jalywol
Re: PL 100-300 versus PL 100-400 zooms
5
lowflyerguy wrote:
Looking for insights (well, opinions, preferably based on actual hands-on experience) on these two zooms. I haven't seen a comparison, which surprises me a bit (pointers to any appreciated).
Sure, the PL 100-400 gets you an extra 100mm, and it comes with the Leica moniker. It's also over $1000 more expensive (where I live), it's large and heavy (quite a bit more than the 100-300) , and it's a bit slower (f4.0-6.3), relative to the 100-300 (f4-5.6) too.
The 100-300 is less painful to buy, faster, is significantly lighter and more compact. And yes, has 100mm less reach.
The 100-300 is newer and comes with support for latest stabilization magic; I assume the 100-400 can get that same level of IS support with a firmware update.
On a basic level, it looks to me like the trade-off is, how badly you really want that extra 100mm (and your willingness to pay 2.5X the price for it).
It's not just the extra 100mm, although that's pretty nice if you do birding.
I can imagine that for lots of wildlife shooting - especially when mounted to a tripod - the extra length of the 100-400 is appealing, albeit that comes with some trade-offs. But otherwise, for hand-held shots, where there's action (eg BIF especially), if you can live without that last 100mm of zoom, the 100-300 sounds more appealing to me.
Nooo, you need more, rather than less reach for BIF. Talk to nzmacro about needing reach and birding....
But I'm probably missing something important (wouldn't be the first time!) - am I? What?
Image quality? Ability to focus quickly? How do the two compare there? Other distinctions I'm missing?
IQ is the biggie.
Here's the thing: The 100-300mm is a nice lens. I used the first version for about 4 years. It took me a year to develop good technique to get the best out of it. I had a very good copy, too; it was reasonably sharp out to 300mm, and had minimal CA around bright subjects up close. It actually became, over time, my most used M43 lens. I got some of my favorite shots in this format with it. However, I did have to not only learn how to handle it and what setting to use to minimize blur, but I also had to learn what PP techniques to use to extract the most from it. Images are good, and sharpen up well from it, especially at the shorter end, but I found myself most of the time doing a double sharpen in PP to get the detail I wanted from it.
When the 100-400mm came out, I spent several months trying to decide if it was something that I should get. It's a large amount of money for me, as I am on a limited budget. However, I ended up getting one after realizing that I would use it more than any of my other lenses.
So, how is it different from the 100-300mm (Mk1)?
- Image quality, of course, is better. Images without processing are noticeably sharper, and need far less PP to extract fine detail.
- Colors and contrast are cleaner; much better microcontrast on the 100-400mm.
- Far, far less CA and much better handling of close bright areas without halation and CA.
- Closer focusing capability on the 100-400mm. You can use it for a pseudo macro if the opportunity arises.
- You can use this lens wide open and still get sharp images. The 100-300mm behaves best stopped down, esp at the long end.
- OIS is far, far superior to the original OIS in the 100-300mm. Now, I know the new version has improved OIS and focusing capabilities, so I can't speak for how the MkII and the 100-400mm compare. However the differences between the MkI and the 100-400mm are significant in this area.
- Focus speed, accuracy, and tracking: Again, I have only used the MkI, but there is no comparison at all between the 100-400mm and at least the earlier version of the 100-300mm.
These are very different lenses. I would even venture to suggest that if you are not heavily into working with really long lenses, or don't know whether you would need a 400mm lens, that it would probably not be worth it to go for the extra $ for your uses. It might even put you off working with long teles, because the 100-400mm is heavier, and requires very good technique to get the most out of it, especially as you get out to the long end. The learning curve for it can be a bit of a bear if you are starting from scratch....The 100-300mm will also have a learning curve, but it's lighter and easier to handle, and might be easier to work on your long lens technique with initially.
So, the conclusion? Yes the 100-400mm is a better lens. If you need what it has to offer, yes it is worth the difference in price from the 100-300mm. If you don't, then no, it's not, and you will probably regret having spent the extra $ and the extra weight you have to carry with it.
-J
