Panasonic DFD
Started Apr 15, 2017 | Questions
OP Paul Amyes Senior Member • Posts: 1,907
Re: Panasonic DFD
Doux Vide wrote:
No offense, but I think that if you are serious about video to the point that EM1II is not enough and you need a GH5, then you should seriously consider manual focusing (so DFD or not DFD isn't a relevant issue) and lenses especially designed for video...
I already manual focus for video and own a nice set of primes for it.
The reason the EM1  mk2 isn't under consideration is that the while the advertising states a bit rate of just under 237 Mbps it is actually variable and most of the time it spits out around 24Mbps which at 4:2:0 means that the files are brittle and can be difficult to grade.
I would like to maintain a hybrid workflow where one camera can do both stills and video, but it is now looking more likely I'll end up springing for something like a Canon C100. Shame really I had high hopes for the gh5 but the AF seems half baked.
 Paul Amyes's gear list:Paul Amyes's gear list
Voigtlander 35mm F2.5 Color Skopar
Doux Vide
Doux Vide Contributing Member • Posts: 922
Re: Panasonic DFD
Sorry but then I don't get why you need DFD
DP13Photo Veteran Member • Posts: 6,307
Re: Panasonic DFD
I don't know if this helps, but my 12-40/2.8 focuses faster in low light on my GX85 than on my Pen F.
I definitely think you are smart to look at the GH4 if you are becoming more video centric.
I would try what you intend to do...you can always get a Lumix lens later if necessary.
Dave
 DP13Photo's gear list:DP13Photo's gear list
Sony a7 III Sony a7C Sony a7 IV Sony FE 28mm F2 Zeiss Batis 85mm F1.8 +15 more
Jon555 Veteran Member • Posts: 7,722
Update
Apparently Panasonic said this on Friday (about the GH5 video AF):
“We recommend to select 1-area AF in 30p or 60p frame rate for more comfortable Auto Focus speed. When you select 24p, 1-area AF is recommended.
If you are still experiencing slower than desired AF, Panasonic suggests to override AF by pressing the shutter button halfway down.
Panasonic pledges to further improve the AF quality.”
https://www.youtube.com/watch?v=rS2XL-ajHGk
This review is quite fun too:
https://www.youtube.com/watch?v=8WD9C3C2koU
(Okay, so it is true I wasn't thrilled to be given quite as hard a time on the forums when I was testing beta cameras and saying the AF wasn't there yet, but I really don't have an axe to grind and I still may get a GH5 as it's better than my GH4 is several areas.)
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
hindesite Veteran Member • Posts: 4,893
Re: Panasonic DFD
I don't get why you wouldn't want both.
Re: Panasonic DFD
Because for some situations CAF is desirable and I want to know if my existing m.Zuiko lenses will work or will I have to replace them with Panasonic ones.
MOD Tom Caldwell Forum Pro • Posts: 46,360
"DFD Lite"?
Raist3d wrote:
hindesite wrote:
Raist3d wrote:
The DFD will work better with Panasonic lenses, and yes, a full profile will realize the full benefit. However, as the Japanese GX850 brochure states, there's a partial DFD benefit even using non-Panasonic lenses (which does include Olympus lenses).
[citation needed]
I already did that before. Go ahead to Panasonic's Japanese website, go to their section on GF9, and translate the Japanese text. It's their Japanese website, not the PDF brochure (my small mistake):
http://panasonic.jp/dc/g_series/gf9/high_image_quality.html
Translate the section on AF- look for "空間認識AF"
"Improve autofocus speed and tracking performance
Adopt space recognition technology (DFD * technology) to instantaneously calculate the distance to all subjects appearing on the screen. Contrast AF which high precision was popular in the past, has also realized faster AF (autofocus) and improved tracking performance. In GF 9, even when using micro Four Thirds lenses other than ours, we can improve AF performance by utilizing a part of DFD technology.
* Abbreviation for Depth From Defocus."
Emphasis mine. You are welcome
I have also mentioned a few times that I thought Panasonic used a form of "DFD Lite" to get its quicker than usual CDAF performance and this manual snippet more or less confirms what I had thought common sense.
Anyone who has used manual focus lenses for more than a moment can agree that a slight  wiggle turn in one direction will soon enough visually disclose whether the lens is moving towards focus or away from it.  The degree of out of focus also give some indication of how far out of focus the lens is and some indication of how far the lens must be adjusted to get within precise focus distances.
