Tip: AF in manual focus mode - Panasonic video
Started Apr 25, 2017 | Discussions
RickPick
RickPick Senior Member • Posts: 1,332
I have been shooting Panasonic M43 cameras for several years but have only just noticed something about the AF icon that appears when in MF focus mode on the current cameras (I verified this on the GH4 and GX80).
Since it first made its appearance, this facility has been a handy way of getting initial focus when in MF mode both for videos and photos. This works, for example, on the GX7, but not when video shooting is in progress.
The new thing (for me) is that on newer cameras this not only works while video is running but it focuses much faster while rolling than when using other methods such as AFC or AFS with a shutter half-press or touching the screen. As a bonus, if you have peaking enabled this highlights where the focus is and you can make fine adjustments with the focus ring if needed.
To use "AF in MF", first set the camera in MF focus mode then, if necessary, press the Display button until you see the AF symbol near the bottom right-hand corner of the LED display. If you are hand holding the camera, you can use your right thumb to touch it.
If you use the focus ring while shooting the AF icon will disappear. To make it reappear quickly you can half-press the shutter button.
Another tip: from the GX80 on you can enable auto-ISO in video mode. If you want, you can use shutter priority and let the camera adjust the aperture and ISO settings. Transitions, e.g. light to dark, seem quite smooth.
 RickPick's gear list:RickPick's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85
Vesku Senior Member • Posts: 2,964
Re: Tip: AF in manual focus mode - Panasonic video
You can also use back button focusing (AF-ON in menu) with manual focus. It is easier, just press AE-lock button.
Auto iso exposure change is smooth but when the camera adjusts aperture the exposure changes in visible steps. Auto iso and S is handy indoors where the aperture stays fully open anyway.
eivissa1
eivissa1 Contributing Member • Posts: 620
I don't get your story.
If I switch to manual mode I cannot mak a video. Cause I am in photo mode.
Maybe you can explain a little bit more.
 eivissa1's gear list:eivissa1's gear list
Panasonic Lumix DMC-LX5 Panasonic LX100 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
point2 Contributing Member • Posts: 684
Thanks v much for the tip.  I'm new to M43, and have recently started to use the EM5, and then the much newer Panasonic G85.  The "AF in MF mode" facility works for the G85 as well.  It's a nice thing to have.  It's amazing the stuff they can throw into the tiny little body (I come from Nikon DSLRs).  Thks
DNature
DNature Regular Member • Posts: 310
That is what I do, I have mostly use manual focus on my GH4 and GH5 and just use the AE lock button to get focus quickly. I found use the AE button doesn't work well when moving from focusing on something in the background the foreground and trying to focus on the object in the foreground, especially with a busy background.
There are times when I have tried to go from focusing on a wider shot to a plant in the foreground and more often than not, it won't lock focus using the AE button with AF-ON when the wide shot was busy and the lens kept focusing on the background.
I think he means setting the focus to manual focus with a switch on the back of the camera, not changing the mode on the mode dial.
If find that the best way to live life, is not in the pursuit of material possessions, but its to live in the pursuit of making positive differences to both other people and to the planet as a whole and if you can get others to do similar or the same, so much the better.
 DNature's gear list:DNature's gear list
Canon EOS 400D Canon EOS 500D Canon EOS 600D Panasonic GH5 Canon EF-S 18-55mm f/3.5-5.6 +9 more
RickPick
OP RickPick Senior Member • Posts: 1,332
Yes, that is right, but my point is that using the AF icon on the touchscreen causes the focus change to be made much faster than any other method (while recording a video). Part of the reason I posted this was to see whether anyone else has found this to be the case. Maybe I didn't test the back button focusing - my testing was fairly unscientific!
RickPick
No, actually I am talking about the onscreen button [AF] which appears on the LCD screen (bottom right) when you switch the camera to MF.
How you switch to MF depends on the camera. Some, e.g. GH4, and GX7, have a physical switch but with others, e.g. GX80, you use focus mode in the menu or set a function button to allow you to switch.
