A6300 HELP Missing pictures
Started Apr 15, 2017 | Discussions
stacey magee Regular Member • Posts: 198
Everyone!  hoping you can help.
Second time this has happened with my A6300.
I take pictures, I can see them in the viewfinder/review on the back screen.
I get home and put them in the computer and they are not on the card. Put he card back in the camera and can't see them.
This happened back in February and I just assumed it was cause I did not format the disk before using and went on ..sad about losing pictures. but moved on.
TODAY - here is exactly what happened:
1.  Took pics throughout the day
2.  Could see the pictures on the camera
3.  Back home - put the disk in the computer COULD not find them at all.  (I do have other files on the disk - did not format again - forgot - but this CAN'T be it - keep reading).
4. Put disk back in the camera and get the big "?" on the back of the screen.
5. Try in computer again can't see it.
6. Traveling with a friend who has an NEX6- put my disk in her camera - COULD SEE my pictures for the day.
7.  Try back in the computer and my camera can't see it.
HELP!!!!!!!!
And if this is a camera issue - does SONY really help.  figure I should call them.
I have had the camera since July - but only used it for a big vacation in Hawaii - where I fell in water and it had to be fixed by Precision Camera.
Sony a6300
(unknown member) Senior Member • Posts: 8,068
Re: A6300 HELP Missing pictures
Assuming you mean SD card, not "disk" oh yes, that can be it! The camera creates a data base to keep track of image location and other stuff on your card. Never use the card for any other purpose than taking pictures. Never format the card on your computer. Always format card in camera. (This is also important for video, cause it determines whether your camera will record PAL mode or NTSC mode).
Not sure about this - could you see the full images or just the preview pics the camera generated automatically? But certainly there is hope.
Probably no need to send it to Sony. Any data recovery software should be able to find it, if it is still there. Whatever you do - do NOT write to the card (or take new pictures with it) cause that might overwrite whatever is left.
OP stacey magee Regular Member • Posts: 198
On the NEX6 - we can see the whole pictures - everything just like normal.
My calling sony is to find out if something is wrong with my camera. My concern is that there is some setting or something..Or why would I be able to see it on the NEX6.
AND why could I see it while I was out and about and even reviewed them on the camera.  Then as soon as I take the SD card out of the camera into the laptop then it is gone and can't see it on the A6300, the computer and the NEX6.
Thanks for the help!
drewp5
drewp5 Regular Member • Posts: 131
discounting what your friend may of seen in his camera id say try a different sd card/ might not be working right, intermittent issue possibly. why have hair loss trying to talk to hadji from sony cs for two hours when a $15 sd card can solve the mystery.
 drewp5's gear list:drewp5's gear list
Sony E 18-55mm F3.5-5.6 OSS Sony E 55-210mm F4.5-6.3 OSS Rokinon 21mm F1.4 Sony a6300 Sony E PZ 18-105mm F4 G OSS +3 more
To the best of my knowledge, there is no setting that would make your pictures visible on one camera, not the other. There is however a hidden database, and maybe that became corrupt.
What file directory are you trying to find your images in after you plug the card into your computer? Is the directory still there, but completely empty? Or is the directory gone too?
LOL on the sony - which is why I really don't want to call.
I am going to try to move everything off the card so I can format and try again.
BUT It has happened twice and so odd.
And I am here traveling with my friend and I actually put the card in and saw them clear as day - UGH.
drewp5
good point, should still see them in windows explorer even if there gone in playmemories app. one thing too is the pc always wants to run a check and format my card and i ignore it. could be the op didnt ignor this and wiped it?
drewp5
just to be on the safe side id use a different card rather than possibly risk loosing more photo`s
Hey BB-I don't do anything to specify where to find the pictures...what I have done is just put in the SD card in computer and then look for the number that show up like DCIM/109MSDCF etc.
there are directories there from previous days.
And the DCIM shows updated today so I know pics were there...(again, I know they ARE there as they are on my friends camera).  We actually just sent the pics from her camera via wifi (nex6) to my phone so I would have them.
this particular trip I am not worried about the pics so much as my upcoming trip to Alaska that is in two weeks!
Agreed!
Except they are in the card. That is the oddest thing.  they are there....on the disk as we can see them on the nex6...
If your camera can see them, your computer can see them. Period.
Let me ask again: what directory are you looking at? Is the directory still there and completely empty? Or is it gone too?
Morning BBQ - just to recap
1. The Camera COULD see the pics while out and about
2. When I put in the computer - could not SEE the pics - looked in the DCIM folder and there are other pictures in there from previous trips etc.  (because I did not format it - just because I forgot)
Below is info on where I looked.
alohajason New Member • Posts: 1
stacey,
Did you have any updates on your disappearing pictures issue? I have the same problem:
I took a bunch shots today, some I could see a preview while on a shoot, and now back at my computer, I don't see any the pictures from today (only the one I took after I found they were missing).
alohajason wrote:
stacey,
hi there.  I actually don’t remeber it was so long ago. Sorry you were having issues.