I would imagine that if we were to make a science of it with one favourite lens our eye-brain-finger co-ordination might get quite good. Experienced users might not even need a preliminary test turn to determine which direction to twist.
Electronically a DFD lite system might be able to not only tell in which direction the lens is out of focus but also give a good estimation of how far it must travel quickly to get close to good focus.
Therefore "DFD Lite" must only be an electronic version of what any user of manual focus lenses can see and manipulate on any lens.  Full DFD must be when individual lens focus characteristics are fully documented and the process refined.
Therefore if (guess say) DFD lite gets 80% of the speed of PDAF (maybe faster?) then perhaps lens statistic based full DFD might add another 10% to this.  I simply do not know facts but use the figures only to illustrate my thoughts.  As PDAF is supposed to be very quick but lacking in finite precision even good pdaf systems can be hybrid and switch to cdaf for absolute precision.
Whatever method is used there is no doubt that Pansonic bodies focus Olympus lenses acceptably quickly.
I doubt if there is any secret on what needs to be done, just how it is done electronically is much harder.
Tom Caldwell
Re: Here, 2nd time I do it -
Raist3d wrote:
brentbrent wrote:
Interesting. I missed whenever you previously posted this. Thanks for posting it again.
The real bottom line is that DFD or not, I still find Panasonic focuses better (GM5, GX850, GX85) than my OMD EM5 MKII, PenF. OMD EM5 MKII does better than the PenF.
But not only the AF is better, the options are also better. The workflow for pinpoint AF is amazing. That said, the PenF is pretty good with focus peaking in MF.
This raises some interesting issues which might be best illustrated by how Canon EF lenses are handled via Metabones adapters.
Taking the very sharp Canon EF 135mm f2.0 as an example.  For some reason it was one of the hardest EF lenses to give good quick accurate AF when electronically adapted.  It is regarded as one of Canon's sharpest lenses and that may have been part of the problem.
In any case using MF this lens is incredibly sharp.  Once Metabones sorted out how to link the Olympus pdaf routine to the lens it has become equally sharp on the E-M1.  But the "in focus" cdaf image from the GX7 is not quite as sharp as MF or pdaf on the E-M1.  Which is disappointing.
My reasoning runs along the lines that the EF lenses were designed around the use of pdaf focusing methods whereas all M4/3 mount lenses must be designed to first work with cdaf.  I have no technical knowledge of whether a lens understands the difference in its firmware or not but there was little doubt that in the case of the E-M1 the AF performance of Metabones adapters jumped when pdaf was hooked in to replace the Olympus cdaf routine. And so one might guess that there are cdaf and pdaf focus methods and these are probably camera body based and interface with how the lens firmware combines with them.
Therefore does the Panasonic cdaf (DFD-lite) struggle with the relatively old design but very sharp EF 135/2.0 lens?  Later lenses such as the Canon EF 100mm f2.8L Macro have no focus accuracy issues when used on the GX7.
All this comes with the caveat that the 135mm f2.0 has always been a sort of last fontier lens when adapting to other mount systems with AF support.  Now that it does AF easily maybe it simply only needs a little trimming in the accuracy department.
Tom Caldwell
SystemAgnostic Contributing Member • Posts: 867
Re: Panasonic DFD
It looks like the C100 has a max bit rate of 24 Mbps.  I recall from past reviews that the video quality is equivalent to my 70d, which I'd rate as crappy (at least as far as detail or ability to grade).  Perhaps I'm wrong.  But you can get clean HDMI out and record on an $400 1080p Atomos.  I'd expect that would look pretty darn good.  But at $3400 for C100 with Dual Pixel and an Atomos, that is quite a bit more than the GH5, and you loose high speed recording and the ability pan and zoom in post with 4k.  And you might need new lenses?
It really comes down to how much you need continuous autofocus.  And note that even Canon Dual Pixel isn't perfect - it will lose focus sometimes.  So you'll likely want to continue to use manual focus on stationary subjects.
 SystemAgnostic's gear list:SystemAgnostic's gear list
Panasonic LX100 Panasonic Lumix DMC-GX85 Panasonic GH5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS +6 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,709
Re: Panasonic DFD
Paul Amyes wrote:
I'm in a bit of a quandary. I have a m4/3 kit based around an EM1 mki, EM10, and EP5 with the Olympus f2.8 zooms and 4 nice primes. At this stage I'm looking to get more into video - i already shoot quite a bit - and so I want a more video capable camera with 4K. The EM1 mkii would be nice but doesn't have all the video functions I need so consequently I'm looking at the GH5. My question is the Panasonic DFD focus is based only upon Panasonic lens profiles so if I get a GH5 will using my Olympus lenses mean decreased AF performance and so will I need to start acquiring Panasonic lenses as well?
