Would you suggest getting a 85 f/1.8 for me?
Started Apr 24, 2017 | Discussions
Dimes Regular Member • Posts: 382
Good day, everyone! I currently own 70-200 f/4is, which overlaps 85mm, 24-70 f/2.8, which is close to 85mm and is versatile and a 135 f/2l, which is my primary portrait lens.
I'm thinking of getting a canon 85mm f/1.8. I like that it is relatively inexpensive, possesses fast AF, small in size, and has a good focal distance, which is convenient for me. However, I find it to be lacking "beauty" in its images (it tends to be "dull and boring" like 24-70, not "arty" like 135 or 85 1.2). I'm also not sure if I will be satisfied with its sharpness at f/1.8. I don't like to carry more than 3 lenses with me at once and I doubt that 85 f/1.8 will be able to substitute any of the lenses I mentioned above.
I'm thinking of this lens as a street and travel portrait lens and a concert lens for low lightning.
What do you think?
 Dimes's gear list:Dimes's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 35mm F1.4L USM Canon EF 135mm F2L USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +5 more
Great Bustard Forum Pro • Posts: 45,641
Sure, why not?
What do you think?
I can't see any reason not to get a lens that produces photos that you consider "dull and boring" and "lacking in beauty".  After all, those are the top characteristics I look for in a lens.
(unknown member) Contributing Member • Posts: 578
Re: Would you suggest getting a 85 f/1.8 for me?
Yes, as they are relatively inexpensive s/h, on either Ebay or Cragslist. So you may as well have one in the bag.
Jura S Senior Member • Posts: 1,980
Maybe you are not addressing characteristics of the lens. 85/1.8 has its problems, lack of "artistic" look is not one of them.
Tom Holly Contributing Member • Posts: 564
Your gear list says you have 100 macro, 135 f2 and 70-200 f4.
85 1.8 is pointless in my opinion, especially if you have those primes already, including the 135
 Tom Holly's gear list:Tom Holly's gear list
Canon 6D Mark II Canon EOS 90D Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +11 more
Jura, do you often shoot around f/2.8 with this lens for portraity shots?
It seems to work well there.
Spotted Cow Senior Member • Posts: 1,586
I think the above tells me that you will not use this lens if you get one. If your mindset is already that it's not good enough compared to any of the lenses that you already have then you will never have a reason to grab for it.
For me, I'd get it because I really like the 85mm FL. I often just go out with a 35mm and 85mm primes.
I usually shoot even more open.
50/1.4 85/1.8  and 100/2.0 are real classics. Not perfect, but very decent even in current hyperpixel world.
I don't like 28/1.8 usm but it could be that my sample is a lemon.
I have the 85 1.8, and yeah it's a real classic. I often shoot at f2.8 and was interested to hear what others generally use it at.
I find the purple can be a bit much wide open when there is bright light, and chances are I'll miss focus, but I do use wide open.
The 1.8 is also useful when I shoot film in low light, in which case purple doesnt matter so much (black white film).
How come you use 85 1.8 and 100 f2. These are quite similar arent they?
They are almost like twins. Same AF speed, same CA fringing, same look and almost same size.
I've bought 100/2.0 because it was cheap. A little more than 200 euros and the guy had trouble selling it for anything more.
I do have 100/2.8L which is a nice lens but prefer 100/2.0 for intimate portraits.
Dave
Dave Veteran Member • Posts: 6,231
If price will prompt you, it can now be had (refurb from Canon) for $259.99.
http://www.canonpricewatch.com/blog/2017/04/additional-discounts-on-refurbished-lenses-and-cameras-canon-store/
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
