77D - Radio Trans Flash as Master
Started Apr 22, 2017 | Questions
Steve_tEkGuY Contributing Member • Posts: 516
hi folks,
The 77D manual is a little confusing. I understand that the optical wireless flash will work fine when using my 430EXIII-RT but how about using Radio Transmission.
Can I fire off the remote flash using RT only on the 77D.
Thank you
 Steve_tEkGuY's gear list:Steve_tEkGuY's gear list
Canon EOS R6 Sony a7 IV Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Sony FE 200-600 F5.6-6.3 +5 more
Canon EOS 77D / EOS 9000D
OP Steve_tEkGuY Contributing Member • Posts: 516
Re: 77D - Radio Trans Flash as Master
Steve_tEkGuY wrote:
hi folks,
Thank you
Looks like Optical only.
Mark B.
Mark B. Forum Pro • Posts: 28,640
Steve_tEkGuY wrote:
hi folks,
Thank you
Correct, optical only.  If you want to use radio triggering you need a radio-enabled master flash or radio trigger on the hotshoe.  I find Canon's radio-enabled system very expensive.  I've been using Yongnuo YN-622c-TX transmitter and the YN-622c transcievers on remote flashes, works great.
Mark B. wrote:
Steve_tEkGuY wrote:
hi folks,
Thank you
Hi could i use a different RF trigger something I could use with the 77D and my 6D much like the ST-E3-RT. I have seen some threads where the IR focus light wasnt working on the Yongnuo YN-E3-RT with canon 80D.
I'm trying to avoid having separate TX and an RX gear since my Canon flash already has the RX built in.
Mark B.
Steve_tEkGuY wrote:
Mark B. wrote:
Steve_tEkGuY wrote:
hi folks,
Thank you
Yongnuo makes a version of the ST-E3-RT.  It is cheaper than the Canon, I'm not sure how good it is.
Sailor Blue
Sailor Blue Forum Pro • Posts: 15,536
Steve_tEkGuY wrote:
Mark B. wrote:
Steve_tEkGuY wrote:
hi folks,
Thank you
The Canon ST-E3-RT doesn't even have an AF Assist Light. The Canon 600EX RT has the red AF Assist Light.
If you are going to use the Yongnuo YN-E3-RT with a Canon 600EX RT you should check to see if you can turn the AF Assist Light of the YN-E3-RT off.
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
