.4mm
while 1.54 * 16mm = 24.64mm
my impression is that in 4K modes is around 2.4 * 10mm = 24mm
while 2.4 * 16mm = 38.4mm.
How do you see whats in the viewfinder when moving the camera around?
Is there a control cable for NX like the one for Lumix?
I couldn't resist and ordered a V2, hence the questions...
markyboy81 Veteran Member • Posts: 4,778
You're usually behind the camera and you can tilt the screen up or down if necessary. You can also use the samsung camera app, but this is only really worth it if you've mounted the gimbal on a tripod and you're controlling that remotely as well.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Capella2 New Member • Posts: 10
is it possible to connect the NX 1 camera with gimbal controller?
How?
How?
Do you mean in order to control the camera with the gimbal? If so then no, I believe this only works with Sony and Fuji cameras.
