New A6500
Started Apr 19, 2017 | Discussions
Almazar80 Senior Member • Posts: 1,048
New A6500
I tried out an open box A6500.  Without changing the setting to be able to raise the heat threshold, I was able to exhaust a fully charged battery and the camera did not shut down.  About seventy minutes or so of recording 4k 24p 100mb/sec bit rate, at an ambient temperature around 70F (indoors).  Needless to say, I think I am keeping the camera.  The temperature warning light went on after about 45 minutes of recording, but the camera kept recording.  Now, I had to restart the recording after the 29:50 cutoff, but the idle time was a few seconds at most.  Not too bad.
Sony a6500
drewp5
drewp5 Regular Member • Posts: 127
Re: New A6500
frequent cuts are preferred to just one long unbroken video stream.
 drewp5's gear list:drewp5's gear list
Sony E 18-55mm F3.5-5.6 OSS Sony E 55-210mm F4.5-6.3 OSS Rokinon 21mm F1.4 Sony a6300 Sony E PZ 18-105mm F4 G OSS +3 more
OP Almazar80 Senior Member • Posts: 1,048
Re: New A6500
The testing that I did was to figure out what the overheating threshold for this particular A6500.
drewp5
Re: New A6500
well ok i got that,  just not sure when that ever becomes a issue irl.
amdix Regular Member • Posts: 134
Re: New A6500
Well, I was watching an instructional video today that had been recorded with a 6300 and it cut out (overheated) during the video at about the 20 min mark. So I say it most certainly is/was an issue. Glad to see that it has been somewhat resolved on the 6500.
 amdix's gear list:amdix's gear list
Sony FE 24-70mm F2.8 GM Sony FE 100-400mm F4.5-5.6 Sony a9 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +5 more
BBQue Senior Member • Posts: 7,553
Re: New A6500
Install the OPEN MEMORY TWEAK and you can record longer video without the camera shutting off after the arbitrary 29:50 cutoff.
Re: New A6500
Thanks for the tip, but I never shoot clips longer than a few minutes.  I only do the long clips when I am testing for overheating.  Then again, one never knows when one will need to take a long clip.