Paul I use an Olympus 40-150 f2.8 pro lens with my gx8 and it focuses so fast and so accurate that none of my Panasonic f2.8 pro lenses can compete. And that's real world usage. Mainly indoor/outdoor sports and bird's in flight.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Kawika Nui Contributing Member • Posts: 905
Raist3d wrote:
hindesite wrote:
[citation needed]
The link you provided is to a pdf brochure on the GF9.  The section on 空間認識AF does not mention other cameras.  It's hard to find the reference you quote below on the Panasonic site.  Perhaps if you quoted more of it in Japanese, to allow for a search?
I'm also interested in this topic in regard to using Oly lenses on my G9.
TwoMetreBill Senior Member • Posts: 1,992
Re: Panasonic DFD
DFD is a gimmick that delivers very poor results. For stills you will be lucky if 75-80% of your shots will be in focus. If you are serious about video, you will be focusing manually anyway. No matter what you pay, all video systems hunt on AF. This is true even for 6-figure video gear.
Switch from Olympus to Panasonic for AF and you will regret it. True that Panasonic is superior for serious video. Serious means manual focusing, post processing with high end software, shooting on a tripod...
Bill
 TwoMetreBill's gear list:TwoMetreBill's gear list
Fujifilm X-T3 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR +2 more
Re: Panasonic DFD
" I’m thoroughly impressed by what Panasonic has achieved with the Depth From Defocus (DFD) for continuous AF." (https://blog.mingthein.com/2018/01/22/review-the-2018-panasonic-lumix-g9/)
My own average is more like 95%+, normally shooting burst or 4K video (G9). Maybe you got a bad copy?
Not if you are shooting fast-moving subjects coming toward you or moving away from you. Sports and action video is "serious" too, you know.
I'll never be able to afford 6-figure gear, but you are right. You can see it even in feature films with moving subjects. Not a lot, not often, but it is there.
Only if you stick with Olympic lenses. "Using Olympus lenses, you will not have the benefit of DFD for the S-AF and C-AF capability of the G9." (Ming Thien review cited above.)
Agreed.
Someone forgot to tell all the award-winning sports and action videographers about the tripod requirement.
carlgorski Contributing Member • Posts: 861
Re: Panasonic DFD
bad no matter what
whumber
whumber Veteran Member • Posts: 4,371
Re: Panasonic DFD
It really depends on what kind of movement you shoot. Things that move at a relatively constant speed are handled pretty well by DFD; but throw in some subject acceleration and DFD falls apart, even with Panasonic lenses.
I'm pretty skeptical about how much the lens specific DFD profile matters. I find almost zero difference in AF performance between Olympus and Panasonic lenses on my G9. Based on my reading of the available literature, Panasonic should be able to create an effective approximate PSF profile just by knowing the focal length and aperture ratio of the lens.
 whumber's gear list:whumber's gear list
Fujifilm X-T1 Olympus OM-D E-M1X Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: Panasonic DFD
I can say that my GX850 focuses better than my OMD EM5 MKII, Pen-F. Even the GM5 without DFD focuses better than those. But the EM1 MKII represents a major performance jump for Olympus...
My take honestly is- if you need video and by that I mean serious video, go for the GH5. It will still focus very fast with whatever lenses.
If you need ultimate speed/AF performance, but just pretty good video, go with the Olympus.
Honestly I think more than the AF, the first question is how serious you need/are into video. The GH5 may be overkill - or not.
What I can say though is that none of my Olympuses focus the Panasonic pancake F1.7 MKII which I adore accurate on most situations when it should, while the Panasonic bodies do.
My 20mm f1.7 mkii Pana focuses less well on my EM1.2 but not as bad as you make out. In low light, CAF is a struggle and SAF has its limits, especially if without an AF assist light, but I get the job done. It is my "emergency" social pic out and about lens quietly stashed in a small bag to complement my 12-100mm walkabout lens It surprises me how many say it does not work at all on Oly bodies...
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
(unknown member) Forum Pro • Posts: 12,354
Re: Panasonic DFD
I'm fast coming to the conclusion that you're the king of FUD on this forum, that's a ridiculous statement with nothing to support it.
