Capture One profiles for Fuji?
Started Apr 24, 2017 | Questions
Damián B Regular Member • Posts: 174
Hello,
In Lightroom when shooting RAW I can change the color profile to Velvia or whatever, same as in the camera.
With Capture One the option is not there, which I find annoying. Same happens with Canon profiles.
I found a thread with dropbox links which are not working at all...
If anyone has a solution would appreciate it, so far Capture One seems a better RAW converter but my flow is slower than in Lightroom.
 Damián B's gear list:Damián B's gear list
Fujifilm X100S Canon EOS 80D Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
Adoubeur
Adoubeur Regular Member • Posts: 109
Re: Capture One profiles for Fuji?
Hello,
I uploaded Fuji ICC profiles for capture one on a cloud, you can download them here :
http://www.mediafire.com/file/3g634ri5yx3u40z/Profils+ICC+C1+Fuji.zip
The "XT1" folder contains profiles for X-Trans 2 (X-T1, X-T10, X-E2...).
The "XT2" folder contains profiles for X-Trans 3 (X-Pro 2, X-T2, X-T20).
Don't forget to rename them according to your gear before placing them in the appropriate folder. For instance, if you own a X-Pro 2, use the XT2 profiles and rename them.
FujiXT2-ACROS_ARGB_V2.icc -> FujiXPro2-ACROS_ARGB_V2.icc
etc.
If your using Windows, the folder where you want to copy those files is :
.../Program Files/Phase One/Capture One 10/Color Profiles/DSLR
 Adoubeur's gear list:Adoubeur's gear list
Sony ZV-1 Fujifilm X-T2 Fujifilm X-T30 Fujifilm X-T4 Fujifilm XF 18mm F2 R +10 more
OP Damián B Regular Member • Posts: 174
Adoubeur wrote:
Hello,
etc.
Awesome! I'll try them when I reach home. I'm on a MAC but will find out the path.
deednets Forum Pro • Posts: 12,975
Adoubeur wrote:
Hello,
etc.
I don't use them myselft, but find people like you and Scotty Wang contribute a lot to those who are interested!
Excellent stuff (will of course have a play out of pure curiosity)
Deed
 deednets's gear list:deednets's gear list
Sony RX1R II Fujifilm X-Pro3 Sony a7R IIIA Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +8 more
Adoubeur
Those are Scotty Wang's profiles, not mine, I just uploaded them as Scotty Wang's download links don't work anymore.
I find them at least as good as the Fuji profiles you have in Lightroom.
fadege New Member • Posts: 2
Great job! And they be useful for x-t10 and x-t20 too?
 fadege's gear list:fadege's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +2 more
Adoubeur
Yes !
Novim
Novim Regular Member • Posts: 141
On Mac profiles go to:
Users/UserX/Library/Colorsync/Profiles
(Rename them according to the model of your Fuji camera.)
 Novim's gear list:Novim's gear list
Ricoh GR Digital IV Leica Q Ricoh GXR Mount A12 Fujifilm X-E1 Panasonic Lumix DMC-GX85 +4 more
bowportes Veteran Member • Posts: 4,218
I use them all the time. Very nice!
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro2 Panasonic Lumix G 20mm F1.7 ASPH +13 more
ateriksen
ateriksen Forum Member • Posts: 62
Adoubeur wrote:
Hello,
etc.
Man, I love your profiles! I re-posted them on my local FB group and gave thanks to you here @ DPreview on this link. You sir, are awesome
Best regards,
Aleksander
 ateriksen's gear list:ateriksen's gear list
Fujifilm X-E1 Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-Pro2 Sony a7 III +12 more
Adoubeur
Thanks, but as I explained before, they're not "my" profiles.
Best regards,
Aleksander
Let's give Scottie Wang his due.  These are his profiles.
None of us are awesome for simply posting someone else's work, even though it was a nice courtesy to do so if the original links no longer function.
ateriksen
Oh, sorry !
The profiles still rock tho, I'll drop credits to both of you then. You for informing
ateriksen
bowportes wrote:
Best regards,
Aleksander
I'll tag him in my post, thanks for correcting me
Aleksander