In either case the [AF] onscreen button appears, but you may have to press Display a number of times to see the right display screen. When you touch the AF button on the screen the camera performs a single AF (GH4/GX80) and what I noticed that this appears to be faster than other methods while recording video. Focus jumps rather than crawls to the new focus point (relatively speaking). I found this quite exciting....:-)
RickPick
You can make a video using manual focus. This is set either using the Focus Mode menu item or a physical switch if there is one. Whether in photo or movie mode the [AF] icon appears on the touchscreen. There are more details in other posts in this thread.
(You don't have to be in M mode - that means manual aperture and shutter adjustments independent of focus mode.)
In video recording it is not good looking when the auto focus works too quickly. When I use half shutter autofocusing (AFS) in video with my GH4 the autofocusing is still too fast and looks sometimes ugly. The touch focus (touching focus box) is slower and better looking.
4k auto focusing in general is slow and some times unreliable. My GH4 reacts quite slowly when I half press for new autofocus. It may think few seconds before it moves and when it moves it does it ugly. It depends on lenses too.
I think it is difficult to touch screen AF-symbol without shaking the camera during recording. Shutter half press is more stable. Also it is impossible to touch AF-symbol if watching through EVF.
_vlad Veteran Member • Posts: 3,213
Thanks Rick for a tip. I never ever noticed the icon with my GH4 - until GX80. Fine to know that in video camera focuses much faster - however fast refocus is not always optimal as Vesku wrote. But for sure it might be highly desirable sometimes.
There is one drawback though. Tapping the screen will place your focus point wherever you want to have it - followed by refocusing. Tapping the icon will just initiate refocusing - using the focus point previously selected. It means you have turn your camera to new object/direction and then tap the icon.
I am not sure if I explained it clearly. Imagine having camera on a tripod. Without moving the camera you can refocus to different objects without moving the camera-just tapping them monitor. This cannot be done with your method - you have to move the camera - point it to object you wish to be focused and then tap icon.
Vlad
 _vlad's gear list:_vlad's gear list
Panasonic Lumix DMC-GX85 Panasonic GH5 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH +6 more
RickPick
Thanks, and yes, I agree with your points and Vesku's too. Panasonic have actually said that focus changing is slowed in video deliberately because too fast a focus change can look bad. Unfortunately, a lot of the time with this system even a slow change can look quite bad too. In my case, when I shoot video it is usually at some event where we are using two and sometimes three cameras for different angles. Sometimes one camera is "roving", usually supported on a shoulder rig. I am thinking of using my new GX80 with its good stabilization for this function - maybe handheld even. In that case, this could come in handy for me. Sometimes I need the focus changes to be fast rather than "look nice". While editing I will only use certain shots from the roving camera and will obviously not use those not so nice-looking moves. So I'm glad that Panasonic have provided this option.
Same thing goes for the focus point. When hand holding I can easily reuse the current focus point and tap the AF icon with my thumb when needed. I think of this more as an addition to the armory than an answer to everything. As you say - "highly desirable sometimes".
Thanks again for your response.
GodSpeaks
GodSpeaks Forum Pro • Posts: 14,713
I set my cameras to AFS, Shutter AF to OFF and the back button AF to ON (but not locked) when shooting video.
When I want to focus I tap the back button, and bingo.  My only complaint is that Panasonic, in it's infinite wisdom, disables the small pinpoint AF box when video is recording.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
- Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic FZ1000 Sony Alpha DSLR-A850 Nikon D800E Panasonic Lumix DMC-GX7 +52 more
MattinPA New Member • Posts: 7
I discovered how fast this was as well. It seems to vary with different bodies and lenses. I only have two native Panny AF lenses and of the two, the 12-42 3.5-5.6 on the G7 grabs focus very quickly and never hunts. I'm going to do some more experimentation for run-and-gun video where you want to grab focus and start rolling ASAP. But even when it's slower, say on the GH4 with the 20mm 1.7, it's still faster than any other option. Very psyched to discover this and it only took me like three years. : )
