C Sean
Re: PL 100-300 versus PL 100-400 zooms
lowflyerguy wrote:
Looking for insights (well, opinions, preferably based on actual hands-on experience) on these two zooms. I haven't seen a comparison, which surprises me a bit (pointers to any appreciated).
There been a few comparisons but there are members like myself who upgraded from the original 100-300 to the 100-400. To be perfectly honest the 100-400 is better built but it not in a league of it own. It's a very flexible lens and I say the best bit about this lens in the performance in the field which I can't say the same with the original 100-300.
Sure, the PL 100-400 gets you an extra 100mm, and it comes with the Leica moniker. It's also over $1000 more expensive (where I live), it's large and heavy (quite a bit more than the 100-300) , and it's a bit slower (f4.0-6.3), relative to the 100-300 (f4-5.6) too.
You're thinking the extra 100mm will allow you to zoom out further and I'm sorry but that is wrong. This lens allows you to zoom in further to an already well compose subject and remove the need to crop or crop heavy.
The 100-400 is actually a 100-300+ because if you zoom out too far you usually get interference between you and your subject whether it's dust, heat or air. It will soften your image. The other problem is at 300mm to 400mm, the lens becomes softer and really to get a detailed shot, you really need to zoom in or if the subject is too far away at 400mm, it will appear soft in the final image.
Two further things, the 100-400 is fast as the 100-300 and is not slower. The other regarding the weight issue. Yes mounting the 100-400 on the GH4 does take some time getting used to. However, put the camera in the sling bag when not in use.
The 100-300 is less painful to buy, faster, is significantly lighter and more compact. And yes, has 100mm less reach.
With the 100-400 you're getting better performance and extra zoom in compared to the lighter, not faster compact 100-300.
The 100-300 is newer and comes with support for latest stabilization magic; I assume the 100-400 can get that same level of IS support with a firmware update.
mkII is newer but the original in the field has a lot to desire.
On a basic level, it looks to me like the trade-off is, how badly you really want that extra 100mm (and your willingness to pay 2.5X the price for it).
Yep
I can imagine that for lots of wildlife shooting - especially when mounted to a tripod - the extra length of the 100-400 is appealing, albeit that comes with some trade-offs. But otherwise, for hand-held shots, where there's action (eg BIF especially), if you can live without that last 100mm of zoom, the 100-300 sounds more appealing to me.
The 100-400 is a professional lens and the 100-300mm mkII isn't.
But I'm probably missing something important (wouldn't be the first time!) - am I? What?
I haven't tried the MKII so I can't comment how much it improve compared to the original. However, if MKII focuses better then maybe that is good enough but around 300mm the lens likely to be softer.
Image quality? Ability to focus quickly? How do the two compare there? Other distinctions I'm missing?
They're similar lenses but one is built better and perform better in the field.
Thanks for your insights.
