Macro with the G7X : magnification
Started Apr 19, 2017 | Discussions
tokumeino Veteran Member • Posts: 3,175
With third party solutions, it becomes possible to attach filters to a G7X (I or II) or a G5X, or more...
IMO, a CPL is mandatory but for people who like that, macro / close-up lenses are fun as well.
I own a Hoya +10 diopters and a Hoya +4 diopters. I tried to put them both on my G7X, and I tried to focus on the smallest possible object, at varrying focal length. I actually did that with a ruler so as to measure the size of the "object".
Methodology
  1. Start at WA
  2. Manual Focus set at the closest point
  3. Move the camera until focus peaking indicates sharpness
  4. Take the picture
  5. Zoom in by one step : the focus distance should remain minimal wrt the new focal length
  6. Continue
I'm sure that it could be more precise but I did it quickly to have a rough idea.
Results
I've put the data on my Google Drive.
  • The size of the smallest focussed object filling the frame (mm) has been observed on the pictures
  • The magnification on the 1" sensor is the calculated resulting magnification
  • The third indicator is more weired and I'm not sure that it makes sense : it represents the reguired magnification with a FF setup, so as to fill the FF sensor with an object of the same size.
Tha values : measured and calculated
The size is expressed in millimeters.
These values are about object sizes and magnification, but they don't show the focussing distance. Actually, at WA with close-up lenses, the lens was touching the subject, with a massive shadow. As the FL increases it becomes much better. At longest FL, it is OK IMO : I would tell 20-30 cm at least.
Conclusion
I've only tested 24mm, 35mm, 50mm, 85mm and 100mm. Without a close-up filter, the highest magnification is obtained with a FL between 35mm and 45mm (FF equivalent) : not at wide angle where the focusing distance is the smallest, and not at the tele side. This had already been shown by JND : https://www.dpreview.com/forums/post/54597516
Good news are :
  • a regular +4 diopter filter will permit to keep the max magnification at longer FL, thus increasing the working distance
  • a stronger +10 filter permits to reach very decent close-up magnifications
Bad news : none.
Canon PowerShot G5 X Canon PowerShot G7 X
krugman Contributing Member • Posts: 957
Re: Macro with the G7X : magnification
This is very helpful. Let me ask a few questions to make it even more helpful:
1. What is "CPL"?
2. How did you get the +4 diopter to adhere to, or attach to, the lens of the G7X? What are the "third party solutions" that  you used?
3. How sharp were the results for the smallest object (c.31mm) with the +4 diopter lens? Was it sharp enough to use it to digitize slides?
We are very interested your results and would like to try this ourselves, but we need your help in telling us what you did and how you did it, in a bit more detail,  and how well it worked in terms of sharpness.
Thanks,
Krugman
OP tokumeino Veteran Member • Posts: 3,175
1. What is "CPL"?
sharpness.
Thanks,
Krugman
CPL stands for Circular Polarizer filter. See Wikipedia or CambridgeInColor for details. Very helpful : much more than corner sharpness for the impact of an image.
I attach filters with the Magfilteradapter ring. There is also the cheaper Lensmate system, depending on your own needs.
About sharpness, I cannot tell with the G7X because actually, I performed very quick tests only to measure size objects, with a very little care about sharpness, and handled. Needless to say that with a light camera such as the G7X and a +10 filter of the longer FL, you need very steady hands !
But in general, such filters work well and retain a good amount of sharpness. Even with very basic filters, one can achieve very decent results. Kurt Munger studied close-up cheap kits. The filters I own are Hoya HMC Close-up +4 and Hoya 55mm Macro Close-up +10.
Not sure whether a compact camera with such filters can rival a scanner for films or slides. But for sure, you would need a way to handle the film and the camera so that nothing moves, and I don't own such a thing. Indeed, to make sure that everything is in focus, depending on the lens field curvature, you might need to close the lens and lower the shutter speed.
Note : the 31mm size is with the +10 diopters filter, not the +4. And it is on the full tele end. In such a situation, you will undoubtly need a solid tripod or such.
Update : working distances and samples
5
The original post is about max magnification but this is not the whole story. Indeed, a large magnification is sweet, but it is much better if it can be achieved from a reasonable shooting distance.
And while close up lenses permit to decrease the minimal focusing distance, they also decrease a lot the maximal focusing distance.
+10 diopters @100mm
+10 diopters @100mm / max magnification eg closest possible focusing distance @100mm with the +10 diopters filter attached
Again @100mm +10 diopters. The *maximal* focusing distance is very close from the minimal one. So, you don't have very much versatility for composing.
To get an real world idea of the working distances...
Minimal focusing distance @100mm +10 diopters
Maximal focusing distance @100mm +10 diopters : not that much different. The range is indeed very small.
+4 diopters @100mm
With the +4 diopter filter, you loose magnification, but you gain a lot of versatility wrt magnification, while retaining comparable working distances.
@100mm + 4 diopters : max magnification
@100mm + 4 diopters, min magnification
Let me recall magnifications without a close-up lens, @100mm...
Max magnification @100mm without a filter
By reducing the FL, it is possible to increase magnification
Max magnification @50mm without a filter
...but you need te be much closer.
+4 diopters @50mm
@50mm +4 filter : max magnification
@50mm +4 filter : min magnification
with the following working distances
+10 diopters @50mm
@50mm +10 filter : max magnification
With the +10 filter, wrt to the first sample of this post, by reducing the FL, you regain a fair amount of versatility while keeping a fair amount of magnification (actually better than @100mm with the +4 filter). But you need to get quite close to your subject.
@50mm +10 filter : min magnification
Conclusion
All in all, I think that the +4 filter is appropriate to carry in a pocket everywhere, for quick and casual close-up shots. The +10 will be better suited when you'll have a little more time and specifically intend to shoot close-up.
Sorry for beeing long. I don't expect answers, actually. The point is that this is the kind of information that I've been looking for, but that I couldn't find by Googling. So I hope that it can help future Google searchers. It's not a post meant for "debate".
PS : a Playmobil toy is approximately 7.5 cm (3 inches).
SarahJane734 Regular Member • Posts: 103
Re: Update : working distances and samples
Thanks for the examples, that helps a lot!
SidSoni
SidSoni Junior Member • Posts: 29
Wow! Fantastic information.
I shoot small objects and often look for such information and comparisons. I sense you've done plenty of work for this post. Thank you.
